Tom: You and I ordered our jeeps about the same time. I was at Culinary School in upstate NY.....
Rubicon express is really the only other one I would consider.
There are spacer lifts with longer shocks available for about $200 or so, but don't address track bar adjustments or anything like that.
-Paul
-Paul
As for aggressive tires for onroad, perhaps the Bridgestone Dueler tires would work for you. We put some on our Grand Cherokee (2000 WJ) and they did quite well on the icy mountain roads back in California.
-Paul
If you went with 33's, I'd regear to 4.56. 4.88 for the 35's. But you also need to consider axle strength. The D35 rear axle can really only handle 33's reliably at the most. Even then, I'd put in the stronger alloy shafts (which is EXACTLY what I have in my TJ, along with an ARB selectable locker).
With stock gears and 33's, about the only road you could hit would be the strip on a Saturday night. Acceleration will be dangerously slow.
You're in Vegas - it is not like it is that far to Bryce Canyon or Moab.
Here's my OME, with the JKS body lift installed so you can see what it is like. They work just fine offroad and my onroad ride is BETTER than it was when I got the TJ.
And that height is with armored bumpers, winch, rocker armor, rear armor, and a 33" spare on the back.
-Paul
I have been out of town for a few days and missed your check-in.
Hang around more, it just might get fun again. Lot of people can use your help.
Are you driving out west? If so are you coming by the Chicago area?
Guess we won't have to elect a new Mayor.
Terry
Well, I don't know about the "Mayor" business, since I have been gone so long. I think you may have had several mayors around here during my long absence. When's the next election? Maybe I will throw my hat in the ring.
I'll be flying out West, Terry, not driving.
Good to hear from you, my friend!
Still NOT smokin'! Been four and a half years now. You were a big help when I needed some encouragement... might have blown it, if not for you.
Tomster
Have you hugged your Jeep today?
I remember your Jeep came in with a tan hardtop instead of a black one. You ended up keeping the tan one, I believe?
Did you trade that Jeep for another one? You said you have a 2002 Jeep, and mine is an 01. I thought we DID order about the same time, like you said???
Seems like maybe I remember that you did trade your Jeep for one with a 4.0L??? Wasn't that first one a four banger?
Stick around, Rich, OK? I'll try to check in at least a couple times a week around here myself.
Tom
Your experience with the OME was very helpful, but I think I would have gone that route anyway.
Good Lord, NOBODY has anything bad to say about the OME lift. I honestly cannot remember ever seeing a negative post about them. I have seen hundreds of posts in favor of the OME lifts.
Tom
You up for a possible TB run next weekend (6/21)?
Belltom and peeps are going and if I can find a way to trailer my TJ up there with the Avalanche, we'll (wife, son, and me) likely camp and hang out with them for a couple of days.
-Paul
Plenty. You will be much better off finding an OEM unit from a 2001 or older Wrangler or else going the aftermarket route.
First off, welcome back! You were alot of help when I first got my Wrangler Unlimited back in 2005..
Anyhow, I ended up getting a Rubicon Express 2" lift, with spacers and shocks. They aren't installed yet, still waiting to make an appt. with a local mechanic near me. I don't have the tools, time, or experience to do it on my own. I'm going with 32" BFG AT's once the lift is installed. I'm considering the black Cragar wheels, we'll see. When I get all this done I'll try and post a before/after picture..
- Karl
Good deal. Nothing wrong with spacer lifts, especially if you are not looking for major improvements in off road capability. A lift kit with longer springs would give you more articulation for off roading, but if you do only very mild off roading, they would not be necessary, and a spacer lift would do very nicely.
Thanks for the welcome back.
Tomster
Tom
Great looking Jeep!!! Thanks for the Help! I'm a little concerned about having the gears changed. I don't know if I can afford to do that right now, with all of the $$ I'm dropping on lift, tires & wheels. Do I need to do it right away? How much "power" am I going to loose by not changing the gearing? Will it really affect the power that much? Would it b elike going from a 4.0l to a 2.5 4 cyclinder?
