I put my gauges on hi and low ports. Compressor kicks in and press increases on suction and discharge. I here switch on dryer closing and opening. Not sure if condenser coil fan is coming on. Is there a press switch that turns the fan on? Also as the press increases the engine starts to strain. Car is in park. System been vacuumed and charged, 1.2 lbs of 134A.
Last year i had problems with my air conditioner, and had to replace the fan which cost me over $1200, this year my air conditioner is blowing hot air, I had the coolant check and it was full. I have carried my car back over 4 times to the dealership where i purchased it. After leaving it there for 5 days, i have the same problems. Is there anybody out there that can tell me what to do. Someone mentioned the switch is bad, and i informed them, but they refused to fix it. Please someone reply and let me know what to do.
Hello. Does anyone know how to bypass/troubleshoot the A/C fan switch and A/C fan relay on a 2006 Chrysler PT Cruiser? Apparently, it must be a trade secret or something, because I have searched the internet, Chrysler forums, asked for advise on the local craigslist, and nothing. Not even a whisper of advise. Oh, sure, the dealers and local repair shops will do it, only if they can replace the whole system, not troubleshoot it like I ask. Thank you.
After running either the heater or A/C for about 30-45 minutes and internal vent door begins to close. I can hear the fan running at different speeds I select but the volume greatly reduced. After an hour off the same thing happens again . Are these vent doors operated by vacuum line or electrical drive?
My ac works intermittently, but mostly it doesn't work at all. I paid to have it analyzed and was told that the compressor clutch module is not working. They said it was $600 to replace and then Chrysler may have to program it. Chrysler would not say how much that would cost. Does this make sense? I can't seem to find out anything about such a module and where it is physically located. Is it part of the compressor or clutch assy? Does anyone know? I would really appreciate any information.
After three visits at two different repair shops to repair the air conditioning in my 2007 PT, here is what finally worked:
First, one shop told me that the computer module would need replacement. I did not even ask how much that would cost. Another shop told me that the entire radiator fan and cowling assembly needed replacement. The shop wanted $680 to perform the job. The reason given for the high cost was the $425 price of the original Chrysler part. I told the shop "no thanks" and I found the assembly on line (brand new) for $88. It was easy and fairly straight-forward enough to replace the assembly myself. After replacement, the A/C still did not work. There appeared to be no change in symptoms.
Next, after more on-line post readings, I paper-clipped the contacts in the Low-Pressure Switch connector that sits atop the accumulator. After starting the engine, I immediately felt ice cold air for the first time in two years. I found the switch in stock at my local Auto Zone for $29 (Santech #MT1191). It was super simple to replace. No freon vacuuming is required - just unscrew the old switch and screw in the new one. The wiring connector easily pulls off and the only tool requited to remove and replace the part is a small crescent wrench or a half-inch wrench. It is a ten-minute job. Within an hour of the paper-clip diagnosis, the problem was repaired and the A/C has been working perfectly ever since.
So, before you shell out big bucks on other "remedies", pull off that LPS connector, use a small piece of wire or paper clip and short the two contacts in the connector (do not let the jumper short out against the engine or body metal). Then, see if the A/C is working. You may want to take it for a full test drive before you decide. I did make sure that I had a full charge of freon before I tested the LPS.
Hey where did you find the part for $88.00? I took my 2007 PT to the dealership and they told me $800 to fix it!! Said to replace the Fan. And you say that might not even be the problem? My A/C works as long as I am moving but when I am stopped, it starts to blow warm air and the RPM's drop - bog down as sounds like compressor is kicking in and out? Any additional Info greatly Appreciated!! Thanks
It first started by blowing the fuse all the time, then only worked when it wanted to and now I cant get any cold air. I can feel it in the engine when it kicks on and off sometimes but only get hot air. Any ideas?
Go to www.partsgeek.com. Specify the correct year.
It was $88 for the entire fan assembly and about $9 for shipping. You CAN do it yourself; it's relatively easy. It helped that I had mini drive-up ramps and a floor creeper, but, these are not mandatory.
Remove the negative battery terminal but don't waste time removing the entire battery and battery shelf. Removing the wiring connector is a little tricky. Look at the connection in good lighting. Slide a small-bladed screwdriver between the (fan side) catch prongs and the body of the connector (the raised hump). Then pull out the (car-side) jack.
