Anyway, how do you know the problem is the battery? Was the voltage checked?
We've been loyal Chevy owners for many years, my 3 month old 93 s 10 pickup sat in my yard went boom and burned, alternator shorted out, GM took responsibility and I got another truck. In my 95 I bought a new GMC Safari van and didn't get home with it, some sensor went out and I drove a loaner for a week......but I've stuck with 'em cos they've always fixed what went wrong, not now, nobody knows.......I need help with this please.
Otherwise what's happening seems normal to me.
Anyway, when your low beams go out use high beams as a back up.
I believe the fix has been to replace both the #45 & #46 fuses. Haven't done that yet myself as I just keep switching to my high beams and eventually the low beams will come back on.
Ditto on the ugh!
Do you have any suggestions or advice for us. Apparently this is a major issue with these Trailblazers!!!!!!
Head light off
Can’t remove the key
4x4 change by itself
Can’t open passenger door or back door
Music volume control
I read also that you are in GM CustSrvcDptm, will you direct me to the solution?
Thanks Rafael
Ok...low beams go off and on at will. Replaced all fuses, had so much service, checked wiring, problem still happens and we can't figure out why. On a cross country trip, we spent more time in Chevy garages than on the open road! New plugs, new filters, new ignition switch, and lots more. Now the Check Engine Light is still lit, lights still go off, and now...when we add gas, the car runs rough for the first few minutes! Sometimes even stalls! The right hand outside mirror is frozen in space. But most of all...we can't run it in two wheel drive. NOISE comes out like as if we are popping popcorn! We had a complete new transmission several years ago. Chevy garage is no help...since it is all intermittant! HELP! we spent over $6000.00 on the road getting it road worthy enough to drive through the Colorado Mountains and Reno Mountains! Still not running right. HELLLLLLP
i have the exact same car and problem. i've changed the battery, ignition switch, fuse panel, relay module all with no solution. starter checks out fine. chevy dealer says they can find the problem because they can't duplicate it.
it's obviously electrical but what the heck is going on? i would love to know.
any info would be great. i think it's between the fuse panel and the starter.
billberke
All is well now and I'll keep the beast until it dies.
Bill
I apologize that the different components replaced by our dealership did not resolve the concerns you had been having with your Trailblazer; it's good to know that you were able to find the root of the problem (the starter motor) and that everything is back up and running.
I wish you many more happy miles!
Sarah
GM Customer Service
Bill
If you're interested in pursuing a refund, I would recommend speaking with your dealership. However, one of the considerations when evaluating different cases is whether or not you as the customer have invested money through our dealerships into your vehicle repairs. While this does not guarantee any end cost assistance as it is just one of many different variables we look at, it definitely does contribute to the case. Should anything arise in the future, please do let us know.
Sarah
GM Customer Service
I am having some trouble with my wife's 05 TB EXT LS. For a while the speedometer has been working on and off. Sometimes it marks good, sometimes it just doesn't move at all, or I could be going at 60-70mph and says is going at 30mph. No biggie on that, truck was still driving, so a quick app download on phone gave me speed.
Sometimes the when at a red light, the truck would completely shut off...only has happened around 4-5 times in the 3 years we've had truck...would start right away, so we kept driving it.
Check engine would come on and off, took it to auto part, forgot the code it gave, but they said it wasn't a big deal. The light would come off, so again we kept driving it.
For a few months now, I've had a battery drain problem. Checked battery, was from 08 so decided to replace. No problems for a few days, then again, new battery completely dead. A jump start would solve the problem, for 2 days...so I started digging into it. Started checking fuses under the hood, took off ignition and onstar fuses off overnight, put them back in next day, truck started without a problem. Thought it would be the onstar module, so since I don't use it, left it out. Next day, battery drained again. I took all the fuses out of the front, checked battery voltage every 5 minutes or so (after waiting around 30 mins for computer to shut off) and voltage kept going down. Figured the fault wasn't there, and since it was about to rain, I took all the fuses out in the rear fuse box to see if the voltage would stop dropping, yeah, probably a bad move on my part. I put everything back next day. voltage kept dropping. Now when I start the car and put on drive, it's apparently on 2nd gear! At all this the key was stuck in ignition, even when battery was fully charged. Had to push on the release to get key out. Ordered new ignition switch (thanks to all posters on the subject!) I left the battery connected without the ignition switch connected, for 3 days, no battery drain. Put new switch in, still key won't come out, and got a battery drain again. and to top it off...the temperature gauge now is all crazy..like it got de-calibrated? it sits about a 180 degrees from 0 mark when engine is off and then it goes up (well keeps going its way toward the 0 mark doing a complete circle in the gauge meter)... No $ to take to mechanic..and wife going nuts for not having a car..she can't drive a stick shift so she can't drive my VW golf.
Sorry for the long post, but just thought i'd give and overview of what's doing and what i've done...Does anybody have any pointers for me? I'm good with a meter, and good with tools, I've rebuilt engines before, I'm an audio engineer by trade, with some electronic know how, but this is driving me crazy!
Any help would be greatly appreciated!
Thanks, Fafel
About a month later the driver side dim headlight went out, we changed the bulb and it didn't fix it. My husband eventually got frustrated and knocked the crap out of it and it started working again. Every now and then we would have to hit it to make it come back on. Soon after, the passenger side side started doing it, sure enough we could hit it and it would start working again. Now the driver side dim light wont work at all and the passenger side light wont stay on, still though, the brights work. We have tried changing the bulbs.
I haven't found anything to trigger this problem but at times the cruise will not work, it have fiddled with the blinker, bright/dim switch, and tried turning the car off and on.
In the past month the face vents for the ac have stopped working, the feet and defroster still work fine. Two weeks ago, the battery shorted out. After changing the battery the radio stopped working for a few days, now my door speakers cut in and out constantly.
My most currently developed problem; the transmission will not shift into third gear, we tried changing the fluid and filter, there were also very few shavings that had been dropped. It just rolled over to 90,000 miles so I would think it to be in good condition? There was no slipping before hand. I just started it and it wouldn't shift while on the highway. Could this be an electrical problem causing all of these problems or am I stuck with a lemon?
I noticed that when I turned off the ignition and removed the key that the red battery light stayed on. the key switch had some play in it so i made sure the switch was all the way in the off position and the light would go and that problem was solved. it would also do it with the key in if it wasn't all the way back in the off position. if it was overnite a jump would get it going without any memory loss to the radio so it apparently it wasn't discharging the battery completely. if I didn't drive it for a few days and the light was on it totally discharged the battery.
Were the mechanics you were working with at one of our GM dealerships? If so, we're happy to follow up on any diagnostics they've done. Please email us at socialmedia@gm.com with more information (including your name and contact information, the last 8 digits of your VIN and mileage, a summary of the situation, and the name of your dealership).
Sarah, GM Customer Service
