I think inasmuch as this issue spans several model years, there IS a problem.
I’ve had the recall work done. The noise seems to be “minimized” at the suspect speeds. But, it appears to be showing up at higher speeds (maybe I’m just overly tuned to noises now .). Also, while it’s only been a gas tanks worth of driving since the work was completed – it’s looking like I’ve lost some MPG (between 1.5 and 2). Perhaps it’ll average out to what it was prior to the work (15.8).
I’m not confident that this recall is the solution. I’m afraid it is a software fix for a hardware problem.
But how can the rest of the thousands of MDX owners be explained for their trouble-less years of driving??
I am still quite convinced that this problem is not widespread.
For those with the faulty transmissions, I would recommend quelling this problem by driving on "D4" gear in the city, and using "D5" only on the highway. Doing so reduces the shifting stress occurring in the 35-40 mph speed zone.
"Never run in 4WD mode, front and rear drive coupled together, except on sustained low traction conditions. Do otherwise and you will soon suffer the consequences."
So here now we have a relatively NEW F/awd system that PRE-EMPTIVELY engages the rear drive, couples the front and rear drives together, each and every time you accelerate from a low speed. Additionally, it also does so in the worse of conditions insofar as driveline component over-stressing is concerned, while turning on a highly tractive surface.
So it should be no surprise to anyone when the driveline components of these F/awd systems begin to fail, PRE-MATURELY FAIL.
Good luck, hope the service bulletin # helps.
Sommerfall - seems like we have the same vehicles. I purchased my 04 MDX as a certified pre-owned with 54k miles on it. I now have 107k.
I called Acura customer service and they said they would help out, but needed to be diagnosed by a dealer. I assumed they may offer to half of their inflated dealer price for a transmission. Still don't want to shell out $2k.
Did you say they paid 100%. Was your MDX a CPO? Do you bring you MDX in for service at the dealer regularly? I do a lot of maintainence myself, so I have brought it back to the dealer since I bought it (I do have receipts of having the transmission fluids changed at a honda dealer though).
Some dealers are scummy. My back up camera died during the cpo and the first dealer I called said to bring it in for "diagnostics". I'd have to pay for that.
The second dealer I called was up front over the phone and said CPO doesn't cover electronics. :mad:
I'm very frustrated right now. About 18 months ago I had to fork out 5200.00 to replace the transmission on my 2003 MDX. It only had about 110k miles on it at the time. Then about 6 months ago I noticed my car was leaking transmission fluid. Took it on to the dealership who ended up doing another 2500.00 worth of work on the transmission and replacing the torque converter. Now here I am today with the same problem yet again. My transmission is leaking. I've already sunk 7,700.00 into this freakin transmission and still it doesnt work. It might not hurt so bad if I still didnt owe 15,000 on it. I'm frustrated and really let down. Anyone have any suggestions??
Anyway, DEMAND that the dealer contact their California office about compensation or find a new dealer. We had out 03 MDX transmission replaced at 108k miles and Acura paid 90% of the cost, but only after I argued with them after the first two offers were too low.
Also, file a complaint with BBB and the government recall agency.
Besides your transmission problems, look out for your two serpentine belt-tensioner pulleys to need replacement after 130k miles. I noticed my serpentine belt wobbling a little at idle on the top idler pulley. Sure enough, the bearings were going bad. I didn't need a whole new tensioner assembly, just the two pulleys that cost about $45 total at the local parts store. It's not an easy job and only recommended for the "mechanically inclined".
If a pulley were to fail, it could sling off the serpentine belt and possibly damage the water pump and/or alternator, not to mention leaving you stranded on the side of the road. Keep in mind, these serpentine belts are only good for 60,000 miles and need periodic replacement. Just because you take your car in for regular oil changes, doesn't mean they inspect and take care of all these little problems.
We'll be buying a Ford after our replacement transmission warranty expires.
I never replaced the back-up camera and as for the transmission I drive in D4 unless I go on the highway.
Does it really cost $5k for a transmission? How much at an independent shop?
There was a recall on that check it out
http://www-odi.nhtsa.dot.gov/acms/docservlet/Artemis/Public/Recalls/2002/V/RCDNN- -02V226-2083.PDF
http://www-odi.nhtsa.dot.gov/acms/documentList.do?docId=02V226&docType=RCL&fromP- ublic=true
Also Google Acura MDX transmission problems and see where it leads. Print the important stuff and take it to the dealer and rub their nose in it.
But also, read the owner manual maintenace schedule and decide if you have a ligitimate complain. Was your vehicle's transmission maintained with the recommended fluid changes? Acura appears to be handling this case-by-case. Depends how long you had it and who services it, and if you'd remain loyal to Acura/Honda.
Please help me officially inform Acura/Honda of THEIR transmission problems by calling 1-800-382-2238 and file a complaint directly with them so that they can no longer pretend a major problem exists AND report the problem to the Transportation agency NHTSA @ 1-888-327-4236 or www.safercar.gov.
Our 78 Honda, 87 & 89 Acuras, and now our 08 Acura and my wife's 06 Pilot we have had no issues. We do service our vehicles according to the specs and I would say my wife of 46 yrs. and myself have driven our vehicles in excess of 150k and then sold them.