I did not open the radiator drain plug. I just shoved a short piece of plastic tubing into the radiator cap (the metal cap over the front of engine, not the plastic over-flow cap) and after it filled with fluid, I pinched the end and pulled it out to create a siphon. I drained out two beer cans worth of fluid. With the car on the ramps, this was enough to drop the fluid level below the upper radiator hose flange.
Remove the two lower fan cowling bolts then the bolt on each side. The driver's side bolt is the most problematic - having a thin arm helps. Remove the front grill by removing the four bolts on top and then unsnapping the grill by pulling each side forward until it pops out - you'll see the two snaps on each side as you pull it toward you.
Twist the two radiator retainers (black oval-shaped plastic about the size of a dollar coin) on the top of the radiator counter -clockwise and pull them off. Lift off the front portion of the rubber hood gasket and set it out of your way. Remove the upper radiator bracket bolts and the one center brace bolt. Remove the remaining two upper fan cowling bolts, tilt the radiator forward and behold! You can now pull out the entire fan assembly. Just install the new fan by reversing the process.
Well, I gave up and went to the Chrysler dealer to get a diagnostic on what was wrong. First of all, my dealer charges $98 to program the module. Second of all it wasn't the module after all, it was the low preasure switch. Third of all the first garage had damaged the high-side Shrader valve and all the refrigerant was gone. I paid $247 for Chrysler to fix it and then went back to my local garage, which was, by the way, recommended on Angie's List. And raised hell with them. They apologized and refunded the $182 which they had charged for the labor the first time and threw in an oil change. I don't believe I'll take the oil change though. :>) Thanks BThompson. Must be a lot of this going around.
Well, apparently, I bought the last $88 fan assembly. It seems that the price has coincidentally gone up to $94. That is still a lot better than $680 or $800! The direct link to the part is below:
I'm a novice as far as car repair goes and definitely can't afford the dealer fix for this problem. Do you know where I can find a diagram that shows me where the low pressure switch is? I'm having the exact same problem with the ac and the dealer recommended the exact same fix.
The accumulator is the vertically mounted aluminum cannister on the firewall of the engine compartment passenger side. It is about the size of a small travel Thermos (or a 24-oz. beer can). There is an A/C refrigerant line attached. You will see the LPS mounted on top.
Well, the switch need only be replaced after performing the paperclip test to verify the defect. If the A/C was charged two months ago then it should still be charged unless you have a leak. Other possible causes can be the High Pressure Switch located on the compressor, the radiotor fan assembly (as described in this discussion thread), a fuse, a relay, or A/C console switch. Then of course, there's always the worst-case scenarios - bad compressor, compressor clutch, condenser coil or evaporator coil.
And, in the category of "Just Really Bad Luck", the new switch may be defective. Perform the LPS paper clip test again. If the compressor kicks in when the LPS connector is shorted with the paper clip, then you may need to buy a $10 can of R-134a that comes with a gage (Big Lots), attach it to the low-pressure line and see how much of a charge is indicated.
Unfortunately, there is not just a plain ol' "Edit" button to click on for one's previous posts (after log out), so I will elaborate on one of my previous entries. In my reference to the "tricky connector removal", I am referring to the removal of the fan cowling connector, not the negative battery terminal. The cowling connector is located at the bottom of the radiator fan assembly, not near the battery terminal.
I will reply to anyone who has questions within a reasonable period of days. I have set up my posts to e-mail me of any responses. I do ask that anyone who benefits from these posts to also pass along their "lessons learned".
Ok, put the old LPS back on, attached a paperclip to the two prongs in the LPS, started the car and put the a/c on high and recirculate...Nothing happened, the air would blow but nothing cool, no surging, no compressor kicking in. Stopped the car, put on the new switch I bought yesterday and attached the wiring harness. A/C went back to doing what it used to, barely cool and surging with a drop in RPM's. I put on a pressure gauge that came with a can of refrigerant and started the car again. The gauge was set for the ambient temperature, put the a/c on high and recirculate, at first the guage read that it was low but when the engine started surging again the needle would peg out way beyond the high pressure red zone and then it would come back to the middle of the 10 psi zone between 45 and 55 psi. When it would surge again the needle would peg out once again. Took of the pressure gauge and came in to message you, so this is where I stand as of now. I have not added refrigerant. Any ideas? Do I need to paperclip the new LPS? Getting frustrated and hot!!!
Whoa. I just realized that your post says that you paper clipped the LPS and not the LPS connector (?!?). If I am misunderstanding and you did clip the connector contacts and not the switch contacts, then the symptoms appear to be that of low-speed radiator fan failure. Does the A/C act any differently when traveling at 70mph?
