My husband gave up on having heat but last month, the radiator blew and it also blew a gasket. When repairing the radiator and gasket, our mechanic checked the water pump and said that it needed replacing because it was completely worn. The total of this bill was close to $1300 and of course the warranty has expired because it is over 100k miles.
My question is this: could a defective water pump have caused the problems with the heater, radiator, and gaskets? The dealer is telling us no and will not defray the cost of this work. Should we pursue this and/or call Jeep? Any recommendations? Please help!! Any suggestions would be much appreciated!
Lori
It sounds more like this was all caused by a leaking head gasket that gradually went from bad to worse (assuming that it was the head gasket that blew).
Thanks, Andy
To establish a fair price in your area just call half a dozen shops. Make sure that the price includes a complete clutch (pressure plate, friction plate, release bearing), and have the transmission and t/c drained and refilled at the same time.
Darlene, it would help if you could define what you mean by "running rough real bad". Did it happen suddenly or did it develop gradually? Was any service or repair work done just beforehand?
It's a little difficult to even attempt an answer without some detailed information. :confuse:
Every time I tell them that, they make me work even longer hours!
Even if it is leaking through the floor in some way, it's hard to imagine that it would allow water in to the extent that you're describing. If they claim a leaking 'crease' to be the cause, make sure to have them show it to you in detail.
P.S. Your description of 'icecycles' hanging from the ceiling conjures up an interesting picture!
If it runs ok when cold but badly when warmed up, that would suggest that it has a fuel/air mixture that's too rich. The most common issue is a faulty O² sensor, though not the only cause by any means. You need to have the on-board computer read for any fault codes (Autozone will do it free), which will give an accurate indication of where the fault lies.
Your symptoms sound nothing like carbon buildup on the valves. However, that diagnosis and the work previously done does indicate a lot about the incompetence of the shop involved. I trust that this isn't a Jeep dealership you're using? (If it is.....SHAME ON THEM!!!).
It does sound as if it's a fuel delivery problem though. Does the pump run? Is the security system wired to the fuel pump relay? Do you have a 'check engine' light or any codes?
I have a 99 TJ. It has a fast clicking sound coming from the flasher unit, under the dash. The sound stops when brake pedal is pushed, but not when just the hand brake is applied. When signaling left or right the sound changes to the normal turn signal click. Changed the flasher relay (or the box that was making the clicking) but that did not fix the problem.
All the lights are working. But one time I notice the front and side marker were alternating. Signal left the left FT. then the LT. side would go, and so on. same when I tried the other side. That went away after a minute or so, and haven't seen it since.
A litte help Fellas? That clicking is driving me crazy.
I have an 04 Unlimited. In cold weather, especially below freezing, it has developed a bad buzz at part throttle. Here's the parameters:
-Sounds like it's coming from the firewall
-Heavy vibrating buzz. Would sound like a quarter on your table when a train goes by, or placing it on a subwoofer.
-Only happens in gear (auto) and only at the first few millimeters of throttle pedal.
-Took the dash top and radio and ac controls out but could not seem to get closer to it. Wonder if it's coming from the engine compartment against the firewall?
-Totally not present once the gas goes farther down or at highway speeds. Repeats going away from every stop.
It's bizarre, and something I'd rather just quickly fix rather than wait all day at the dealer, but it has totally eluded me so far.
I hope someone has an easy fix. So far mine has been to turn the radio up louder.
Yours in Jeep Coolness,
Dave
Assuming the ignition is ok, then the most likely cause is a leaking injector(s) causing an over rich mixture. Next time you try a hot start, hold the gas pedal to the floor while you turn the key (and let it up as soon as the engine fires). If it fires straight away then that was your problem.
What type of lift do you have?
Does anyone know where I can get a replacement bracket that holds the key release button for a 1999 Jeep TJ???? :confuse:
Any help will be appreciated.
"On vehicles equipped with a manual transmission,
a lever is located on the steering column behind the
ignition key lock cylinder. The lever must be operated
to allow rotation of the ignition key lock cylinder. The
lever mechanism is not serviced separately. If repair
is necessary, the steering column assembly must be
replaced."
It's hard to tell what's causing your problem without actually seeing it, but you should be able to remove the lock cylinder and tumblers by drilling it out. You may then be able to fix whatever is causing the lever to jam. A new cylinder can be obtained from the dealer.
A 4" lift on a short wheelbase vehicle like a Wrangler has a much greater effect on the c of g and the handling than it would on a longer vehicle like a full size F250.
Unless you have a specific need for 4" of lift, a 2" - 2 1/2" lift is much more vehicle and user friendly on a Wrangler.
Please let me know how you are progressing on solving your problem.
American car ever again! The Jeep bounces you around. You can't hear the radio.
You can't talk to anyone on a cell. It has no pickup. I've taken the roof off
once- and NEVER AGAIN! It was such a headache to put it back together. It
guzzles gas like crazy. It has no handling. The glove compartment is too small.
You have to hold the gas hose while pumping gas and can't let it sit alone.
Picking up dry cleaning is a pain because there's no where to hang anything. I
have no trunk so when after I play golf I just can't leave my golf clubs in
there. I have had to put patches on my tires four times already and the tires
wear at an abnormal rate. The jeep has no wind aerodynamics- so on an open
highway- you get blown everywhere and I have to struggle to keep this crap on
the road. I'm done with it. Tomorrow I'm trading in for an Ultimate Driving
Machine and can't wait!
