Visitor Agreement.
Anyone else notice this?
I mentioned the "rattling" noise it makes (especially when I shut it off), he said not to worry about this either. Something about the exhaust system having to brake in. He said after 10,000 miles it will quit. Anyone one else ever hear of this?
BammaTazz- I asked (like I said I would), it has nothing to do with the trans.
I'm sure you will enjoy your road trip to CO.
I think i would replace the dash speaker 1st..
Will you be doing the installing? If they are definatly get the dash speakers replaced. they are the hardest..The Soundbar speakers are very easy to replace..
Nkelly...I havent noticed in build up on TAZZ...
plus no rattling noise either..got 1400 miles on it now.
Got Jeep!
BamaTazz
I took Ross Allen and Momma for a topless/doorless ride right after sundown, and WOW! What a pleasant, wonderful experience that was!
I hope Thelma never sees that top and those doors again until winter! I have something else to drive now, so I ought to be able to leave her like that all the rest of the summer and just drive the S-10 when there is a chance of rain.
tsjay
Have you hugged your Jeep today?
I learned through other posts here and on other message boards that the 31 x 10.50's are the largest tires that you can go with on a Wrangler with no lift.
They are working just fine on my Thelma Jane. There is no rubbing or anything negative about them at all.
Now, someone please answer my question... when people say that the 31's are the largest tire that can be put on a stock Wrangler, are they talking about for offroading or for ANY kind of use? Sure looks like plenty of room left on my Jeep to go bigger on the tires. But, I don't know what would happen in offroad situations, especially with the sway bars disconnected. I don't offroad anyway, or at least I haven't yet.
So, if a guy is going to stay on pavement, can he go even larger than 31 X 10.50 without a lift?
tsjay
The top you returned, dark tan, was the correct color for the vehicle. However....... it's not a match for the interior and never was. The dash, seat backs, and roll bar covers are all camel, which is a lighter and brighter tan. '97/'98 models used a brighter tan, but it's still not the same as camel. Dark tan is what you would have got if you'd ordered the top with the vehicle from new. Hope this helps.
i'm not really sure on the years...
cj (civilian Jeep) older jeeps...
cj-2...cj-5 cj-7
YJ...have square headlights... 82-95
TJ round headlights...97 to present..
that it I think...
Well looks like Barry is heading my way...
gotta get that top up...Now I can see is TAZZ is water proof..
Got Jeep?
BamaTazz
http://www.geocities.com/bamatazz2001/index.html
http://www.visi.com/~tam/tjstereo.html#frontspkr
for help. I put in Polks all the way around.
So i was wondering is if anyone has used or knows of a good clear tape that i can put there to help protect the sides but wouldn't fry to the paint in 100+ degree weather. I'll want to take it off and replace it occasionally so it'd need to weather well.
Bob
CJ5: '55-'83, even shorter than a Wrangler, with the s-shaped lower doors, round headlights
CJ7: '76-'86, about the same size as a Wrangler, round headlights
YJ: '87-'95, Wranglers with the square headlights. There are no '96 Wranglers.
TJ: '97 to current Wranglers, round headlights and coil springs.
FYI, postal Jeeps are DJs. I still see those around occasionally.
I just lift straight up and then step away. I do have half doors though.
blb3318
Here is a cover you may want to check out
http://www.jeepcovers.com/
The tonneau cover/bikini top/wind breaker may be a good way to go. This setup would not keep all the water out though. You would be able use those when you are driving and you wouldn't have to put the top up if it is raining.
madmax74
I have the same color interior as you. I just went with a black top to match the color of my Jeep. I don't know if that will work for you.
Maybe because the Safari Tops are newer you won't see them as much. I have heard some other people complain about the same problem you had. I like the look of the bikini top better so that is what I have. (and I don't care about my backseat passengers)
Sorry about your scratch. I did the same thing the first time I took the doors off of Thelma.
It sounds like you are talking about applying clear tape to the Jeep itself, but I don't think that should be necessary. I would be afraid of what the tape might do to the paint.
As long as you come up very slowly and perfectly straight with the doors, those hinge bolt threads should not come in contact with the Jeep.
If you feel that you need some protection, however, maybe you could put some electrical tape around the exposed threads before pulling the doors off. You couldn't put it on too thick, I guess, or you wouldn't be able to pull the bolt through the hole in the lower hinge.
I haven't had a problem since I learned my lesson that first time (I wasn't prepared for how heavy those full doors were the first time). I just go real slow and easy, being sure that I am pulling straight up. I get my knee under the bottom of the door to help support part of the weight.
Another little item that you need for "doorless" is a protective strip for the top of the rocker panel, the part you step over to get into the Jeep. Some of my passengers rested the bottom of their shoes on the top of the rocker panel while we were riding around doorless! You can get these things for only about $20 a pair from Q-tec. They go on very easily, and they are called "entry guards," if you want to look them up.
I would take the factory clear plastic strip off of the top of the threshold before installing the entry guards. This might help the adhesive on the new entry guards to stick better.
tsjay
also, I plan to get the canyon wheel package. I figure that'd also make the auto a bit more sluggish.
maybe I just need 2 jeeps ? If I had the money, I seriously would ..........
In my opinion the TJ is a much better vehicle because the suspension is so much more refined and comfortable.
sounds like you just need new pads, unless the jeep is
fairly new ....
