Visitor Agreement.
AFAIK, Sirius is not available as an option for the Canadian 07 Outlanders, not even with the HDD/Ent pack for XLS, so that would explain why you don't have the Sat option. Don't rely too much on the dealers, you probably know more than them.
Well, you always have the option to get non OEM Navi, but will it fit in the 07 Outlander?
I have been noticing the problem more by the day.
Hope this works, keep us in the loop.
These are the functionality that u are looking for:
DOOR UNLOCK MODE (Options)
(1)All doors unlock: All the doors are unlocked when the driver's side door is unlocked.
(2)Dr door unlock: Only the driver's side door is unlocked when the driver's side door is unlocked. (default)
KOS AUTO LOCK "auto lock function"(Options)
(1)Enable: No function (default)
(2)Disable: With function
A list of programmable alarm functions:
Hazard answer back
Dome light delay timer with door
Door unlock mode
Auto door unlock by position
Duration of horn chirp
Horn chirp by RKE
Tone alarm answer back
Timer lock timer
Duration prealarm
Alarm
Panic alarm switch
KOS auto lock
Fob out of car
KOS feature
KOS unlock disable time
What are these & what do they do: "Hazard answer back"; "Horn chirp by RKE"; "Tone alarm answer back"?
(1)LOCK: Flashes once, UNLOCK: Flashes twice (default)
(2)LOCK: Flashes once, UNLOCK: No flash
(3)LOCK: No flash, UNLOCK: Flash twice
(4)LOCK: Flash twice, UNLOCK: Flash once
(5)LOCK: Flash twice, UNLOCK: No flash
(6)LOCK: No flash, UNLOCK: Flash once
(7)Without function
This can be configured using the remote control, chk the manual.
Horn chirp by RKE
(1)No horn answerback function
(2)The horn sounds when the lock button of keyless entry transmitter is pressed once.
(3)The horn sounds when the lock button of keyless entry transmitter is pressed twice.(default)
(1)Not sound tone alarm: Without function
(2)At keyless key: Sounds when the keyless entry system is activated.
(3)At keyless: Sounds when KOS is activated (default).
(4)At Both: Sounds when the keyless entry system or KOS is activated.
Thanks again!
(I don't own an Outlander, hence all the questions, even though some are no doubt discussed in the manual)
Thanks for your patience!!
The answer is No. If the setting is programmed to flash once for UNLOCK and no flash for LOCK every time you press the UNLOCK button or UNLOCK fob it will flash once and every time you press the LOCK it will no flash.
:mad:
Glad to report the new radio works great!!
There are options in the menu for auto relock and auto relock time, but after reading the manual I think that takes effect if you unlock the car by touching the handle or using the button on the key and then do not open any door within the time period.
Does anyone know if there is a FAST key out of range lock function?
- if you are outside with the fob and you unlock, autolock could relock, as long as you are more then a couple of feet away
- if the fob is inside, it should not auto-relock under any surcubstances to avoid lockout...
If the auto-relock feature is a function of the distance between the car and the fob, then one would think that the system should be able to be programmed to auto-lock the way bobsmith would like it to.
thks
I also have this Radio clarity problem with my Outie since I got it back in may 07. I checked with Mitsubishi Canada (I'm in Montreal) yesterday and asked them about the TT-136-54-002 bulletin that been running around since april 07. I was told that TT-136-54-002 is in fact what Mitsubishi calls a "Tech Talk" ticket. It has not yet reached the Technical Bulletin stage yet. It will when the peeps working on the Radio clarity issue will find a solution. The Tech Talk was issued to dealers to warned them as to not try to fix the problem by either;
Changing the radio in the dash
Changing the antennae
Changing the AM/FM modulator located in the roof under the antennae
Apparently, none of the above solutions were successful to have the issue corrected so far and will result in a waste of time/money from both the customer and the dealer. So, there we have it...We gotta wait until Mitsubishi Motors finds the fix and release the official Tech bulletin. Until then, if you are experiencing this issue it will not hurt to call your dealer or Mitsubishi (Can or US) to let them know about it.
Cheers
I have the same issue with my base (single CD) unit, which it seems that it's not being addressed by Mitsu. Anyone else having the problem with the non-Rockford Fosgate radio?
You mention a Backup Camera option for the NAV display. Can you point me to this information? I don't seem to have any dealer support on finding this option and I want very much to install this feature in my 07 Outlander.
Howard
But if you're still interested in doing it, here goes: http://www.mitsubishiforum.com/m_139348/tm.htm
Have you dealt with Mitsubishi US directly, or the dealership only?
If the Mitsu Canada does not have accurate information on this issue at this point doesn't concern me as long as they receive the final TSB from Mitsu sometime in the near future. I will follow up with Mitsu Canada one of these days, but if I can provide them with some updated info from you it would be helpful.