Tom:
Great memory! I did order mine with a Tan top, but it came with a black top..... It was a 4 banger, so I traded it in on a 02 Sport. EXACTLY the way I ordered the 1st one, except I had every factory option they had put into it at the time... I wish I would have waited 2 years and got a Unlimited Rubi, but who knew then.... I have driven all over the counrty in my 02. From Vegas I moved to Pittsburgh, then to Hoboken then to Brooklyn, and now back to Las Vegas.. It's been my daily driver for over 6 years and still runs great! Its starting to leak a bit of oil, but nothing too major... I have thought about trading it in on a 4 door JK as i like the new look and 4 doors. But with the price of gas constantlly going up, I have chose to keep it, lift it, put on bigger tires and drive it as my daily driver one more year. Then get a small car to drive to work and to the store. i'll keep my Jeep as a weekend driver.
Hope all is well... Great to hear from you again! I promise to keep in touch more regularly!
Rich
Wow! Great to be back in touch with you again!
You have certainly gotten around in the last few years. I guess you must be the "Galloping Gourmet... Chef?"
You are talking about going to 33s, right? Do you currently have the 3.73 gear ratio for your axles? If so, I would NOT automatically regear without first having driven the Jeep a while after the 33s go on.
Yes, there will be some loss in acceleration, but you might very well decide that it is not a big deal, since you do have the 4.0 L engine and will still have decent power.
Regearing is a major expense and MUST be done by someone who has experience and who will stand behind his work.
What might happen is that you will need to stay in fourth gear when you are cruising around at about 40 MPH instead of shifting up to fifth gear. Not a biggie. (I'm assuming you have the five speed manual tranny...can't remember if you said you have an auto or a five speed.)
Paul might have been thinking that you had the four banger when he was suggesting that you regear. Paul does have a four banger and regearing is definitely called for with the four banger.
Now, if you have the 3.07 gearing, then you might really need to regear. I would still drive it a while first to see if you can live with it, though.
Tom
Not too sure what gears I have. I do have the Auto with a Dana 44 in the rear. Other than that, I would have to check out my window sticker to see if it states what gears I have...
As for the lift - I am having someone install it as I don't have the time/tools/experience for be doing that type of work on my jeep.
Yeah - I have moved alot in the last 7 years, like 7 times in 7 years.... Not fun!
Talk to you later!
Richard
If you have the Dana 44 rear end, then you should have the 3.73 gear ratio. Did you get the AAS package from the factory? That package is a killer deal that would have gotten you the Canyon wheels, Dana 44 with 3.73 gear ratio, and 30" tires for about $850.00.
I'm going to guess that after driving the Jeep with the 33s on it with your current gearing, you will decide that the loss of acceleration is not bad enough to warrant the expense of regearing.
If you DO regear, make sure that the person doing the work is someone who has lots of experience in that kind of work and who will guarantee his work in writing. Setting gears is a real art, and not just anyone can do it.
Tomster
That is the package that I got. i also have the limited slip differencial - not too sure if that will affect anything or not.... Once I get the 33s, I'm going t odrive it for a while to see how much, if any, power is lost....
Richard
There WILL be SOME power loss. That is just a matter of physics.
Going to a larger tire has the same effect as if you had changed your gearing to a higher ratio (lower numerically). If you are now on 30" tires now and go to 33" tires, you are effectively changing your gearing from 3.73 to 3.36. (Ten percent up on tire diameter equals ten percent down on gear ratio number.) Many Jeeps came from the factory with 3.07 gearing, so even with your 33" tires, you will have a lower gear (higher number) than many Jeeps.
Will it have the same accleration as you have now? No. Will the acceleration be as good as the Jeeps that came out with the 3.07 rear ends? Yes.
The limited slip feature does not come into play with respect to gear ratio.
Hope I haven't confused you.
Tomster
P.S.
Guess I should have added that I plan to go to 33s for my next set of tires on Thelma Jane, and I have NO plans to regear.
Why is no one posting?
Tomster
It runs in spurts. Hang around.
