Dchopp put some great info together in there.
Steve
muckyduck: On my 2000 CR-V, I got a piece that sounds very similar to what you describe; it is the extension for the tire jack. Check your owner's manual for tire-changing instructions and see if that doesn't clear things up.
So doing a little reasearch I find several reports of this issue all around the 1000 to 2000 mile mark. Most of those reporting this problem say it was the oxygen sensor that was replaced. So I call the dealer this morning and he asks how did I find about this. I tell him on the internet and he wants to know where. Anyway he says oh yeah he has replaced a few. So I ask if he has the part, nope because he has used quite a few. Can he order it now so I don't have to wait? Nope, has to do the diagnosis first. Then he says he doesn't even think replacing the sensor is the fix since at least one person had the problem again. Then he says maybe there is a bad batch of sensors. Don't you love it?
As a point of reference I drove my Accord for ~13 years and the CEL never came on once. Now I realize todays engines are more sophisticated and from what I've read the slightest thing can set the CEL off but I have to admit I am a little perturbed. No one buys a new vehicle and thinks they'll have to have it serviced (and the inconvenience that goes along with it). I hope this isn't the karma gods getting me back since I have been such a vocal supporter of Honda.
They say they tested the EX manual - I thought the EX model did have tweeters installed in the dash. Sure sounds like it it does to me.
I have noticed a slight buzzing sound from one of the door speakers, just like the review said. Doesn't happen all the time, though. Has anyone else noticed this?
From what I heard, the tweeters upgrade kit for the LX goes inside the front doors. I thought the most common location for the tweeters is in the dash.
You can find this information by choosing Specifications and Features from the pop-up menu, then scroll down to the Interior Features section.
Hparts.com has the Tweeter installation instructions online as a PDF file here:
http://www.hparts.com/pdf/23092.pdf
Image 13 on Page 4 clearly shows that the tweeters are located in the dash near the base of the A pillars.
Has anyone had a buzzing sound (or maybe it is when playing deep bass the woofer is not able to produce it correctly - I can't think of the phrase for that but it can be pretty common in speakers, espically cheaper ones) from the in door speakers? Maybe I've been playing my CD's too loud and have damaged the speaker!!
It does not occur all the time however.
Once the dealer pulls the codes he will know in a hurry.
Should be a quick fix in any event.
Someone reported their second CEL after having the O2 sensor replaced. This got me thinking so I called the Service Manager where I bought my CR-V. He seemed very straightforward and went in to his "library" of Honda bulletins and memos and this is what he told me (paraphrasing):
When they pull the code they are getting 1164 error/fuel ratio. He says the normal fix would be to replace the O2 sensor (or even some others). However returned parts to Honda have shown no defects and they have concluded it is a software problem. On March 13th or 14th all Honda dealers should have received a memo stating that if code 1164 comes up, no repairs should be made, only reset the CEL. A software fix will be available in April or May.
So this afternoon I am taking mine in to a different dealer so I will keep my mouth shut up until he tells me what code was pulled. Hopefully he will have the same response.
Tweeters - I suspect that folks may be seeing the OEM tweeter kit for the 97-01 models (which are installed on the door). TheRacoon's information is correct for the '02 model.
WRT the Edmunds review, there are two possibilities. They apparently didn't hear the tweeters (which is not a good sign), or the reviewer missed them in the spec sheet and felt that he/she needed to comment. "Oh look... This thing doesn't have tweeters. The sound must be terrible." or something like that.
Personally, I suspect a little of both.
very happy with it and my wife like it a lot, but I would like to know what is the watts per channel on the basic factory stereo
in regular driving I have to dial the volume to almost half and the sound is not the best actually it is pretty cheap . I asked in a very good store that's specialized in high tech electronic and they told me that even if I change the speakers for better one's the head unit would not be able to supply the watts need it. at this time i do not want to rig the crv. any body know how can i impruve the sound?
Do you mean that you don't want to change the head unit? If so, I'm a little surprised that the electronics shop didn't suggest just adding an amplifier. Then you'll probably be ready for upgraded speakers.
More importantly, we really love the vehicle and think it fits our needs well. We have a 3 month old son and didn't want to start with a van or large SUV yet. We usually keep cars a long time (we donated our 89 Corolla with 200,000 miles to charity) but figure if we need more room we should be able to trade the CR-V in a few years without taking too much of a hit.