And no, I am not connected to Acura/Honda/fill in here dealers and I am not connected to the auto industry except here when I post a few comments.
Our son in Illinois has over 200k and his 96 Honda is still going strong.
I know my experience is different than some, but I had multiple breakdowns with Chryslers, Dodges, and Chevrolets.
I will continue to purchase Hondas and/Acurs in futuro. (Everything I have said, is JMO.)
Good luck to all and stay safe.
jensad
he tried several times to actually get a district manager to talk to me but none were available at the time. but they would call me today or tommorow at the latest.
So there is still some hope.
Right now its been about a week since the TC replacement and I can still hear the transmission shuttering/juttering/rattling problem. Its not as noticeable as previously but you can hear it judder/shutter or maybe its "whistling" around 20mph(slightly, you have to listen for it w/ the radio off but its that same judder/shudder sound, I KNOW I'll have same problem down the road). It seems that the only thing software update did is to move the shutter/problem from 30MPH to 20MPH, thereby just transferring the problem but not completely fixing it per se.
I will be taking my MDX back to the same acura dealer and possibly demanding that they replace the entire transmission because in my eyes/ears, there still is a judder problem(just not as loud). My questions are:
-will Acura warranty transmission warranty FIX this issue permanently or band aid it?
-is there a permanent fix?
-Exactly what does acura trans replacement under warranty do? rebuild tranny? refurbed? remanufactured?
-What is the best way to go back and tell them to replace my transmission? I know they're going to try to hide the problem since I am 2000 miles away from my warranty running out. They're def. going to fight me so I have to be smart about it.
I'd really appreciate any input on this. I am very frustrated and disappointed with this headache. This has been giving me migraines. I can't believe that I am stuck with this car for another 5 years. I have 00 RL with 118k miles which still runs great which is why I bought another acura but what a big mistake that was....never again, I live and learn, once bitten twice shy and eventhough I LOVE Acura's but no more Acura for me after this headache.
Guys, please go here and file a complaint on this issue....I know there are alots of attorneys that are currently laid off and are looking to make money. Anyone know any good class action attorneys?
1) there is no permanent fix...only permanent fix is to get rid of the vehicle entirely
2)PCM software update will not fix the issue
3)replacement TC will go bad again
4)replacement Transmission will go bad again
5)If you are unable to get rid of the vehicle, it seems that the best solution so far is to push for entire transmission and torque converter replacement from Acura and get the 3 year 36k warranty and hope that if it goes bad again, it'll go bad within the warranty period.
6)fo0o0o0o0o0o0ock me!
Today, I was driving and noticed the D5 light started blinking. In reviewing other internet posts, it can mean the transmission is going out or a switch is overheating/failing. I'm not experiencing any other problems so he said that it is probably the switch and that sometimes that happens when a transmission is removed and put back in. So, I took it into the Acura dealership today and they are currently looking into it. On the phone, I said "it wouldn't cost anything to get the switch replaced...right?" He went on to say well if you don't have the extended warranty, then yes. I'm going to fight this one for sure...they had to pull the transmission because of the torque converter recall....I'm sure that is what is causing it....it's just a coincidence that 3 weeks after they worked on the trasmission that now it the D5 light is blinking?
Any suggestions?
Check out the FB page dedicated to this issue.
http://www.facebook.com/#!/pages/Owners-Dealing-with-Acura-MDX-Problems/13568474- 3139321
Wrong.
You could pull the fuses that power the drive to the rear clutches and dramatically extend the life of your transaxle. The other possibility is to put a switch in series with the power to the rear drive clutches and only power them under KNOWN low traction conditions.
I had my TC replaced by dealership under waranty and PCM update. It lessened the shudder but the problem seems to be still there, just not as loud. Took it back week later because it was making minor shudder/whining/whistling noise and complaied to dealer and asked them to replace the entire transmission and they would not. They said they ran diagnostics on the tranny and they could not find nothing wrong. Also they said that its the bearings that's making the noise and its "normal" compared to other vehicles so they will not even open up the tranny to look at it. unreal
So this TC/Tranny problem is Normal guys according to my Acura dealership.
Purchasing a car is overwhelming! It seems like all the cars have reliability issues. Any insight would be greatly appreciated.
Having a $60,000 vehicle that sounds like its got a diesel engine was not part of my plan. Not knowing what's causing the noise for months now has given me a bad view of Acura. I've also been told by the dealer that its normal for the car to sound this way. Yeah so Acura intentionally made a vehicle that knocks.
Thanks...
In an actual 4WD in this situation it would most likely result in "tire hop"/scrubbing as a way to relieve the additional stress. In the early VTM-4 MDX that "give" was obviously provided by the torque converter (lockup clutch?) resulting in widespread premature failures of that component.
Your slight metallic knocking noise may be the result of slippage of whatever component, weakest link, must provide the required "give" when accelerating, even lightly, on a non-slippery, tractive, surface
We learned from bad experiences and I hope the readers don't have to learn the way we did.
jensad
jensad
Has anyone thought of a class action suit? I asked if they planned to do a recall on the transmission and then stated "Since it is not a safety issue, we legally are not liable to"
