Visitor Agreement.
tidester
SUVs
happy motoring,
rockycow
Paid 22550 for 02 EX/auto, including security alarm and front muds.
Axle ratio can be compared only if the gear ratios are identical. So, it can mean differently with different vehicles and different gear ratios. I will use an example to try explaining effects of axle/gear ratios,
Assume that a vehicle has
First gear ratio: 3.00:1
Second gear ratio: 1.65:1
and so on.
Axle ratio: 3.50:1
This means that the vehicle has a overall drive ratio of 10.50:1 in first gear (3.00*3.50) and 4.95:1 in second gear.
Numerically higher overall drive ratio would indicate greater multiplication of torque reaching the wheels. Therefore first gear can pull more strongly than the second (almost 45% more than the second in our example). If the engine made 200 lb.-ft @ 4000 rpm, the torque available at wheel would be 200 * 10.50 = 2100 lb.-ft @ 4000 rpm(ignoring drivetrain losses and using a very simplified calculation).
Now, if we changed the axle ratio to 4.00:1, we have effectively increased the overall drive ratio in first gear to (3.00*4.00=) 12.00:1. So now, the effective torque at the wheels at 4000 rpm for the same engine would be 12.00*200 = 2400 lb.-ft. So, our vehicle will feel stronger evenif the engine is the same.
We improved the vehicle's pulling capability by using a numerically high overall drive ratio (in this case by using a numerically larger axle ratio). This same concept is used in vehicles with a low-gear.
If a vehicle has a 3.50:1 axle and has a 2.00:1 low gear drive, then, when the low gear is engaged, the effective axle ratio becomes 2.00*3.50 = 7.00:1. This doubles the pulling capability of the vehicle.
CRV uses different gear ratios between auto and manual transmission. With auto, the first gear overall drive ratio is 12.25:1 (I think), and with manual, it is 16.79:1 (I think), obtained by multiplying first gear ratio by axle ratio. This means that CRV will have a greater pull with manual transmission than with automatic.
The downside to using numerically high (referred to as 'short') overall drive ratio is that the engine revs higher for the same speed and limits the maximum speed attained in each gear. Therefore, short gearing is usually reserved for high revving engines.
I recall when we first got our '97 CR-V, a rattle/clicking noise developed which sounded like an idling lawn mower. We would hear it at certain times (but not all the time) when the car was idling or just starting up. It turned out to be 2 metal vacuum lines for the air conditioner touching and rattling at certain rpm range. The service guy just pulled them apart a bit by hand and solve the problem. However, I don't think the clicking noise you guys are experiencing is the same problem since you can feel it through the shifter.
from the steering column and have the Honda dealer-installed security syestem as well.
The noise when you press the brake before shifting to drive is a standard feature.
It exists in our 98 Accord and 92 Toyota Corolla.
I think it is a saftey mechanism.
Would appreciate any helpful information you can provide. Thx.
Now that we are into annoying things, can somebody let me know, how far back should the parking brake go? Mine seems a little long, specially for a brand new car. Thanks for the response in advance.
as far as black trim, when i had a jetta it had lots of black trim pieces, i used black magic, it is some sort of very thick silicone goop that you carefully apply, it usually last about a month or two depending on how often you get your car washed. but makes the black really black. on the inside i use armor all wipes, and the honda vymil treatment.
As an aside- does anyone know if the Model X will have AWD? Is there a Model X board within Edmunds?
This was on Friday afternoon and I have still not heard anything. Once I do i will post the information. I hope anyone else who gets any new info makes a post as well.
The other thing i noticed was that the clicking does not occur on braking when I have the car in 1st or 2nd gear; only in drive.
Does anybody else notice that?
Honda "Model X" - miniSUV/Hatchback
{edit mode - oops, I see you found it!}.
Steve
Took it to the dealer and the mechanic told me that it's the solenoid sensor.
This is from CR-V Engineer (off the Honda Information Xxchange board).
