Visitor Agreement.
You got me torqued about your 4Runner - that is all great news!!!!!!! I am glad to hear you also love yours - I have the same model as yours as well as the same color. I just love that big hunk!
How easy is it to change the oil? Do you have to take off the skid plate? How many screws??? Explain to me the process - it seems like there is plenty of room underneath to get to the oil pan - but I could not see where the oil filter is. What kind of oil and filter do you use?
I am getting 21 MPG - mostly highway miles. Do you put yours into 4wd???
Rick
My biggest "concern" is about owning an SUV (I LOVE the look of this vehicle!) as I've never had one before. I currently drive a Protege5 (which is great) and have had VW GTI, Integra GSR and Civic in the past. I like the sporty feeling of these cars but have always loved the 4Runners. It's nice to have a commanding view of the road too I'm sure... oh, and the 4wd availability (especially being in Minnesota). I've seen the pics of the new 4Runner and don't really care for it (yes, I know it may look different in person) - and since I've always liked this model I decided to check it out now that they're clearing them out.
Anyone else go from a sporty type car to the 4Runner? I think my biggest concern may be gas mileage - and of course it's going to be lower. I get about 22-25 city with the P5 and 30 on hwy.
With the low interest rate from my credit union (5.49) and this being a "last chance" on this model... just wanted to get some real owners feedback.
Also, what is maintenance really like on a 4wd toyota? Is the 30/60/90k expensive? Is there a timing belt (didn't get ahold of the manual as it wasn't in the glovebox).
I will be making a decision by Friday... thanks for the input!
Let's hope we're not disappointed by the new design...
I use Mobil 1 every 8k. Part of the reason for synthetic is to extend the drain because it is so messy.
You need 6 qts. of oil and a good filter and you're good to go. Also, change the oil drain plug washer or it'll drip.
Good luck,
Jack
1. oil and filter every 3k w/ dino; every 8k with synthetic.
2. every 8-15k, rotate your tires. 8k for most brands; Michelins seem to be able to go 15k.
3. every 30-45k, change the coolant, trans. fluid, brake fluid, PCV valve and air filter. about $200 at a good independent.
4. every 90k change the timing belt, other belts, hoses and plugs. about $400 at a good independent.
Do brakes pads/rotors as required. I have 91k on the originals. Original Michelin tires went 74k.
4 runners are reasonable to work on and are very reliable. Do a little PM and it should go 200-250k.
Happy trails,
Jack
I have also heard SUV's act funny in the rain, well the 4Runner hits a big puddle and drives straight thru it, no hydro planning. Great traction in the rain. My Integra acted funny in the rain.
Maintenance can be expensive, I think a bit more than a small car, especially if you get a 4WD. If your worried about cost, a local independent shop may help on the cost. The timing belt needs replacing at 90,000 miles. I have had no trouble with the 4Runner as of yet.
Also beware, my wife absolutely loves the 4Runner and she drives it a lot and I think she thinks it is hers now. Hope this helps.
Mackabee
Thanks very much for the response - I do not have ramps so it would be difficult for me to change the oil myself. I got my first change at 2,300 at a good place around the corner and it cost $29 bucks (penzoil, with a penzoil filter).
Thanks also for your summary on maint. I have printed it and will keep to it. I unfortiunately, have Bridgestone Duelers - so i think at about 40K I will need a new set of tires. What kind of Michelins do you prefer?
Thanks again for the response.
Rick
Post #2358 from joatmon is accurate, changing the oil is not easy. But this can be done by anyone with some mechanical ability.
Answers To Your Questions:
The Sport Edition has 3 Skid Plates, the front plate has 4 bolts but does not need to be dropped.
The middle plate has 5 bolts, the back 4, all are 12mm.
I'm not sure if you have enough clearance to remove the plates without ramps or jacking. I recommend a pair of 2 1/2 or 3 ton floor jacks. To clear the running boards, I use a short piece of a 4'x4" to place between the jack pods and the frame, you will see what I mean if you do this.
I have never attempted to remove the filter without dropping the plates as joatman does, I will look at this next time I change the oil.
I use Penzoil 5/30 and a Toyota Filter every 3000, I would not go past 5000 miles with any type of oil but that is a personal decision and synthetics are no doubt the best oils. Suggest you buy a filter cap to remove the filter. I purchase filters /gaskets and other parts from www.toyotaguys.com , they are a Toyota dealer and very fair. I have air tools so the removal and replacement of the bolts takes very little time. The front (middle) plate hooks under the front, like everything else, the first time is the hardest. You might ask you dealer if you could watch the mechanic do this the first time, I did and realized that doing it yourself is better!! Takes me about 45 minutes, I really do not mind doing this on my schedule but realize this is not something everyone should do. Oil drain plug is 15mm.
My wife has a new Avalon, I just changed the oil and filter for this car last week and it is easy. The filter is right under the hood, not like the Runner where you have a reach under the bottom left side of the motor.
Use of 4WD? I live in Southern New Jersey so the occasional 6" snow is an event. I decided that with any wet roads I would use this any time of year. This is a great system, you can use on any surface. On a steep gravel hill in Pennsylvania my rear wheels began slipping, pushed the button and no problem, no more ship.
I'm sure the 03 will be a great truck but for the first year it probably will come at a price at or above MSRP.
Good luck with your Runner.
Bob
Can somebody tell me what TRD filter is? I have a 2001 SR-5 4WD Runner; can I get one for it?
The oil filter is best removed by a "strap" wrench. I have "filter caps", but there is not enough clearance above the filter to use them. Again, a 100W trouble light helps, especially the first time or two as you learn your way around. I like to look things over to check for leaks, etc., and the light is a must.
Jack
Steve
Steve
What's the diff between a regular toyota filter and a TRD one?
The TRD Air Filter # 0602 17801 002 will cost $59.46 + $6.95 S&Hndl. What is the website for K&N? Will I really experience a little more horsepower and better MPH?
Yes, they are washable/re-oilable for those who want to save a little bit,but, I am lazy, so , I just will replace:(
http://www.gadgetonline.com/Super.htm
Hope this helps.
Galen
Then we look at what Toyota did. They asked Edmunds to stop showing the pictures, saying there is a information embargo. My guess is that the new 4Runners were there to be seen by the Automobile Press.
So, I am 99.9% sure this is the new 4Runner. So get ready to have "ugly" plastic siding on certain models to show up in the showrooms in a few months. Sorry about that.
However, despite TRD's claims, the general consensus is that those modifications are NEEDED and A MUST if you want to get the full benefit of the SC and if you want your engine to last longer.
I presume that someone has had to look this up before. I can't be the first to ask this question and I probably won't be the last. Any advice would be appreciated and hopefully a location where I may purchase them would be great!
Just picked up a 2002 4Runner Sport this weekend and put over 450 miles on it already
