First based on the poor history these sensors on Colorados and Canyons, it is probably a right front wheel sensor dirty, or adjustment, or occasionally defective.
Rather than throw expensive parts at it like most dealerships will do, I suggest that you try to narrow it down first. I would clear all of the codes and reset the ABS controller. Then the moment you get a new ABS light have the codes checked again. Hopefully this time you will not so many codes to deal with. Also there is a good possibility that after you reset it you may not see the problem again.
To reset all of these simply disconnect the battery for 30 minutes or more (overnight is fine). When reconnecting the battery attach the battery cable and immediately tighten it again. The computers (ABS, PCM and BCM) do not like the power flickering off and on, so connect the cable once and do not let it bounce around during reconnection.
If it is a bad sensor it is entirely possible the is is just dirty or out of adjustment. Most dealerships will not tell you this as they make more money replacing it. Clean the sensor and pick up with brake cleaner. Then tap slightly in on the sensor to make sure it is seated all the way. That is usually all that is wrong with these.
If it turns out to be a bad sensor, the sensor is available WITHOUT the hub assembly from GM. Replace the sensor WITHOUT the hub. It is a much cheaper repair. Most GM dealerships will tell you that you need a new hub assembly when cleaning or replacing the sensor is all that is needed.
Good Luck
Sarah
GM Customer Service
Sarah
GM Customer Service
The answers to your request:
Ken Overdorf/ KPO/ ...68226297/ don't have a dealer that I can call "your (my) dealer".
I look forward to hearing from Christina. Check Service Bulletin#04-08-57-004A for starters.
Ken
I believe I have found your file in our database using your VIN. Has your address changed since September of 2009 (when you last had a request open with us)? I have opened a new case, and for your records that number is 71-1039872072.
If you would please send us an email verifying your current address and phone number, and if you would please also include your current mileage on the Colorado, we will move forward from there.
Sarah
GM Customer Service
Sarah
GM Customer Service
All the best,
Sarah
GM Customer Service
Since you have advised Colorado owners to take their pickup to a GM/ Chevy dealer to 'look' at the problem, I am curious as to what one should expect from said company.
Is there a recall on the ABS system yet?
If a person decides to take his /her Colorado to a Chevy dealer for this ABS issue (and many others that seem to be universal), what are the agreed arrangements between parties for payment, service, diagnostics and resolution followup? Is the GM company going to step up with integrity or just talk a game?
Ken / KPO
Sorry....
Sarah
GM Customer Service
After expressing the same ABS issues, I replied to your request for my info (please send us an email at the address located in my profile with: your name/Edmunds username, phone and address, the last 8 digits of your VIN and current mileage, and the name of your dealership,etc.), but have not heard from you. What does that mean?
Ken,
KPO
I've been checking my inbox and haven't seen an email from you. I'm sorry about that! Would you mind please resending it to me? Or if you wanted to try sending the information to socialmedia@gm.com, that would work as well. Again, I'm sorry for the delay and am not sure why the email would not go through.
Sarah
GM Customer Service
I have engaged ABS at 55 mph and at 10 mph under panic stops on multiple GM vehicles. I also tow some very heavy trailers with trailer brakes and I use the ABS trigger point on the Colorado ABS to adjust the rear brake controller for maximum effectiveness without locking up the trailer wheels.
I do not know where your 35 mph figure comes from. I googled ABS speed and ABS engagement speed plus several other iterations and found nothing.
From experience I think that ABS engages at all speeds and I can not find anything in writing to disprove this.
Good Luck
I re-sent this to you and "social media":
I look forward to hearing from Christina or Sarah. Check Service Bulletin#04-08-57-004A for starters.
I'll Try Quigley Chevy (Bally, PA) for a dealer.
KPO
Best,
Sarah
GM Customer Service
I did research the problem here before going to the mechanic. I took it to my local shop instead of the dealer. Our local dealer is a rip off or they always come back and say "we couldn't duplicate the problem," which just costs me more money in the end. I think I will buy a Ford next time.
I'm sorry to read about your Colorado's brake concerns and hope that the repair at your local shop goes well.
All the best,
Sarah
GM Customer Service
He then went on to say "Don't worry about it Mam, we'll take care of it when the light stays on". ARRGGHHHH
Now my vehicle is sitting at the Crews Cherolet dealership in Charleston, SC waiting for me to pick it up. Was first quoted $335 to replace the sensor, then called back with a higher quote. Over $600 to replace the hub (bearing) and sensor. Wait a minute...this problem started while the vehicle was under warranty why should I have to pay (just a note, my GM extented warranty ran out 5 months ago). Was given the 800 number to contact GM cust serv ( I have a file number). They got back to me today. Anna (District rep), offered me a $500 credit toward a new car purchase!!! WHAT!!! Are you kidding me!!! She stated their wasn't a known problem with the ABS system and that I was responsible for the repairs. This isn't just burnt out light bulbs, a faulty A/C, or any of the other miscillaneous problems...this is a safety issue.