Thanks again for all of the great posts -- I'll try to occassionally be a contributor, too! By the way, my real name is Jeff -- as you may have guessed "JohnGalt66" is just a name I use on the internet for fun.
Which dealer in the Bay Area did you deal with?
Thx!
Now, the real issue - should the tires be at 26 psi like Honda recommends? These are the Bridgestone OEM tires. Driving on the highway over the weekend, I did not hear excessive road noise and the tires were NOT at 26 since I was unsure about my gauge - I didn't want to make them less than 26. The cr-v seems to rock some on bad roads - could that be due to the higher pressure?
P.S. if you were going for an exciting car - OH MAN, there was a CR-V in the showroom that had the nice wheels, body side cladding, footstep, and wood trim - all of which turned the CR-V into a HHHHOOOOTTTT looking vehicle that WILL turn heads.. Anybody have pictures of a black leather interior?
I counted EIGHT references to MIke Patton in your post and it sounds less like an endorsement than a promo or solicitation. It's a good thing you didn't include a phone number and link to a website!
Let's be more careful about our endorsements because it's a very short step into promotion and solicitation which violate Edmund's Terms of Use. There are other forums for discussing dealers and we'd prefer to stick closer to Honda CR-Vs here.
tidester
SUVs
limited but at over $30k Could not justify it.So
I got the CRV EX and I added the woodgrain kit
myself which I got through the internet for $142
plus shipping of $5.It was amazingly simple to install and dresses up the interior nicely.Now that gas is skyrocketing up I am glad I don't
have to feed a V6.As for power it is too easy to
do 80 mph.On hills it's broad torque band is really appreciated.I considered the Santa Fe too but this little 4 banger is a lot peppier than the V6 in it.So far the only negatve thing is due to it's short wheelbase it has a choppy ride
on some freeways that are not perfectly flat.To get a smooth ride then you need a bigger
vehicle.My daily drive does not involve this kind of road thank goodness.It may be my imagination
but when changing lanes the high turn signals
tend to catch the other drivers attention quicker
than my old car did.
I may not need it but for $15/month I get some peace of mind. You never know even with Honda Quality.
GIVE ME A BREAK!!!!!!!!!!!
You all paid 22K and are expecting this to be a luxury SUZ like a Lexus or BMW-- GET REAL!!!
Stop complaining and enjoy the 22K SUV, like I am.
This was my budget for a small SUV and am very happy with my purchase but I was NOT expecting
a totally smooth, noiseless ride with high quality audio tweeters and superb armrests, etcc.
If you want the better accessories you need to pay for it. Don't just sit there and complain after paying just 22K for a SUV.
Rememembrr, you get what you pay for!!
Sport Utility Zebra (if the white had come with the black interior)
Sport Utility Zen (the enlightened Sport Ute)
Sport Utility Zephyr (ride with a gentle breeze)
rockycow
Any info will be appreciated.
If I had to guess what will be done with the CR-V I would think no changes for '03 (minor mechanical tweaks I'm sure but nothing significant). Either in '04 or '05 they will make cosmetic changes to the lights, grill, front fascia, etc. I call this a "freshening". A new color or two may also be added. When they will release an SE is hard to say. They just might introduce one fairly quickly to get those extra $ that people are willing to pay for painted bumpers, leather and a hard spare cover (not sure what else they can do---EX already has the 6 disc CD changer---but I'm sure they'll come up with something).
Perhaps they'll include the subwoofer as an audio system upgrade?
I've got more than a few years of life left in my '99 EX, so I can be patient.
The only small car to match it is the new Impreza, so things are looking good for the new Forester (which was already Good), too.
By the way, both beat Volvo's S40. :-)
http://www.iihs.org
-juice
Juice - The Civic was tested a while ago. I believe that the IIHS ranked it in their top five safest cars list along with the Passat and a few others. It's also been tested by the NHTSA.
Sorry if that's old news, I hadn't heard it mentioned here, and I do think it's relevant since the CR-V is based on it.
-juice
I believe the OEM speakers are 6.5" - is that correct? And does anyone know the watts/channel?
The side airbags do make a difference, but I also see a trend with height. It seems that vehicles with seating higher off the ground tend to do better in the side impact tests. Compare the previous generation CR-V with the previous Civic as an example. Four door vehicles also seem to score higher (placement of the B-pillar, I'm sure).
A TSB (technical service bulletin) would be issued for something like this. Honda service techs would be made aware of the problem and how to correct it. However, customers wouldn't be contacted. Only the people who have the problem will get the fix.
