From your post, it looks as though you're already working with Customer Assistance. I want to apologize if that process has further frustrated you! Did you start that process with us via email or by calling the Customer Assistance Center?
Sarah, GM Customer Service
a non-GM person performed the replacement and since the service occurred 2 months after the deadline for the Special Coverage Adjustment 07099 had expired and even though I had not surpassed the 150,000 miles no consideration could be extended for reimbursement. The Special Coverage Adjustment stated that service had to be performed within 10 years vehicle was placed into service or 150,000 miles whichever came first by GM dealer. Therefore if anyone has a problem with the SES light staying on it would be to your advantage to check and see if this letter was sent to you. I am very disappointed with GM and that they would not give any consideration to this problem.
I also went through 4 batteries within 3 years because of an electrical drain. Many things were done that I can't remember and didn't help. Finally the speedometer started going wacky. The battery drain as well as the speedometer was fixed by having the dash nodule replaced. I'm sure that is not what it its called but it is the unit behind the dash that has all the gauges. We had to have two put in as the first replacement was just as defective as the original. The fourth new battery was destroyed by the replaced unit. Of course there was no compensation for the battery, they actually made noises about charging us for the second replacement.
This was over a year ago and we haven't had any other electrical problems. Keeping fingers crossed!!!!
Pretty sure we will never buy another Chevy. Dealership repair shops around here are a nightmare to deal with.
LP
My Bro-in-Laws 2004 Trailblazer has started doing the same thing. After reading about all the causes, I'm going for the battery flip-switch which attached to the battery. Has anyone got a legal solution to this ?
Hi! I have a 2005 Trailbazer that recently started having issues with the dash lights-I believe it is a sensor because they will not turn on when I start the car in the dark. Everything works, just no lights. They will however, go on when I start the car in the daylight hours. Anyone have this issue and what part do I need to fix this?
Thanks in advance
Thank You
I'm sorry to hear of your current experience with the Trailblazer. We would like to look into this concern further for you. Can you please send us a private message including your VIN, current mileage, contact information and the name of the dealership you visited? I look forward to your response and working with you.
Marlea W.
GM Customer Care
