Chevy Silverado - Continued XVIII
kip
BTW how is your 2500 doing? Or the Tundra... LOL
-Eric
John Lingenfelter is indeed an interesting individual, and like all hot rodders went through the university of many hand grenades to develop the lineage of successes that have been reported by the magazines that are supported by advertising...hmmmmm! think about it...
hey it finally snowed in New England...but then again maybe you saw it on TV...
matthew
http://64.62.57.22/adult_cdn/01048ABAAMgAAAAEDRce1Ibe3SNK.hK2QvvGUr_kyvD .u8zGsvRfr4G5nODglb7BXPco6_BtIdgms/cj_7759.wmv
Take out the blank space & check out the video.
Long time no post! I have relocated to PA and have not had much time to check in.
Here are my two questions.
1. What happened to the TSB website that used to be located at http://www.geocities.com/crackeregg/CKtruck/2001/bulletins.html
2. Has anyone had the steering wheel vibration problem while driving at 65mph? Mine started AFTER getting rid of my Firestones.. But.. the problem is intermittent. Any ideas??? I am going to the dealer soon.
Jim
if your Silverado is a 99 or 00 C1500, there is a TSB on it titled "front end vibration" #00-02-35-004 dated June 2000. I took a glance at it, and it's pretty involved: replacing the steering rack; reinforcing the left rack mount; replacing the lower control arms; and replacing the power steering metering valve.
Hopefully, yours is under warranty. Otherwise, if this is your problem, it sounds very expensive to fix.
ps - this is for the 2WD truck, and it's not all of them, only some with certain VIN's.
Good luck - Mark
However, the following I have no idea what they are...
A31
A95
EVA
FK2
FK3
K68
SLL
VXS
V22
V73
YD3
YD6
YE9
1SZ
6WY
68U
7WY
92D
92I
BC/CC U507F
Okay, that was more than a "few"; but there were 65+ numbers on my RPO sheet! - Mark
http://gm-trucks.com/RPO_index.shtml
Ryan
Any info on the TSB site anyone?
Jim
The person to check with is Bob Prim over on the Pacific-Audio GM forum (http://www.pacific-audio.com/performance-discussion.html). Bob is the "Mirror Man" - you can even buy a full upgrade to the "Denali" outside mirrors (autodimming on the driver's side, auto tilt in reverse, puddle lamps, etc.) from him.
(The ??? I don't have a clue, yet)
A31 Electric Side Door Window
A95 High Back front bucket seat, driver, passenger
EVA ???
FK2 Arm Torsion Bar Adjust Lh
FK3 Arm Torsion Bar Adjust Rh
K68 Generator 105 AMP (I know but that's what GM calls it)
SLL ???
VXS ???
V22 ???
V73 ???
YD3 ???
YD6 ???
YE9 Uplevel Decor
1SZ ???
6WY ???
68U ???
7WY ???
92D ???
92I ???
BC/CC U507F paint code color "U" = upper
if two tone then "L" = lower
Hopes this helps,
matthew
68U=primary color ext medow green (99)
YD6= spring RR base equipment
File In Section: 08 - Body and Accessories
Bulletin No.: 01-08-66-005
Date: June, 2001
INFORMATION
Subject:
Availability of Pickup Box Reinforcement Kits for Toolbox/Rear Window Barrier/Ladder Rack Applications
Models:
1999-2001 Chevrolet and GMC C/K Pickup Models (Silverado and Sierra) With Fleetside Pickup Box (RPO E63)
New pickup box reinforcement kits are available for customers who may want to install a cross toolbox, side box, or a ladder rack system as an accessory.
Important: The reinforcements must be installed before adding a toolbox or ladder rack system. After the reinforcements have been installed, follow the instructions supplied with the toolbox/ladder rack system for installation onto the pickup box.
Use the following service procedure to install the reinforcements. Use the applicable reinforcement kit part number listed below.
Toolbox and Rear Window Barrier Applications Only - Front Reinforcement Installation
Important: The horizontal surfaces of the reinforcements must be flush to the horizontal surface of the pickup box top rail. Use a clamping tool when positioning the reinforcements onto the top rail to ensure flushness to the outer panel.
1. Place the front L-shaped reinforcements into position on the front top of the pickup box. For vehicles equipped with an over the rail bedliner, the bedliner should be removed with the aid of an assistant prior to installing these reinforcements.
2. Mark the holes necessary for drilling.
3. Remove the front reinforcements.
Important: Use a block of wood and/or a drill stop in order to protect the back of the cab while drilling.
4. Drill two 13.5 mm (0.54 in) holes per side into the box section of the front panel.
5. Drill 7.5 mm (0.30 in) holes into the weld flange of the side outer panel.
6. Touch-up the drilled holes as necessary using the information found in the applicable Service Manual and GM Refinish Material Booklet # 4901M-D-2001 (English) or # 4901M-D-F2001 (French).
7. Place the front reinforcements back onto the box, lining up the drilled holes.
8. Install the large shoulder (M8) bolts into the reinforcement and front panel (total of 4) and the small (M6) bolts into the reinforcement and side outer panel (total of 6) with the nuts.
Tighten
^ Tighten the M8 bolts to 25 Nm (18 lb ft).