I'm filing a complaint with The Office of Defects Investigation (ODI), an office within the National Highway Traffic Safety Administration (NHTSA). Here is the link for filing a complaint. https://www-odi.nhtsa.dot.gov/ivoq/ I urge others, please file too
I have repaired several Colorados with the is same problem. Mine had the problem and I just cleaned and adjusted he sensor. If the hub is not making noise then just replace or clean and adjust the sensor.
The problem is GM did not list just the sensor as a repair part, so you had to order the whole hub. In 2006 or 2007 GM came out with a repair part number for just the sensor. That part also fits the 2004. The aftermarket parts suppliers also sell the sensor for about 1/2 of what GM gets.
I understand what you are saying and what you are not saying, since you seem to have the "easy solution" to just clean and adjust the sensor. You obviously also seem to be a GM service tech oriented or just very 'car smart'.
You said, " There is NO known PROBLEM. Your are the first one, etc, etc , etc. If they admit there is a problem then they are on the hook to repair the thousands of other vehicles WITH THE SAME PROBLEM." From that statement I am convinced that there is a PROBLEM, but GM does not want to make it their PROBLEM.
When a person buys a vehicle, they assume(and so does the US DOT) that the vehicle is designed to function safely and consistently until a mechanical part is assumed to have been in service for a realistic length of time and then is considered to be 'worn out' and therefore 'unsafe'. Tires and brake pads or shoes have typically so many miles of " useable life". "A product's service life is its expected lifetime, or the acceptable period of use in service. It is the time that any manufactured item can be expected to be 'serviceable' or supported by its MANUFACTURER."( http://en.wikipedia.org/wiki/Service_life ) This is not a wear and tear senario. These highly important 'parts' should function like the brake shoes even if they get a little dirt on them. You said, "Mine had the problem and I just cleaned and adjusted he sensor." They should not put the owner's life or others on the road, in jeopardy with an unpredictable failure that does NOT stop the vehicle at some unknown time and that is not considered a known"service life". The key here is that this is NOT being supported by the manufacturer and its is a DESIGN FLAW. If it was wear and tear or routime service then GM would take the responcibility and would be informing the customer/owners of such a service life and quote a time or approximate milage that required service should be preformed to maintain safe operation. They ONLY manufacture and sell the vehicle; they don't hold responcibility for the vehicle.
The PROBLEM is again that GM knows there is a PROBLEM and so in 2006 the sensor part was made available separate from the whole hub assembly; probably so they would not have to 'recall' and hold themselves responcible for a design flaw. They just keep making the assembly the same every year and don't bother to redesign it for each new model year. It’s all about money; not the public safety. Chevy Runs Deep (into your pocket). I filed a complaint with Office of Defects Investigation (ODI).
Best,
Sarah
GM Customer Service
Thank you for taking you time to post your concerns and experience. I apologize for the frustrations you have experienced. Please feel free to email me directly with you VIN and I am happy to look into recall information for you.
Christina
GM Customer Service
Mark
Is there a recall yet on this ABS FAULT issue? I have not heard about that from my District Rep. Hasn't there been enough Colorado owners with the same problem?
Many have paid hundreds to a GM dealer and still have the same problem. When a person buys a vehicle, they assume(and so does the US DOT) that the vehicle is designed to function safely and consistently until a mechanical part is assumed to have been in service for a realistic length of time and then is considered to be 'worn out' and therefore 'unsafe'. Tires and brake pads or shoes have typically so many miles of " useable life". "A product's 'service life' is its expected lifetime, or the acceptable period of use in service. It is the time that any manufactured item can be expected to be 'serviceable' or supported by its MANUFACTURER."( http://en.wikipedia.org/wiki/Service_life ) This is not a wear and tear senario. These highly important 'parts' should function like the brake shoes even if they get a little dirt on them. Like Swann11, is GM going to offer an insult of $500 off a new purchase?
I too filed a complaint with Office of Defects Investigation (ODI).
Ken
I apologize, I am unsure why it is not showing up. Please email me at SocialMedia@gm.com. Thank you!
Christina
GM Customer Service
I am sorry to hear that you are having an issue with your Chevrolet Colorado. Recalls are VIN specific and if you would like you can email me at SocialMedia@gm.com with your VIN and current mileage. Each customer and their concerns are handled on a case by case basis, but I would be happy to assist you with your current situation.
