2008 Chrysler T&C & Dodge Caravan brake life expectancy!
Please share your stories about brake issues you have had with your van here, I have had issues with my 2008 town & country's brakes!!!
malfunctioning and so the dealer is replacing it all at not cost to us! Still, having to replace rotors,brakes and pads (front and rear) for a year old van seems excessive. We've owned several T & C vans (most recent 2001 & 2002 AWD) and didn't have the bake problems at all when they were only a year old. I now know that rotors in new cars can't be 'turned' and so the van owner is going to have to put out more money for repairs earlier.No mass transit is available as we live in a rural area.The cost of operating a van in a area that has small mountains and curvy roads has increased dramatically!
Come on Chrysler! What the heck is going on here?
Anyone else???
Our '94 Dodge Caravan only needed front brake pads every 60,000 miles or so.
But, my 2005 Dodge Dakota PU truck needed the front rotors replaced at the 10,000 mile mark because they were "warped". I replaced the pads at the same time, but the original pads were still good and had hardly been worn at all.
So go figure. Brake pad/rotor life in recent Chrysler products seems to run all over the chart. I have no idea why :confuse:
The steering wheel also tends to have a little vibration feedback as well.
Anybody have any ideas what it might be or experience the same?
On the other hand, I had to replace the front rotors on my 2005 Dakota at the 12,000 mile mark. Pads were fine, but replaced them anyway. That was not acceptable!
See my earlier post, #6.
Anyway, this really is a problem that needs to be addressed. Some of you may be aware of the issues Nissan had with the Titan and Armada when they first came out, what a fiasco THAT was. Tons of vehicles bought back under the lemon law because they couldn't correct the brake issue for good until after the '05 models came out.
Dodge could be in the same situation here if they don't correct the issue soon. The brakes are obviously insufficient for the vehicle and overheat way too easily under normal driving.
1. Rotors running hot (say, after a long run down the side of a mountain), then having to stop with your foot on the brake at a stop light at the bottom. This keeps the pads in contact with the hot rotor and encourages pad material transfer to the rotor.
2. Light weight rotors and other brake componets, which are more prone to overheating.
3. Brake pad material. Some types run hotter than others, and other types are more prone to the pad material transfer phenomenon.
4. I have also read where improperly torqued wheel nuts/bolts could exacerbate the problem by allowing the brakes to run hotter than desired.
5. On the other hand, I do not believe that driving through a puddle of water should cause the problem. If it does, the brakes are woefully inadequate to start with and, if the dealer or manufacturer tells you that, maybe it's time to get the NHTSA involved and push for a recall.
I would look into a good aftermarket rotor instead of going with what the dealer offers, warranty or not.
Also, don't let them screw you over by turning the rotors. That is not a fix and will contribute to more warping now that the material thickness isn't consistent, which means heating and cooling at different rates and this will cause warping.
I agree. I would not turn today's rotors. As you said, they are on the light side to start with, and by removing some material you just make them lighter and more prone to overheating.
So basically 7000 miles ago all the pads and rotors were replaced in my wife's '08 DGC and a couple months ago they started warping again. The local Dodge dealer initially said they wouldn't be covered (17k on the van now), but I basically told them warped rotors after 7k miles under normal driving conditions was unacceptable. A couple of days later we get a call back, they spoke to Chrysler corporate who agreed to do a good will repair if we paid $50 and they covered the rest.
Anyway, on to the juicy bit. The RO says "Install updated rotors and pads per TSB #05-006-08."
I can't find any record of this TSB and didn't see it until the wife got home. I'd like to see the details on this if anyone can find them.
For those of you experiencing repeated brake issues, I'd call up your local dealer of choice and ask them about this TSB.
Two weeks ago, one of my tires was low, so I took the van in to the dealer (my tires are filled with nitrogen). My father is retired and works part-time at the dealership, so they know me there. I brought the van back home, and discovered over the past 2 weeks that the tire had a slow leak, so I took it in today to have it repaired. I was told that yes, there was a nail in the tire and they repaired it. However, they had some distressing news for me... I was informed that I needed new front brakes AND rotors, to the tune of $330. I was shocked. The brake pads were gone and the rotors were scored at only 16,000 miles???