I'm not trying to make you feel like a novice, but I will elaborate further for the other novices out there (like I was recently) .
The Low Pressure Switch (LPS) cycles the compressor based on the pressure in the accumulator (aluminum cannister that LPS is mounted atop). Pressure is a function of the temperature of the Freon liquid/gas cycle loop. This is why the compressor will not kick in at idle when the low-speed radiator fan is defective but it will kick in if the vehicle is at highway speed, or if the high speed fan can lower the condenser coil temp enough to trip a non-defective LPS. In other words, there must be enough air flow across the condenser coil to lower the pressure to the point that it will close the LPS and kick in the compressor.
By-passing the LPS via shorting out the connector contacts (the connector with the wires leading from it that plugs onto the top of the LPS) takes the switch and accumulator pressure out of the troubleshooting equation. The LPS switch contacts go to the computer module and the closed switch (such as when the contacts are shorted with a paper clip) signals the computer to tell the compressor to engage.
So, the paper clip test can not only by-pass the LPS switch and pressure as factors, it can also by-pass the low-speed radiator fan as an issue. In other words, if the LPS connector contacts are shorted, the computer will attempt to engage the compressor even though there may be low Freon, a bad LPS, and a decective low-speed radiator fan (assuming other components have been verified such as fuse, relay, and high-pressure cut-out switch).
Therefore, IF the LPS paper clip test causes the compressor to engage, then there are three things to check:
The cost to repair, respectively, (assuming DIY) is approximately:
1. $15 2. $30 3. $100
In my case, I had both problems 2 AND 3.
As a caveat, if the paper clip tests does kick in the compressor, do not let the compressor stay engaged for more than the few seconds required to verify that it is running. Doing so with low Freon can damage the compressor; doing so with a defective low-speed radiator fan can cause excessive pressure to buld up in the system loop; doing so with a bad LPS can cause the coil to freeze up and produce other damage.
I am sure that there are professionals out there who can and will correct my explanations and/or logic, and I would welcome any additional information assistance or clarification, but, the above seems to be the mode of operation that eventualy led me to the correct troubleshooting that finally resulted in cold air - and without an outlay of hundreds of dollars (or more).
2005 PT Cruiser I found this older post and was needing to know where the plug is to check
(You may have a plugged AC system drain. The evaporator and condenser remove moisture from the conditioned air and that water usually drains away while you drive. If the drain is plugged or damaged, the water collects inside the system.)
You're not making me feel like a novice, I am a novice (at a/c work). I put the paperclip ends into the LPS connector, just made a loop with either end in the switch. Started the car, put the a/c on high and recirculate, just blew hot air. Took the paperclip out, put the connector back on the LPS and started the car again with the air on high and recirculate, still no cold air, but it does continue to surge with the car in park and idle. The fan on the radiator does sound like it is on. We used to get cold air while driving but as of last Saturday nothing. Thanks for continuing to respond and help with this problem.
The "surge" you describe would tend to make me believe that the compressor is being cycled. This could mean low Freon, but, that would be counter-intuitive to the fact that cycling requires a minimum amount of Freon.
That fact that you used to get cooling when traveling at high speed would make me believe that the low-speed radiator fan is not operating. Since you are no longer getting any cooling when traveling at high speed, this tends to also point to low Freon.
Use a flashlight to verify low-speed fan operation. The fan should come on as soon as the A/C is turned on.
You may have both a low-Freon issue and a bad low-speed radiator fan issue.
On a recent trip, the air conditioning would run great for about an hour, then it would quit, I would turn it off for about 30 minutes and then it would ran again. Temps were high 90's outside. I could hear the fan running but no air was coming thru the vents. This happened for the entire 6 hour trip. No problems on the way back, ran cold. Any ideas?? This is a 2001 that I just purchased about 3 months ago. Thanks..
I have the same thing going on with mine and can anyone help me out...here is what i have...the air is luke warm at idle and when the comp kicks on it makes the car idle real low...It gets a bit cooler when you are up to speed. I have also seen smoke coming from under the passenger side fender well a time or 2...I have did the paperclip thing and the comp cuts on when i jump it. the next deal os the cooling fan. It does not come on when I cut the air on...so I am asking should i buy a fan and put it on or try something else to make sure it isnt the relay or just low on freon....I also notice when the comp kicks on the small a/c line up on the firewall gets really cold fast...any help would be awesome....
