Visitor Agreement.
The best place to take a power feed is from the Power Distribution Center (PDC). It's the black box to the side of the air filter housing, and in front of the battery, containing a bunch of fuses and relays. The easiest way to pick up a connection is to unsnap the cover at the rear of the PDC and use a ring connecter to attach to the incoming feed. Make sure you fit an inline fuse directly after your connection.
You rascal! You should have told us immediately, but you can be forgiven, since you were playin' with that new Jeep.
Yeeeeeeeeeeeeeeeeeehawwwwwwwwwwwwwwww!!!!!!!!!!!!
PICS! PICS! PICS!
Tom
Have you hugged your Jeep today?
Oh yeah, still hangin'in there on the smokin' thing. Just that one accidental puff in the last three days.
We had an interesting trip this morning going to the LA Auto Show. Since I'm not keen on crowds, we wanted to get there early. We left before I5 was opened (yes, the Grapevine was closed this morning) and the road down to it was like a skating rink. We watched a Mecedes spin out (he wasn't going fast) in front of us and another Wrangler going the other way have a bit of a problem getting going (he had stopped to see what the Mercedes was going to do). It sure was strange to be driving alone on a major 4 lane freeway, and my Noble Black Steed had no problems with half-worn Dueller AT tires on.
I was somewhat disappointed in the LA Auto Show this year. Most of the new cars were sports cars - they didn't have either the extended Wrangler or the diesel Liberty there. They did have the H3, which is cute, but still doesn't hold a candle (at least as far as looks go) to the Wrangler, IMHO.
I removed the soft top (I picked the dual top option and had to remove one of them) today but had a question about the Torx screws. When I put the hard top back on I wasn't sure if there is a particular lb/ft torque I should tighten to... is there? I went with 10 and things are quiet but I'd sure hate to strip a screw this early on.
Also, I'm finding that 2nd gear likes to pop out on its own. It's rare (as in once or twice over the course of the day), but rather worrisome in that I don't want to damage anything. Any ideas on what may be causing it? Doesn't happen in any of the other gears. I'm wondering if the temperature has anything to do with it - it didn't happen on Friday after she was indoors overnight.
Andrew
Don't know what to tell ya about your Jeep jumping out of second gear. I don't remember Thelma Jane ever doing that.
Tom
Thanks for the help!
James
Almost all of the weight is in the back, so, when you lift the top off of the Jeep, be prepared for that.
Be sure that you have disconnected the electrical wire for the rear wiper and defroster and that you have disconnected the rubber hose for the rear window washer, before you try to lift the top off.
Tom
I had to stop several times yesterday and pick up cans and bottles along the trails. Turkey Bay was trashier yesterday than I had seen it in a good while.
I have participated in each of the three clean up days that they have had since I started going to Turkey Bay, and the place seemed to have gotten cleaner each clean up day BEFORE we started our work. The last clean up day, you really had to go looking for trash, and when you found some, it would be an individual can or bottle here and there, and not a concentration of stuff.
I was very pleased by the way things were going until yesterday. It looks like we have taken a step backwards. Oh well, not gonna give up. If I have to spend more time picking up stuff than I spend wheelin', guess that's just the way it will have to be. I HATE LITTER! WHY DO PEOPLE DO THAT?????
Tom
I've got a knocking/rattle noise coming from under the front end of the console when initally under a load(low rpm's 800-1k). It also seems to be more noticeable on bumpy terrain.
It almost sound's like a dive shaft U joint kind of noise. I did some research and found that the transmission mounts are prone to wear out and there is also a TSB on the transfer case shift.I took my dad for a ride last night and the noise went away when we shifted into 4 wheel drive.His famous comment: "All jeeps make noise,wait till it breaks and then you'll find it"!
Here are my thoughts.
Replace tranny mount-relatively easy and inexpensive,plus it has some movement when I yank on it.
Remove front drive shaft and take for a spin-this might tell me if it could be U joints. It has some play in the front drive shaft, a good 1/2 inch rotation possible compared to the rear that has very lttle movement.