I told them that I was surprised to hear this, because there was no noise, no squeaking, no grinding - no warning whatsoever. And at 16,000 miles?? I would never expect brakes to wear out so quickly. The technician responded that he didn't hear any brake noises either. I was wondering then, what made them check the brakes...? My leaky tire was in the rear, so it wasn't like they found it by accident while changing the tire. They knew they needed to check those front brakes. Sure enough, the technician informed me that they had been having this problem with the brakes on the 2008 minivans with 14-19K miles on them, and that improvements have been made to the new brake pads, so hopefully I would get more mileage out of the new brakes. My brakes were apparently in such bad shape, they didn't let me take the van home.
I was pretty angry about the fact that the brakes wore out so quickly, that there was no warning, and that Chrysler knows this is happening.
People are apparently being told that it's the way they are driving, or else it's normal wear and tear. But I have a personal connection at the dealership, so I was told the truth about it.
I am certainly no expert on vehicles, but it could be a dangerous situation if Chrysler underrated the brakes for its minivans. If I didn't have that leaky tire, and if the technicians didn't take it upon themselves to check the front brakes, then when - and how - would I have discovered that my brakes were worn out??? This is specifically a family vehicle, designed to carry more people!! And why am I having to pay $330 when Chrysler is well aware that this is an existing problem with the vans, and is making changes only to the vans that are brought in??
Is this a recall situation?? I think it at least needs to be addressed before someone with low mileage discovers in traffic with a vanload of children that their brakes are gone. It's most certainly a quality issue, and Chrysler is going to hear about it from me.
Rock Auto
They sell ceramic pads for these vans now, by many different makes.
My tires have also been wearing down earlier than expected. My Dodge GC has the Yokohama tires. After 33K miles, they are ready for a change. Again, the dealer just has blank stares, and Chrysler customer serivce keeps on telling me how the dealer has "High Tech instrumentation" to check these things. I think I need an accountant to tell me that Chrysler went cheap on the OEM wheel parts . . .But then again, I already know that.
I called several national chain stores in the Detroit area, many have or can get in 1 day pads and rotors including Pep Boys, Murrays, NAPA, Advance Auto and Autozone.
My '98 DGC w/ AWD has 213,000 miles on it now with about 48,000 miles on the front brake pads. I rotated the tires on Sunday and noted that the pads are at about 60%.
I'm very disappointed about my chrysler voyager ( the name of town and country in europe ) limited year 2008.
I have a lot of problems : brake have been replaced 5 times from purchase ( 42000 kilometers ),I have a air conditioner leak that caused mushrooms behind the carpet, I have also sometimes a siren like noise when driving and sliding doors problems ( obstacle detection ). Normally the leak is resolved, i hope so but now my garage must change all the floorboard. Biggest problem is the brake. I have done 150 km from replacement for brake and now my wheel is trembling during braking on high speed. I have appointment next week with Chrysler's importation responsible.
Hoping now solutions... what a pity that there are no lemon law in belgium
How to report a safety Complaint
Select how you would like to report your complaint. See below for information regarding this form.
• ONLINE: Select the "Begin Form" button to the right.
• BY PHONE: Call the Hotline, Monday-Friday 8am to 8pm at
(888) 327-4236 , TTY: (800) 424-9153.
________________________________________
Who we are
We are The Office of Defects Investigation (ODI), an office within the National Highway Traffic Safety Administration (NHTSA). ODI conducts defect investigations and administers safety recalls to support the NHTSA's mission to improve safety on our Nation's roadways.
Why your complaint is important
Your complaint information will be entered into NHTSA-ODI's vehicle owner's complaint database and used with other complaints to determine if a safety-related defect trend exists.
• If a safety-related defect exists in a motor vehicle or item of motor vehicle equipment, the manufacturer must provide a remendy at no cost to the owner. Your complaint is the first step in the process.
• We do not have to receive a specific number of complaints before we look into a problem. We gather all available information on a problem. Your complaint is important to us.
How Your complaint is Handled
• Government engineers analyze the problem. If warranted, the Office of Defects Investigation (ODI) will open an investigation to determine if a safety defect trend existis. Some of these investigations result in safety recalls.
• While you may or may not be contacted by a NHTSA-ODI investigator to clarify the information submitted, all reports are reviewed and analyzed for potential defects trends.
Filling out this form
Types of safety complaints
There are four types of safety complaints you can report.
• Vehicles: All motor vehicles -- cars, heavy trucks, RV's, motorcycles, emergency vehicles, buses, etc.
• Tires: All types of tires -- requires you to submit your vehicle information as well.
• Equipment: Non-original equipment -- replacement oil filters, wipers, RV accessories, lights, floor jacks, etc.
• Child Restraint: All types of child restraints --infant seats, booster seats, convertibles, etc.
