The noise is in my 2000 and has been there ever since last August. One thing I found out is if I take it in to an alignment shop, they are able to quiet the noise by tightening and lubricating every part in the rear suspension, but the noise come back after a few days.
I am inclined to think the noise is from dried out bushings or leaf springs, but I got a new tip that I may need a limited slip differential additive. The noise does not seem to cause any performance problems, but you are right, it is nerve racking.
http://www.kyb.com/products/detail.php?ID=1
I heard the Air Raid system is good and the AEM Brute Force is good and the K&N FIPT system is good. Does anybody have one of these replacing their stock 2000 Jeep Cherokee air cleaner system? I'd like to know how they really work on a 2000 Jeep with the 4.0L engine only. I know they work differently on other mills.
SUVs and Smart Shopper
i would try a can of SEA FOAM in the crank case to see if will clean lifters
or turn up radio
1994 Jeep Grand Cherokee engine noises
Jeep Cherokee and Grand Cherokee Front End Noise
torn boot could have ruined your axel shaft will need to replace that shaft rebuilt one is ok
drive shaft should have no play when you wiggle drive shaft look close at where it hookes up to your front axel housing if flange moves in out or up down have bad pinion berrings will need to be fixed soon
the cherokee is a 99.the boot is torn I will be taken it apart this weekend.Driveshaft there is endplay but no up and down play what so ever....I am starting to wonder if they sound is caused by a pcv valve or vacuum leak as it seeemed to happen only when you put a load on the vehicle.I havent been able to find part #s for the pcv it is cheap enough and the jeep has 120m.on it.....
look real good at front flange by punkin an the flang that goes into trans fer case
when you put load on jeep pinion move in if you have bad berings in punkin
Is this a usual problem and solvable?
Is it my auto box or prop shaft?
Really worried as I love this car.