Perform the TSB on the transfer shift-also easy.
Am I on the right track? Or am I missing anything?
Any and help would be greatly appreciated.
David
Tom
Thanks again.
David
Thelma Jane clangs something awful from her tail pipe hitting the side of the Kilby skid. I'll get around to doing something about it one of these days. Maybe.
Tom
David - I happened to notice that you bought a '99. I have a '98. By any chance, has the exhaust manifold been changed out yet? If it were after 2000 or 2001 (I can't remember the year) I wouldn't mention it, but since yours is old enough to have the old design, I thought I might bring it up. When mine first started to go it sounded like a rattle when the engine was under load also. It gradually got louder and changed to the classic exhaust leak /no muffler sound. It would be worth checking to see if your exhaust manifold has any cracks in it, and if it is one of the new design.
Also, make sure your ground return is good for both the power and switching circuits. Not just a clean connection, but use a wire that's at least the same size as on the positive side of the circuit.
It has the original exhaust manifold. I didn't even think to check that. I'll make sure that I inspect it as well. I was thinking of adding a Borla exhaust system,header on back. This might be good excuse to do that.
Thanks for the input!!!
David
Yeah, removing the hard top was a bear. I followed the manual so had no issues with the connectors... but given the temperatures outside it all had to be done in the confines of a garage. Not much room to maneouver to say the least. Oh well, now I just need to find a place to store the soft top open (I imagine it's preferable to storing it all folded up?).
Andrew
There could be several causes, but that's not your problem at the moment. Take it back to the dealer and get it fixed under warranty.
Use the warmth of your garage to remove the various connections and drive carefully outside. Then, with more room to maneuver, lift each side up enough to slip in a small length of 2"x1" wood. One piece behind the door opening and one piece under the rear corner on each side. You now have a 1" gap between the top and the body.
Drive carefully back into your garage and easily lift the top as necessary to hook the end of a ratchet strap where necessary.
I've seen a few 97-98 SE's that were asking around $8k or less.
Is the 4cyl any worse on the trails than a 6 cyl? Is the gas mileage any better with the 4 cyl? How much slower is the 4 cyl?
I hope to go out and do some test drives soon but I don't waste my or the salesman's time if I don't have to.
I'll take Buffy in tomorrow about the gear and will update once I hear something.
Andrew
Andrew
The 2.5 is considerably deficient in a comparison of both torque and horsepower.
The 2.5 and 4.0 get similar gas mileage (the 2.5 has to work harder).
I've seen many posts (and know of several people personally) who wished they'd opted for the 4.0 instead of the 2.5.
I've never seen a single post (nor am I acquainted with anyone) who wished they'd opted for the 2.5 instead of the 4.0!!!
Does that help?
David - the OEM (new design) manifold is expensive, so if you are already thinking about aftermarket, do it. The main problem with replacing the manifold is that it can be labor intensive - the bolts break easily. There was a TSB out for the '98s about the bolts (not on the manifold itself, just the bolts) - you might check that out. Good luck if that turns out to be your problem.
Out on the trails, the 4.0 has no advantage over the 2.5, since you are just crawling along in 4 WD Lo Range anyway. Even if you are climbing, the gear reduction the T-case gives you in 4 Lo is a great equalizer, making the 2.5 plenty strong enough for the purpose.
Also, they are fine around town, as has been said.
It's out on the highway where they are not adequate in my book. This is especially true in mountainous or hilly country. The four bangers are geared lower than the 4.0 L equipped Jeeps, but this does not begin to compensate for the difference in HP and Torque.
Definitely drive one of each before making up your mind to buy an SE.
Hey, an SE is a WHOLE lot better than no Jeep! And, if highway driving isn't much of a factor, the four will do nicely.
Tom
That would be the best idea. Make sure to drive a 4.0 for comparison, and as it's an early TJ you're looking for don't test drive a new SE, because the new 2.4 is a totally different engine.
Wast to hard to install in my garage. Make sure you have enough clearance for the back window to open. I made the big mistake of lowering it while my doors were closed. The top scratched the door frames.
