GMC Sierra/Chevy Silverado 2500 & 3500 - II
The company I work for has a bunch of 2500 ext LB's with the 350 and 3.73 gears. We don't really need any more power, but if we can get it without giving up mileage, we would take it.
GM is not paying much attention to the market for these trucks. Why did they stop making the 2500 LD ext cab LB? The 6.0 with 3.73 in the LD with the 5 speed is what I want.
Hitch placement is crucial to successful fifth-wheel trailering. If it is attached behind the rear axle, overload will likely occur there, with no load on the front axle. The result may be some loss of vehicle control. The placement should be 0-6 inches forward of the rear axle, with three inches ideal. Staying well behind the cab is also required so as not to cause cab-to-trailer interference, which may limit turning radius.
I'd like to hear some opinions or experiences concerning waxing the Truck. Should I do it right away or let it "cure" for a while? Also, what kind of wax? Good ole turtle wax or something else?
www.zainobros.com
Jim
Mike L
young and inexperianced seeking performance info as well
....I don't pull a lot...but haul quite a bit.
I pulled a 28 foot trailer for a friend....it pulled very good..but if I did it on a regular basis or long term....I'd want the 454 or new 8.1.....not that it can't handle it...but the 454/8.1 would be a lot more comfort
Good Luck
- Tim
What are the gas/fuel mileages that you are see with a 2500 series, 4.10 rear end?
Are there any head problems with the duramax diesel engines? I heard there was a problem. But heard that the problem was when GM first started to manufacture the trucks they were not putting enough coolant in the truck, causing them to overheat and causing the engine failure. Is this a true statement and do they have the problem fixed?
As far as price, I ordered it for $200 over invoice so depending on where you are, $500 over may be a pretty good deal.
Hope this helps
I have a 3500 with a 454 and want a new truck. I pull a 12,000 LB fifth wheeel.
My local dealer said, he couldn't get me a Duramax, however I have found TX dealers who apparently can.
Hunter
- Eric
The Durmax so far has been a very positive experience and lives beyond the expectations that have been set by the media. The engine is extremely quiet for a diesel. You can at freeway speeds carry a conversation with the passengers without having to talk louder than the diesel. I am also very impressed with the amount of low end grunt this thing has. If I need to accelerate from a low speed or a stop the engine can easily provide it without any difficulty. My friend who has a new 2001 Ford F350 with the 7.3 Powerstroke was very impressed with the amount of on hand power.
The Allison is also just as remarkable. It provides quick and smooth shifts and seems to know the best band to be in.
I currenly have 1500 miles on this truck and my best fuel mileage has been 17.9. Hopefully as the miles pour on the mileage will get better. I cannot tell you what the towing mileage will be since I have not done so yet.
Someone mentioned problems with the heads. This is a rumor that is being drummed up by certain diesel groups. The Duramax has been in development and testing for quite a long time. It is not an engine that was thrown together just for the sake of obtaining a diesel. It is GM's last ditch attempt to gain access to this increasing market and is closely monitored by GM. If for some reason an engine does have a defect, it is removed from the customers truck and replaced with a new one. The only one is sent back to the factory and inspected by GM/Isuzu to determine what went wrong. The rumors that are being posted state that heads or this or that is being replaced. I suggest to you that you visit the forum that is located on the diesel page. WWW.THEDIESELPAGE.COM These guys know what they are talking about and can answer your questions or concerns about these rumors. Also there is information on towing and fuel mileage. You can also check out WWW.TRAILERLIFE.COM this magazine did a big article on the new 8.1 and Duramax HD trucks. They provide insight on how it performed towing 15K lbs. It also gave information on the towing mileage for both the gasser and the diesel. If you can find a reprint of the magazine article, I think you will be quite pleased with what they said about the new Duramax and the 8.1.
I chose the Duramax/Allison based upon research and talking to fellow campers who tow heavy trailers. I could of went with the gasser and problably would of enjoyed it just as much as the diesel. However my truck is also a daily driver in addition to a tow vehicle. I wanted something dependable, fuel savy, tow capable and would also have a high resale value in the years to come. The diesel is certainly different in driving characteristics than a gasser and is definately fun to drive.
My truck is:
2001 GMC 2500HD, Crew Cab (not extended cab) SLT (Onyx black with light pewter leather, short bed, 2 wheel drive with 8.1 liter engine, Allison automatic trans, and 3.73 locking differential.
the dealer is: Vince Whibbs in Pensacola, FL and the VIN: 1GTHC23G11F144525
The procedure as I understand it is that:
"All trucks will leave Flint MI on Royal Candadian Rail which does not have a tracking system. They take them to Cincinnati OH. CSX takes them from there and in our case brings them to Birmingham, AL where they are unloaded and brought by transporter to Pensacola. CSX has a web page twsnetpublic.csx.com that lets you
enter the railcar number and track where it is at.
Once it hits Birmingham and tracking status says ramp off load it is time to call the dealer and tell him to call up there and ask them to get it on the next available transport. That is what I did....and it was delivered 2 days later."