Terrry
I am having a company called 4 Wheel Parts here in Las Vegas do the work. They are a national chain and have a great reputation in LV for working on Jeeps. I have been talking to a few people and they were telling me that you can get GREAT deals on Tires & Wheels on the internet. They get drop shipped to your house and the tires are mounted and balanced on the wheels. Pretty much bold on and go. Has anyone went this route? If so, tell me about your experences.. Both good and bad. If the savings is better this may be a good option.....
Richard
Tom
I still drop by occasionally, mainly to this original forum.
Paul has things pretty well covered, but I still pick an easy one to answer now and then.
Glad to hear you're continuing not to smoke; I'm sure it's still a day at a time. Good job!
Still putting miles on both the Jeep and the AMG. :shades:
Great to hear from you!
Nope, actually I NEVER, not for one second, crave a cigarette. I would have never believed I could enjoy this degree of freedom back when I was struggling so bad, but it has happened. I guess it's just like I never smoked. It took about a year and a half to get COMPLETELY free, like I am now, but it was WORTH IT. I don't mean I struggled real bad for a year and a half, just saying that's when I realized that I was not having ANY craves any more.
Stick around, Mac! I'll try to do the same.
Tom
How ya, been, Old Tex? It seems so natural to see a post by you. I have been away too long. I think I'm going to stick around for a while and renew old friendships. Hope you will be here, too.
Tom
-Paul
Have you checked out Ted Wiens in Las Vegas? Check out their website or go by and talk to Collin or one of the other guys in the shop.
Sorry that I did not reply to your warm welcome. I didn't mean to ignore you, but I read a lot of posts when I first got back here and forgot to reply to yours. (I'm OLD.)
I was just reviewing some recent posts and discovered that I had not replied to you.
Thanks for the welcome.
Tom
Congrats on that new Jeep!
What username were you posting with when you were talking to Bama and me several years ago?
I'm working my way back on posts, and I saw yours. I'm very happy that you got a Jeep after wanting one for a long time.
Tom
HAHA. Good one!
I have been doing good. Not much wheeling, just getting around at my deer lease. I am glad to see you and the others back.
I would like to trade someone who has a similar condition in flame red, set of full steel hard doors with roll up windows and would be willing to pay cash for the difference. I am open to negoitiations on how much depending on condition.
Thanks in advance!
It might have been need a rubi or some such variation ... i was pretty excited then and even more excited now that i have one ...
I need to get a soft top for it ... some different rims and tires ... (anyone used the Dick Cepek Rims?)
WOrking good as my daily driver and weekend toy! My kids love it and i am thinking about taking my dog with me too sometime! I need to get a leash though ... for the dog not the kids ...
Anyway I am glad to see some familiar faces!!!
C
They make doggie seatbelts. The are really just harnesses with tether straps that buckles into the seatbelt receptacles. They work well, and I use one for Henry Louis when we go wheelin', or when we are riding around in the strip mine lands near my house.
Be very careful about leaving a dog on a leash in your Jeep, if you are going to be away from the vehicle for while. He might hang himself.
Tom
-Paul
No problem, I'm OLD too... :P I usually just lurk around here and let the real experts handle the questions.
-Paul
http://www.poisonspydercustoms.com/
-Paul
But I think I'd try craigslist.com too and say "local buyers only" in the ad to try to avoid any complications from selling to someone not in the area.
For a Jeep, I think a sign in the window could work good too. Maybe park it on top of a rock in a parking lot. :shades:
If you are buying another vehicle outright and not financing, you may come out ahead. Otherwise, you may not realize the savings you're expecting.
-Paul
JC
Stop in again in a few years JC when you get your next Jeep (it's a Jeep thang). :shades:
Hey, as long as I am posting, here's a question for everyone: can a vehicle be insured for a maximum number of miles per year, with the rates being MUCH lower for very low mileage limits? That can be done with antique cars, I know, but can it be done for ANY vehice?
I only put about 2000 miles per year on Thelma Jane nowadays. I only drive her when I am going to go "wheelin' " down at KY Lake, and she sits in the garage the rest of the time.
This might be something some of you Jeep buds might want to consider, if it can be done.
Tomster