I take my hard top off in March used soft top though spring & summer, then hard top in fall & winter.
Drokster u guys have the cold & snow.
It was 72 today in Alabama.
Too warm for January!!
Its NFL Playoffs!! Go Titans!!
Keep Jeepin
BAMA
-twylie
Haven't had this much fun just driving around in a long, long time. Dropped in another 50 Km with Buffy today just tooling around, still grinning. No problems with the gears today either which makes me a happy man!
Andrew
Andrew
I'm sure whatever it is, they will take care of it under warranty. Just keep us posted.
I know the worst part will be having to part with her for a day or two while she is being worked on.
Hope it all turns out well. Please keep us up to date with what's going on.
Tom
P.S. Just found your post describing Ellie's options, and I see that she is an auto. Good luck, Glen. They'll getcha fixed up at the dealership.
I am thinking about hooking the driving lights up to the cigarette lighter (Sorry to mention that word Tom!) Whats everyone think? Will it work OK?
James
As Mac said, it's ok to use this wire for the trigger lead on the fog light relay, but leave the relay (and the high current wires) on the engine side of the firewall if possible.
-twylie
I use a 3 point lift that lifts only by the top of the doors and top of the rear window. Have had two jeeps with it and no problems whatsoever. The best way to go by far.
-Paul
What vendors would you recommend for a sway bar? Mopar? Addco? Other?
-Paul
I know of several hardtops that have been hung from ratchet straps in the way that I described without problems. If having the sides spread was perceived to be a problem, an easy solution would be to support the top on two lengths of 2"x1" with eyebolts on the ends. The ratchet straps would engage the eyebolts, which in turn would prevent any potential sideways movement of the top. Personally, I'd rather do that than hang it from its top edges (although it works for you).
Thanks for the compliment, but I doubt that I'm the most knowlegable here.......... I just post a lot!
I'd say go with a MOPAR sway bar. The Addco and other "performance" bars don't make much sense on a Wrangler in my mind. Poly bushings are the easiest and cheapest route to firm up roll in a vehicle. Since the bar is only under load when cornering, ride is not noticably changed for the worse.
In your neck of the woods, I bet there are plenty of people running the Anti-rock for a front bar, and you can find a stock replacement bar for cheap or free. If you find a stock bar, let me know and I can send you my old stock end links if you decide not to do discos for now.
-twylie
PS - I too think Mac is the most knowledgeable on this board; humble as well!
At the risk of dwelling on a fine point, I considered the fact of the load when on the vehicle as well, but reasoned that a) since the bottoms are bolted to prevent flex, and b) that the sides are vertical and relatively light weight (each side), that certainly the overall design of the top is strong enough to hang from the top.
At any rate, I guess we've determined through experience that either way works fine. The hoist and rack at Quadratec is only about $140 and worth every penny.
and, yes, you are certainly humble.
Even with stock bushings, the ride will be firmer than it is now.
I have never installed zerk fittings so going with the urethane bushings makes me nervous - if only for the notion of having to drill into them to get the zerks installed.
Gotta try it sometime though.
I'm still considering the Addco for my Grand Cherokee. It needs help on the highway.
-Paul
We are due for a fairly heavy snowfall (for us at least) tonight and/or tomorrow AM. Looking forward to some snow time.
Jeep grins in Seattle,
Stephen
*Each* of my cars averages about 30,000 a year.
-Paul
-twylie
Can you get me the contact information on where you got them with them already in there? I guess you still had to drill holes in the sway bar cover to get to the fittings. I can handle that.
If you want to email me, use the mail you sent stuff to previously, if it shouldn't be posted here.
-Paul
1997-03 Front Sway Bar Bushing Set (30mm) 2.5110
1997-03 Rear Sway Bar Bushing Set (16mm) 2.5111
-twylie
I hooked up the fog lights they work really well till I turn them off, then I blow a fuse. Any ideas??
Remember, if you are using the headlight wiring, you may have problems if you are using brighter than standard bulbs.
-Paul