Christina
GM Customer Service
GM says directly with employee’s words and indirectly by way of actions or lack of actions:
I’m sorry(GM) that you are having so many issues with your Colorado.
I’m sorry(GM) that your warranty is expired so we (GM) can’t (won’t) help you with your faulty parts failures. We will take your money to blindly replace any and all parts that we can convince you that you ‘need’ to restore your prematurely unreliable GM product to service again.
I’m sorry(GM) that you have no choice to buy another vehicle as a replacement for your unreliable GM product, since the economy is flat and Middle America has no financial resources to dump us. You’re stuck with GM (no other mechanic knows how to fix this junk) and you need to get to work (if you even have a job).
I’m sorry that we (GM) don't back up the products and the parts that we manufacture.
I'm sorry that we (GM) can't and won't support you or any of our other loyal owners of Colorado.
I'm sorry (GM) that your appeal for GM integrity to make good on the many GM manufactured and engineering flaws have fallen on deaf, greedy and self serving ears. I'm sorry to say that although we have told you that these parts and systems are 'wear and tear' (they are really flawed parts) items we will still try to appease you by taking your information and setting up a 'case' to string you along, simply to wear you and your persistence down so you will give up. After all. we don't lose money (we save money), we don't jeopardize our life (it's your life[nobody has died yet, so it’s not important] and vehicle not ours)and we don't lose our time or piece of mind with the mechanical/ electrical FAILURES and down time.
I’m sorry we (GM) just took your money when we sold you the vehicle, but had no intention of backing the product.
I’m sorry (GM) that the American tax payers gave us billions for the ‘Bailout’, but we will go out of business eventually and lay off thousands of our employees while never paying back the debt. (another promise broken by GM)
I'm sorry as an American citizen, that America does not mean 'Quality' anymore.
I'm sorry as an American citizen, that American corporations have sold out the USA to China. (Our national debt went through loans to China and other countries; As of January 2011, foreigners owned $4.45 trillion of U.S. debt)
I’m sorry(GM) that we are only following the USA big corporations philosophy: One nation under greed.
Now, I'm sorry, but we need to tell the world and all of America what is happening to us and GM (and many other corporation) to stop the bleeding before we all suffer a greater loss and become a Chinese territory.
Ken Overdorf
Problem_Complaint: Anti-Lock Brake System on 2006 Colorado
Problem_Description: I have a 2006 Chevy Colorado with 22,300 miles. I purchased the truck 2 years ago when it had 14k miles from McFarland Chevrolet in Maysville, Ky. At 21,900 miles I got an ABS Fault alarm, the alarm cleared once vehicle was turned off and restarted. Researching this problem on the internet, I found I'm not the only one that has this issue. I went to Chevrolet's website and emailed them my concerns. They replied say " Due to the nature of your concern, we would like to continue this communication through telephone. One of our representatives will assist you with the concern within one business day." A phone conversation followed and I was assured the vehicle was safe to operate and if the ABS alarm came on again to let know. The ABS Fault alarm came on the next day and has been doing so almost every time I drive it. I went to Edmunds.com and posted my problem on the forum board. GM customer replied and my vehicle information was sent to them, and to keep them informed on what the dealership found.
McFarland Chevrolet diagnosed the problem as a defective left front speed sensor. I was given an estimate on best & worst case scenario to fix ($320/$700). Technician also told me that they have never had a "best case scenario." He told me that this was a defect in the Colorado's. I told GM customer service that I felt this is a safety/defect issue and that no vehicle with 22k should have this problem and repairs should be no cost to me. I also filed a safety complaint online with the National Highway Traffic Safety Administration (NHTSA). GM Customer Service corresponded with McFarland's a few times and their offer was, Chevrolet would agree to pay for the cost of parts and I would have to pay labor cost. I feel that if they are willing to pay the cost of the parts, then the parts are defective and Chevrolet should consider a recall. I reluctantly accepted their offer and vehicle is scheduled for repair next week. Any help or advice would be appreciated.
His response was:
Yes. By all means keep a copy of all your receipts and credit card statements showing what you've paid for this. Given what you've said it seems as if there should be a recall of some sort and that you would be entitled to be reimbursed.
Back on the subject of the ABS problems, has anyone else noticed that the ABS faults subside when warmer weather arrives? That's what my '05 does. In the winter, I'll get a fault warning once a week or so but in the warmer months I'll see one maybe once a month. Weird.
Otherwise I really love my Colorado. All I've done to it in 55,000 miles are oil changes, a set of tires and a cooling system flush. Only one dealer visit under warranty for minor problems. That's it. Nice vehicle except for the ABS thing, which I've decided to ignore until it goes out completely. Good luck.