(if you really wanna go cheap, I guess you could try a
black magic marker)
fairly new ....
black magic marker)
They have stayed in place very well so far, and they sure do the job as far as giving you a good surface that is not easily marred by people's shoes. They look good too. I highly recommend them.
I took twylie's suggestion and split the adhesive strip that they give you to attach them with into several smaller sections. They only send one strip for each side and suggest that you apply the strips in the center of the entry guard. I cut my strips into four pieces and applied them near either end and two in between.
tsjay
Auto..for me...need the free hand for the "jeep Wave" and for radio controls...
Maunual..is a hassel to me..slow down..clutch..brake...shift..gas...clutch..brake..
sheesh...i like to just drive and go...
just my opinion..
BamaTazz
the up-shift light is distracting, annoying, and illuminating ..at night. But that's about all it is good for. The bulb makes a nice replacement for
the clock. Pull it.
All that light tells you is the government wants you to shift at this point to save gas-optimal shift points As for carbon build-up, yes, you'll have to clean the throttle body every once in awhile,you may need to replace the O2 sensor every 2 or so years...but that engine will go forever if you take care of her. But the carbon, wont go away.
madmax - welcome to the board (I'm behind on the boards lately)! I have the Bestop bikini with the drill style header. As goducks mentioned, it take a couple of minutes to attach, but we have been running the duster unless we have a back seat passenger (rare for us), so the bikini alone is quicker for us than removing the duster and putting up the factory softop. We have run for 2 hours on the highway at 75mph with no excess noise from the bikini. The wind pattern changes with more wind from behind you, but it's great to keep the sun or rain off of your head. Pics and a writeup: http://www.ewylie.com/jeep/mods.htm Feel free to drop me an email if you have any specific questions.
Sandmann - go with the 5 speed. ala Animal Farm... All Jeeps are fun, but some Jeeps (5-speeds) are more fun. One thing to consider on the auto is that your final gearing will be lower (higher RPMs or do I have this backwards...). At 70MPH, the auto will run about 500-750 rpms higher than the manual. This coupled with the auto will hurt your mileage a bit, but Wrangler owners can't and shouldn't worry about such things... The 5 speed is easy to drive and the clutch is light enough that I'm not worried about it getting "old". My commuter and long distance cruiser are both auto's but the Jeep deserves to be driven <grin>.
-twylie
The fun doesn't go away either! This is the first time in my life that I have ever owned a vehicle for several months and not become bored with it.
How about a post in "meet the members" to introduce yourself and give all the details on that new Jeep?
Post some pics too!
Hope you will be a regular and frequent poster.
tsjay
Twylie, thanks for the link to your site! The detailed pictures and descriptions are very informative! I suggest that anyone who hasn't visited your site, do so now!
Twylie, I had previously ordered the Bestop safari top and duster. I returned them since the dark tan didn't match the camel-colored roll bar covers. I also didn't like the way the safari top's rear area flapped especially after a half hour to an hour on the freeway at 65 mph. Sometimes, one of the rear loops loosened completely and the top was flapping all over the place! I don't know why but the rear straps that go over the seat belt post are way too short! Other than that, I had no problems installing the safari top. The no-drill header was installed in about 5 to 10 minutes. Luckily for me, there's just enough ample room to insert the straps between the soundbar and middle roll bar. I have noticed that for every Jeep that I see with a top, 9 out of 10 have the bikini top. I hardly see any with the safari top (maybe due to the poor fit?). Anyways, this is what I'm planning to get from www.performanceproducts.com (15% off if you buy 3 or more Bestop products, I think)
1. no-drill header
2. spice (closer match to camel than dark tan) bikini top
3. spice duster cover
Sorry this is so long. Thanks for reading all the way down here!
madmax
madmax
Anyways, I would like confirmation on an observation of mine (applies to TJs): It seems to me that the fender flares (which are body colored) for the Sahara are wider than the black fender flares for Sport/SE models. I have 30" tires on my Sahara with no lift. The outer edge of the tires are lined up with the outer edge of the fender flares. I've seen a Sport with 30" tires and no lift and the outer edge of the tires go past the edge of the flare, giving the tires a bigger look (which looks cooler to me). Anyone have thoughts about this? Sorry if this sounds so anal, mundane, or what not, but I'm picky!
madmax
Bob
I am selling the tops I just bought about two months ago. Were on the Jeep less than two weeks.
Still new and smell like out of the box. I have a black Bestop Safari bikini, the drill in kind for $55 "channel not included."
and a matching black Bestop Duster deck cover for $60.
Cheaper than quadratec & no tax or shipping, thats were I got them.
I am selling them because I am selling my Jeep to get an older CJ.
email me saenzski@yahoo.com
How do you post a picture in here anyway? I was going to put a picture of ... well, I dont have a name yet, but dont know how.
You have to have the pic stored somewhere on a web site and then type the link to it in the message. They tell you how to do that in that first article.
And, you are very welcome for the info on the entry guards.
tsjay
This business of "it's normal they all do it" is a kin to "don't worry your pretty little head about it" . I ain't that pretty or little.
What do all of you use to wash & detail your jeep?
I've been looking at Meguiar's products.
They seem to have everything I need.
I use Blue Coral car wash..then Maguiar's for detailing..
Let me know...
BamaTazz