^ Tighten the M6 bolts to 9 Nm (79 lb in).
9. Remove all metal shavings from the pickup box after installation.
10. Install the bedliner if equipped with the aid of an assistant. The bedliner may need to be trimmed in order to obtain the necessary clearance to the reinforcements.
Ladder Rack Applications Only - Reinforcement Kit Installation
1. Install the LH and RH front L-shaped reinforcements using the procedure above.
2. Remove the LH and RH rear taillamp assemblies. This is necessary to gain access to install the rearmost bolt of the rear reinforcement.
3. Place the LH and RH rear reinforcements into position on the pickup box.
4. Mark the holes necessary for drilling and remove the reinforcements.
6. Touch-up the drilled holes as necessary. Refer to step 6 under Front Reinforcement Installation procedure.
7. Place the rear reinforcements back onto the pickup box.
8. Install the M6 bolts through the reinforcement and side panel with the nuts.
Tighten
Tighten the bolts to 9 Nm (79 lb in).
9. Install the LH and RH rear taillamp assemblies.
10. Place the LH and RH center reinforcement into position on the pickup box.
^ On the 2.4 m (8 ft) long pickup box models, this center reinforcement fits over the existing center stake hole.
^ On the 2 m (6.5 ft) short box models, these center reinforcements are recommended to be installed. The reinforcements should be centered between the front and rear reinforcements on the pickup box.
11. Mark the holes necessary for drilling and remove the brackets.
12. Drill 7.5 mm (0.30 in) holes into the weld flange of the side outer panel.
13. Touch-up the drilled holes as necessary. Refer to step 6 under the Front Reinforcement Installation procedure.
14. Place the center reinforcements back onto the pickup box.
15. Install the M6 bolts through the reinforcement and side panel with the nuts.
Tighten
16. Remove any metal shavings from the pickup box after installation.
Parts Information
Parts are expected to be available 6/22/01 from GMSPO.
* Maximum Equipment Weight Capacities (equipment and cargo)
^ Ladder rack and cargo - 364 kg (800 lb)
^ Cross toolbox and cargo - 182 kg (400 lb)
^ Side boxes and cargo - 159 kg (350 lb) (per side)
* The combined weight for all rail-mounted equipment should not exceed 545 kg (1,200 lb).
So if anyone wants to place a toolbox or ladder rack, you had better get these reinforcements as they are REQUIRED.
gm service bulletin # 01-06-01--022 dated sept 2001 although this particular sb is for the 6.0L engine, dealer says it applies to the 5.3,4.3 and 4.8L as well.
subject: information on engine knock on cold start models.. 201-202 chevrolet and gmc c/k p/u and utility models .
some of the above vehicles may exhibit an engine noise that begins in the first several thousand miles of use. the knock noise is most often noticed during initial start up and typically disappears as the engine warms up. the noise is usually more noticeable on the initial startup when the temp's is below 10deg or if the vehicle has not been used for several days. this noise may be casued by an interaction between the piston and the cylinder wall. Gm engineering and analysis of engines returned with this condition, has confirmed that the noise is not detrimental to the performance,reliability, or durability of the engine. the noise does not have any effect on the longevity of any of the engine components.
important: at this time, replacing the engine assembly or pistons will not eliminate this noise.
Bob
-Mark
Of course when I picked up the truck my new oil filter was still there on the console. RO said "use customers oil filter. On console." Doesn't anybody read anymore?
Holy $#!~, I gotta get a new servicing dealer...I really have tried with this guy I bought the truck from!
matthew
OH yea this is a Chevy board, well I think it's time I register my "knock" issue with GM Customer service since dealer stated on last service visit "GM is aware of problem and is working on a fix".
Ray T.
Jim
Kyle
Time for the dealer soon. Maybe I should mention the hunter balancer?
My owner's manual says not to use chains with the P265/75R16 tires "because there's not enough clearance. Use another type of traction device only if its manufacturer recommends it for use on your vehicle and tire size combinations and...If you do find traction devices that will fit, install them on the rear tires. Don't use chains on the tires of the front axle."
I called my local dealer who referred me to Les Scwhab tire. Les Scwhab was hesitant to recommend anything given the warning in the owners manual.
Has anyone had a problem using tire chains with the P265/75R16 tires? Does an alternative "type of traction device" exist?
Appreciate any input available.
Have had em over a yr now (13K miles +) and i made no modification to make em fit. Put em on and drove off.
As long as i keep the air pressure in a 4 tires the same truck drives fine. If one side has less air pressure i can definitly tell.
Anyone here have that option? How does it ride?
Hans
Pathomp: Save your money, the aftermarket intakes are bogus and do nothing to increase horsepower as they would have you believe, they look cool but that's about it for functionality. Get the GM High capacity filter and install it in the stock airbox if you think you need different and provided there is no difference in the airbox design between the two different filters (I doubt it). As TXYANK stated without a dino test you'll never know but my experience with these aftermarkets does'nt warrant the expense.
Now a turbo or supercharger would be a different story.
Ray T.
Yea a few months ago but the reason wasnt because of rubbing or anything it was just done to make "it look level". GF also wanted me to do it cause she didnt like the nose dive look
75v
From the "hate the Flares king!!"
LOL
- Tim
Its flare envy hahah
-- Don