It sure sounds like the low-speed fan. Swap the low- and high-speed relays located on the fan shroud to eliminate the relay from the equation. You should be able to use a flashlight to verify low-speed operation. If the low-speed does not kick in with engine running and and A/C switched on, the check out my previous post(s) on fan assembly replacement.
so i can just swap the plugs on the 2 relays that are on the fan shroud and if it is the low speed fan it should come on when i cut air on...Could the smoking be the fan motor?
If memory serves me, I believe that the relay connectors are snap-mounted to the shroud and the relays can be pulled up and off after releasing the snap catches. It is possible that fan motor coil burn-out could have caused smoke.
The point of swapping the relays is to eliminate the low-speed relay from the possible list of defects. So, if the low speed fan is inoperartive before swapping and it is operative after swapping, then the relay is the problem (assuming engine running and A/C selected). If the low speed fan is inop in both situations, then seek solution elsewhere.
Yes, if you have a set of jumper clips, you can attempt to "hot wire" the low speed fan circuit and test operation.
If you want to pony up the dollars, most shops will charge you around $60 to diagnose your A/C system. If one does verify that the low-speed fan is the issue, then you can proceed with DIY replacement.
WELL I TOOK IT TO GET CHECKED AND HAD A COUPON FOR FREE A/C CHECK AND WHEN THEY CUT THE AIR ON SPARKS SHOT OUT FROM THE FAN AND THE WENT TO RUNNING LMAO....THEY DIDNT KNOW HOW THE HIGH SPEED FAN WAS STILL WORKING BUT IT ...THEY CALLED THE DEALERSHIP AND THEY WANTED $567 FOR FAN AND THEY WANTED $180 TO PUT IT ON...SOOOOOOOOOOOOO THANK GOODNESS FOR EBAY...$108 BUCKS AND SHIPPED TODAY AND I GOT A TOOL BOX AND 2 BOYS THAT NEED TO LEARN HOW TO WORK ON STUFF,,,,THANKS FOR YOUR HELP
JUST GOT DONE PUTTING NEW FAN ON AND ITS FIXED WOOOHOOOO NOW TIME TO TRADE THAT [non-permissible content removed] IN LOL.......2008 CAR AND HAVE TO PUT NEW FAN AND CAM SENSOR.....CHRYSLER SUCKS
Congratulations! I know the feeling of elation that you are now feeling. It is a shame that Chrysler has not maintained the standards of quality for its suppliers that it has established for its own manufacturing. The fan assembly and the CAM sensor were designed and manufactured by third-party, lower tiered suppliers.
Thanks to all the posting in this forum I got the quick and inexpensive fix to my air conditioning. Per advice and very good instruction by bhtompson I now have cool air again. Just as many others complained mine went out suddenly and blew only hot air. I replaced the LPS switch which cost $30.00 and was lucky to get the last one from Auto Zone in my area. Thanks again for all the advice
Let me also say many thanks to the guys who posted their info in this forum...It's save us a lot of $$ and time.
I took it to a local Meineke and they said they tested everything and freon and relays were good...they thought it was a compressor going out. Told me to take it to Dodge as we only have 46K miles on the car.
I took a chance with the LPS as jumpering the connector would get us cool air....got the part installed this morning and took a 2 hr round trip..so far so good!
I wouldn't have known this was a common issue had it not been for this post!! Thanks again!
Just a FYI also that santech part seemed a bit heavier than the OEM part...hopefully this one will last the life of the car!
I travel out of town quite a bit so i haven't had the time to work on my a/c issue lately. Today I verified that the fan behind the radiator works, tried to put in R-134a with sealant in and still getting nothing. The old LPS is in (because there was no change with the new LPS in, and it actually blows cool at idle with the old LPS), the a'c blows semi-cool air when sitting still in park if you have your hand right up near the vent. I took the car for a high speed (65-70mph) test for about 8 miles to see if it blew cold like it used to at high speeds............nothing, still hot. It actually seems to be cooler when sitting still than moving now. It was 101 degrees out today during the test drive. So far $60 bucks in with no results.......I have a coupon for a free a/c check at a local repair shop so I guess I'll see if I can get it over there for that. I am on call 24/7 for the next 6 days so getting it there may be a problem. Any other previously unposted ideas that I can do while I have a little time today?
I believe the previous posts covered just about all the bases. It sounds as though you may have a problem with your high-speed radiator fan but I would expect to see the engine run hot if that is the case. When you charged up the Freon, did you do so with a gage? With the gage attached and A/C on, you should see the change in pressure as the compressor cycles. An over-charge might cause the high-pressure cut-out switch to trip at higher RPM. If all else fails, use the free coupon for a diagnosis and then return to the on-line posts for the DIY repair.