This is from CR-V Engineer (off the Honda Information Xchange board).
Sorry, I guess you cannot use a dash when posting.
Sorry about the typo!!!
Aloha
If I could get a hold of a Honda Engineer I'd be giving him an ear full. What is the "Honda Information Xchange Board?" Thanks for the post, it clarified the reason behind the noise but doesn't make me feel any better owning the car. I feel like it's a flaw in the design and Honda doesn't want to deal with it.
The message boards are through the "Members Forum" link. There's a signup link that sends an email to Bing, the owner/moderator. He'll email you the password for access to the message boards.
Of course the "CR-V" in the title is not as descriptive as it used to be. Bing has added message boards for the new Honda Pilot, Model X, and the Acura MDX.
An excellent place to visit if you own a CR-V.
After 500 miles, I'm pleased to report that the vehicle is quieter and tracking more accurately than I can ever recall.
elugwig: You may be right about cornering, but I don't think you would miss revving the engine in a CR-V. Peak horsepower is at 6000 rpm. I don't know where the new redline is, but it was at 6800 in the old model. Then again, if you have a CR-V budget . . . how about giving the Subaru Impreza wagons a look? (I'd suggest the WRX, but I don't want to be responsible for your insurance agent gagging on his own drool. )
There will be 55,000 CRVs imported, and going as far west as the Mississippi. There will be 15,000 Civic Si's imported, and Baltimore will be the sole import point for these models, nationwide.
Bob
I even had the security alarm installed.
I have a friend who also bought one and he has not experienced any clicking either.
My wife's 98 accord also has no clicking.
If it was the solenoid would the clicking not
occur on all 02 CRVs.
I'm posting this here only because there has been some discussion of Foresters (vs CRVs) on this board before, and I think most people are aware that there is an all-new Forester just around the corner. In fact, it will debut next week at the Chicago Auto Show.
From what little is shown, it appears the Forester has not strayed very far from the current model in terms of size. I'm hoping they've done some clever engineering to find some extra space for rear passengers. As I've said before, Subaru is positioning the brand to be be "sporty," and the Forester to be the sporty alternative in the mini-SUV market. There will be a turbo model, not this year, but for MY04, the following year. There are some rumors, however, the the H-6 may(?) be available, as Subaru just released an H-6 Legacy in Japan. Prior to this the H-6 has been strictly an Outback exclusive.
Bob
http://www.subaru.co.jp/
So the Civic Sis are arriving? Gotta go test drive one for the fun of it. Those things look like loads of fun.
Don't expect 36k miles from Dueler H/Ts. I got only 28k, though admittedly with aggressive driving. They are rated 180BB, vs. 460AB for the Dueler H/Ls for reference. I went Plus One and got tires rates 460AA.
-juice
Bob
The solenoid will be clicking on every A/T CR-V. How loud it is depends on how sensitive you are to such noises and what the ambient sound levels are. The only "fix" I might suggest is getting some sound dampening and lining the inside of the steering column. This can be purchsed in small quantities from Crutchfield or other audio outlets.
The CR-V Engineer also reads these boards, but keeps a low profile. (He must get a kick out of my rants.) In fact, the only reason he "decloaked" at the CR-V IX was to stop someone from using the incorrect part when fixing their CR-V. He answers a few questions every now and then, but he does so on his own time. He's not a public wiping post for every little complaint or problem that we might experience. That's what your dealer's service department is for.
zops, try it and see if you can feel it. Once you feel it, then it is much easier to hear it. But still, the noise is very low, I have to turn off radio/cd and really "look" for it.
I am interested in a hood deflector too. Like you, I haven't found one available yet.
thanks,
seguy
Follow the information in the Owners Manual for your year CR-V. It will also define "severe" and "normal" conditions for you. For example, my understanding is that all of Canada is considered "severe".
And remember that the dealer makes more money if you bring your CR-V in more often for service, so always check what they tell you with what's printed in the owner's manual.