Time needed to complete
The average time to complete the minimum requirements of this form is eight to ten minutes. It is advised you gather the necessary information for your complaint type before completing the complaint form.
Information needed
Below is a list of items you will need for each type of Complaint. Select the "+" button for the type to see what information you will need.
Vehicles
• Model Year
• Make
• Model
• Component*
• Vehicle Identification Number (VIN) (Optional, but very important)
Found on registration or insurance card.
* Component -- Part or system of concern
Tires
• Tire information needed
o Tire Brand
o Tire Line
o Tire Size, (e.g., P275/75R16 89H)
o Component*
o DOT Number (Tire Identification Number) (Optional, but very important)
• Vehicle information needed
o Model Year
o Make
o Model
o Component*
o Vehicle Identification Number (VIN) (Optional, but very important)
Equipment
• Make
• Model
• Component *
Child Restraints
• Make
• Model Number
• Type (only appears with some makes)
• Date of Manufacture
• Component*
Consumer
We Value Your Privacy
• Name
• Address
• Phone Number
Send your suggestions or comments to webmaster@nhtsa.dot.gov
Why hasn't there been a recall? Why weren't my brakes free if the 2nd design was faulty and so many other T&C owners were coming in EARLY to have their brakes replaced on so low mileage???
We just purchased this Chrysler after owning 2 Toyota Siennas w/o any problems. Years prior, we had a horrible experience owning a Chrysler minivan and stayed away for years but were tempted back w/the 2008. Ha! Lesson learned.
Can't trust Chrysler products to last or trust the Chrysler company to stand behind their product. They're always dodging responsibility.......
We will definitely be using the advice from above poster to register our complaint with the government office (see #31). THIS NEEDS TO BE AN OFFICIAL RECALL!!! Heck, our brakes are squeaking already. Back brakes? Rotars? Sheesh - better keep the wallet open. It is a Chrysler, after all......
Although the brakes wore out sooner than they should have I am scratching my head wondering why the service cost was so high to have them replaced. Did you get an estimate from at least one other shop, like Midas or some independent service center? You do not have to have the work done at a high price dealership since this is not part of the warranty.
I'm not a mechanic but I've replaced pads and rotors on many of my cars. It's not that hard to do and it takes about two hours for me with hand tools and my car on jack stands in the garage. I don't have all the fancy lifts and air tools, etc. I would guess the parts cost for new rotors and pads would run around $200. It would be even less if the rotors just had to be resurfaced (turned) and not replaced. You can usually have that done to them the first time or two when the pads are replaced and there's still plenty of thickness on the rotors. Did all 4 wheels have to be replaced? Usually the fronts go out more quickly than the rears.
Anyway, I'm not suggesting that everyone should do their own brake pad replacing if they are not comfortable with taking on such a task. However, to anyone else who did a search for a similar problem they are having and found this thread I highly recommend getting a second or third opinion at an independent shop, especially since this repair is not covered under the warranty. $900 to have brakes replaced is WAY too high.
Here's a solution to the problem that another owner came up with: Chrysler Brake Problems
I'm sorry for the headaches you've had with this. As a former Chrysler employee I took pride in what I did for them and I tried to help any owners out who needed it. Ironically, I worked as an electrician at the St. Louis minivan plant until they moved everything to Canada last year.
FYI - I wrote a letter to the dealer we bought the van from asking for reimbursement for our costs and the owner called us right away. We have a meeting with him Wednesday, October 7th and hope to have some good news to post here. Keep your fingers crossed.
Please let us know how this turns out. We first heard a squealing noise about 3000 miles ago at 13,500 - it seemed to be coming from everywhere outside and we never would have suspected the brakes at 13k miles. The dealer couldn't find the source.
Just brought the car into the dealer at 16,500 and they tell us its the rear brakes totally gone - metal on metal. Of course NO one would expect you need new brakes at 13 or 16k miles! The sevice tech agreed thjis is a major flaw and they have been seeing this alot on the 2008 T&C's as early as 11k miles and yes its a big problem but they have no recourse. They did give me a 10% discount so it came to $300 for the rears.
The Dealer also said the only way recalls get started is if enough people call (for them to be afraid of a class action or safety lawsuit).
He gave me a number, 800-992-1997 to get started (and we might even get reimbursed, but doubtful).
This is not only infuriating, not to mention dangerous.
.Everyone who has had this problem should call and write a letter!
Would the dealer put the ceramic brakes on your van for you or did you have to use an indie shop? How much more did it cost?
thanks!
http://www-odi.nhtsa.dot.gov/