I bought a 2006 base PT cruiser in '08. Since I bought the car, I have had a/c issues and overheating issues. Here's how my story goes. Within the last year, I have replaced about 3 fans, one a/c cut off switch and other things I can't even remember. Nevertheless I have taken it time and time again to have the same problem occuring. Let say my car comes out of the autoshop with the a brand new fan and the whole nine yards, 3-6 months later, I'm stopped at a red light and all the sudden my car starts shaking, my fan turns off, and BAM!!!!!!!!! my car fricken overheats on me. It never fails, I fix my car and then it messes up. Can someone please help me?!?!?!?!?!? What does my a/c have anything to do with the car overheating????????????
Oh oh oh!!!! not to mention now I have a dying cat under my hood when I start the effin car. Please I can't anymore. I am in desperate, desperate need for some experienced opinions here.
It is more likely that your overheating problem is the cause of your A/C problems. In order to attempt troubleshooting via the form, we will need more information.
1. By fan replacement, I assume you mean the radiator fan/cowling assembly(?) 2. By A/C cut-off switch, do you mean the Low Pressure Switch (LPS) or the High-Pressure Cut-off? 3. What other parts/compnents have been replaced?
It is possible that the root cause is electrical related and not component/part related. If that is the case, perhaps not all three fans were bad. The Powertrain Control Module (PCM) activates the high and low speed radiator fan relays by grounding one side of the relays. Faulty wiring or a PCM issue can prevent this. Does the ar ever travel through coastal salt water?
Are you having this work performed by a private mechanic(s) or a Chysler dealer?
The more information that you can provide, the easier it will be to determine the root cause.
Well, I'm back next step is to replace the fan, the new LPS switch is no longer blowing cool air and the freon is good. Uggg Why can't we raise enough H*LL to get Chrysler to fix the problems.
Before you let a shop take your money, do these two checks first (assuming that you are correct and your Freon is as it should be):
1. With the radiator cool (in the morning or before driving for the first time of the day) and the PT in Park and at idle, turn on the A/C on low blower speed. Use a flashlight to see if the radiator fan is running. It should always run if the A/C is on. If the fan is not running (on Low Speed) it may be defective IF the fuses are good.
2. If the radiator fan is running then return to the LPS paperclip test (see my previous posts). It only takes two minutes to check. The OEM LPS devices seem to be problematic, the replacement switches available from Auto Zone are reported to be better.
If shorting out the contacts in the LPS connector (connector and NOT switch)produces cool air, then you have found the source of your problem (perhaps for the second time).
Another person with an A/C problem... Less than two weeks after I purchased my 2006 PT Cruiser the a/c stopped working after driving about 20 miles. I brought it to the dealer and they said the a/c was actually freezing, that ice build up on the a/c and the ice was blocking the air from coming through the vents. They told me to turn off thew a/c so the ice would melt then it would work again. They then said it would cost $690 to fix it, replace the part that was broken. I reported them to consumer affairs for this and other issues because I purchased the car less than two weeks before all of the problems... Any suggestions? Why doesn't Chrysler recall the car for this? It seems many people have a/c problems.
And has anyone ever heard that you cannot use burned CD's int he CD player? The dealer told me to only use store bought CD's when I told them the CD player was not working.
And finally, Only 39,000 miles and the clutch went. The person before me obviously could not drive a stick shift... Or is this a known problem? :mad:
Swing, That was my first sign before my AC went out completely. But it was the low pressure control. Which should not be that expensive. And has been discussed on here over the past month or so.
Hi all my AC uniton my 2005 PT convertible, just statred blowing warm air,but not all the time,i noticed a puff of what i thought was smoke come out from under the hood.but,it turned out to be a blow back or preasure release i could smell freeon/refrigerent.This is a new problem.The engine starts ideling very rough when this happens.Any ideas ?
Thanks in advance.
RichW
Good luck!
Easy. Budget about 90 minutes of your time.
http://www.partsgeek.com/catalog/2007/chrysler/pt_cruiser/cooling_system/radiato- r_fan_assembly.html
1. Low Freon
2. Defective LPS
3. Defective low-speed radiator fan
1. $15
2. $30
3. $100
I hope this helps.
Hope this helps.
Good luck Karen.
Rich :lemon:
John