If anyone out there can access the system to identify what rail car the vehicle goes out on I'd really appreciate it.
gulfguy
tomcrain@gulftel.com
fax 334-948-7952
voice 800-372-0484
Tom, I sent you an email with some further details about our two trucks.
Still hopeing for end of the month!
I have a 2500HD CC LS / posi-373 and I mean to tell you it's Truck Heaven. Have 2,000 mi.
on it and if the oceans had bridges I'd be on my way around the world. I researched this truck for 1 year then waited 4 months to take delivery ( worth the wait ). I once owned an old Mercedes touring car , thats how this truck rides. The drive train on this vehicle is all that my research indicated and more. The braking system is remarkable in it's safe stopping ability, for
I live where we get mucho snow and a lot of adverse driving conditions.
I use this truck in my wood business and also travel 50,000/yr ( a lot on highways) but as for hauling , this truck will do the work it was designed to do. Been checking fuel consumption,
getting 17.39 mpg , haven't hauled any heavy loads for any long distance yet.
The plain and simple of it is , buy what you need.
The engine is in fact as quiet as any diesel you'll ever drive and the transmission is a real thinker and compliments the mill like two brother mules.
I gotta go because this is starting to sound like a GM commercial. My Advise :
" BUY THIS TRUCK " .
Just a note, took my 2000 1500 GMC Ext Cab sb 4x4 5.3L 3.73 265 Michelin truck to the national farm machinery show. Drove 400+ miles. Averaged a whopping 13.7 mpg driving 65-72 with dad in the cab. My averages run from 11-14.5 per tank. My 99 with the same setup except not 4 dr got 14-18. If I could get a CC 3/4 with the 8100 and ALLISON and get the same milage or only loose 1 mpg I would do it in a heart beat. The 5.3 doesn't have the torque I like to have. It has plenty of acceleration if you rev it above 4 grand all the time but I like a motor to stay below 3.
Hunter
Ordered my aluminum front bed and tailgate covers, have my stainless stiffening piece of angle iron ready to install on the upper lip of the front bed....
Gotta clean up the old truck, and take the studded tires and wheels off and reinstall the summer firestone specials....
Started on the canadian train system http://ecprod.cn.ca/english/commerce/cartrace/
but had the railcar supplied to me by an employee at one of the GM plants (handle - Pontiac). Somewhere around Chicago it was put on a BNSF railcar and I used that tracking system (using the last 8 digits of VIN) to track it for days across the country. This AM it is being unloaded into a 'car stall' which I guess the next step is truck it up to Flagstaff.
I need a set of take-off wheels for my new 2500HD. Have a set of studded tires to mount on the wheels. Snowmobile trip in two weeks. Hate to mount/dismount the OEM wheels just for a couple of weeks. I'll take any 2500HD takeoffs, painted, chromesteel, or AL. Let me know.
If it ever stops raining for more than one day at a time I'll try to get some pictures. Planning on adding Nerfs and bed rails in a couple of weeks so maybe then I can get some pic's of 'Truckzilla' with the ugly black flares and all.
I have another truck with the 454 for pulling our trailers. The best I ever got empty with the 454 is 13 mpg. With the trailer, 8.5 to 9 mpg.
A few weeks ago, I went to price a replacement for the 96, and found that I can't get a 2500 LD ext cab long box with the 5.3 and 3.73 gears. Then I found I out that I can't get the same truck with the 6.0. Then the dealer tried the 2001 HD ext cab Long box 6.0, I found that I can't get it with the 3.73.
I will probably end up with the 6.0 with 4.10 gears, but am NOT happy about it. I will probably put bigger tires on it to try to get some mileage back. From what I have read, I expect 12-14 MPG with factory tires. Have any of you increased tire size? What size did you go with? How much did it help mileage? Also - will I need to have the truck re-programmed??
I don't need more power in this truck, so I hate to give up the mileage. Its not so much the price of gas as it is the distance between fillups.
Hunter
oh well..
- Tim
I will need to look into this. The last thing I want to do is make bad mileage worse.
Thanks for your help.
I tow a utility trailer with firewood and a 20 ft pleasure boat. I know the Silverado 1500 would work just fine for me, but I hate buying something when for a little more I could get something better. Is the 2500 worth the extra $?
If you look at the various pieces, and what they would cost as options on the 1500, then the 2500 is a bargain. The 6.0L engine would cost $800-1000 more if it were available; the HD trans would cost $1000-1500 if it were available; the heavier duty suspension $200-250; the HD brakes about $4-500; the HD final drives, wheels and tires would run $400-800. Yet the price differential between the two is only about $800. My guess is the commercial competition with Ford 250SD and Dodge 2500s (where brand loyalty isn't as much a factor) helps keep the price of the 2500s down.
I like them both; if I could only have one it would have to be the 2500.
Mike L
99 Silverado 1500 4x4 4.8L 5spd
00 Silverado 2500 4x4 6.0L 5spd
Deadhorse, Alaska 6-6-99
