Quick Links
Quick Links
Are you under 40 and think that you might not be able to afford a brand new vehicle when you purchase your next car? If so, a reporter would like to talk to you. Please reach out to [email protected] by 12/16 for more details.
The only mid-size that seems to do everything well, without any interior rattles I might add, is the new 2006 Hyundai Sonata, most built in their brand new plant in Alabama. This is truly a landmark car for Hyundai, and will change the way people look at that company. But, you have to buy the LX with leather to get the power seat - standard on the Camry LE. Technically, you can get the power seat in the Sonata in lower cost models, but try to find one on the lot! Interestingly, the new Sonata has very even panel gaps car-to-car, and apparent excellent build quality. However, I think the Camry LE is still the overall better value, and with its excellent resale, a better investment. I guess we're all looking for the perfect mid-size, and I don't think we'll ever find it. Still haven't bought anything yet, but hopefully will make a decision within the next month.
In my experience, my 2002 has suffered from the seatbelt rattle from time to time and when it is below zero, I have heard a slight creak. (But I creak below zero) Would I like to not have the seat belt rattle when I hear it every month or so? Yep. Do I believe that others have worse rattles? Yep. But I'll tell you, I have put over 70,000 miles in the almost four years I have had it and here are the things done to my car besides oil and fluid changes 1. New brakes 10,000 miles ago. 2. An O2 sensor replaced under warranty last year. 3. When new, a sunroof drain was was damaged (punctured) at assembly because the side airbags. (Toyota sent someone from the factory to solve it and subsequently changed the assembly procedure) 4. New tires.
So that's 2 wear items, 1 assembly flaw and 1 classified as other(the O2). Not bad. Plus if it is like my 1992 Camry that I had for 10 years and 137,000 miles it will stay trouble free and I sold that for 25 percent!!! of what I paid for it 10 years earlier!!! And I had my choice of three people to sell it to at that price. I hope someday that a buyer of a 2006 Sonata can post similar results.
I would hope the people reading these boards realize the true big picture. Your Camry is not going to fall apart. Most people do not have rattles, but all brands of cars can have them.
Just curious - is the rattle in the driver's side pillar or the passenger's side pillar? I had a rattle "in" the passenger's side pillar of my Sonata that I eventually traced to the belt being twisted such that the latch's metal tongue was in contact with the hard plastic covering of the pillar and rattling with nearly every bump in the road. Once I straightened the retractable belt so that the metal latch tongue faced toward the centerline of the car, instant, blissful silence. Might be worth a look in your Camry...
I just purchased a 1997 Toyota Camry XLE and need to get another keyless entry remote. Is there someplace besides a Toyota Dealer that sells these remotes? If so, any information will be helpful.
RLJ50
Door Pillar: You can try this. It may not be the door pillar rattling / crackling at all. I always thought it was the pillar but when they tefloned the door seals most of that noise went away. Now and then though I'd still here what I thought was noise coming from the pillar. It has gotten worse, now I almost constantly here a crackle / rattle at ears height BUT I have determined it is NOT from the pillar. (or at least the current rattle is noiser than the pillar one so I do not hear it)
Try this. While driving, when you hear the noise, raise you left arm, place your elbow against the window and apply pressure to the window outward. When I do this the noise stops. I showed the dealer this and they said that, 'naturally the drivers door sill is worn a bit from the window going up and down' and that 'the window has some play between the inner and outter seal when fully raised' and finally that 'since the car is out of warranty any attempt to correct this would not be covered'. Of course my extended warranty would not cover it either...assuming they had a way to fix it.
I am going to look for some sort of thick slicon goo and try putting it in there. If that fails I may just try another dealer or contact Toyota. Note I get similar noise from the passenger window...it may be the same thing.
Let me know if your is a similar issue, we may be onto something....
my situation is whenever I driving over the bump, my car seems will fall apart, i don't even know where the noise come from, the window , the door or else.
Please keep me posted
Cold_In_town
Yes, the pillar area noise happens at anytime, any speed on any road. For the most part if I press outward on the window it goes away. SO it may not be the pillar at all. Or the Window / door seal noise may be louder than th epillar noise so I do not notice it. If you get a fix please post...you'll be the first.
Redesigned anythings have initial QC bugs.
Seriously, I should try some sort of lube first...then maybe a glass guy!
I don't know what WD-40 is good for, but it isn't this. I use the silicone also for squeaking cart wheels and the occasional sticking lock, and in every case, it solves the problem without the mess that WD-40 tends to leave.
1) Lower your Drivers Window
2) Go outside the car and close the door
3) grab the weather stripping in the upper righ hand corner of the window and carefullt pull it out as much as you can lubing whatever you expose. This is also why I like the spray since I can get the straw in there. I lube heavy the corner and all the way down. I then lube the area where the window sets itself when up. This has quieted the noise a great deal for the last week...but it is not a perfect solution and likely will need to be repeated numerous times. It also may not have anything to do with the pillar rattle BUT what you think is the pillar could be this.
I have felt crammed in and around all driver door weather stripping hoping to indetify the most irratating of all rattles. I can quiet it if I press outward on the drivers window while driving but have yet to determine the exact cause. I am hoping if I find it the delaer can fix it...its been a worsening problem since day one. Of course then they could not hear it and not it a normal wear and tear item. If they won't fix it I'll contact Toyota...I figure I'll try to solve the problem myself first.
Anyone know about this...my dealer won't elaborate, just that it does not apply to my 02 Camry...I'd like the details though!
I have the EXACT same problem on my 2005 Camry at 10,000 miles it has been doing this since I bought it. I have a vibrating rattle that starts once I hit any pavement that isn't perfectly smooth. It appears to be coming from the joint of the two cover pieces over the driver side seatbelt. It is DEFINITELY temperature sensitive. All summer (I'm in Texas) it drove me absolutely freakin' nuts. Now that the weather is cooler in the mornings (mid 60's) it only vibrates occasionally.
Has the forum come up with any good fixes???
Mickey
NCDAD
This may or may not be your problem, but I found this after riding in the back seat of our car, and partially folding the seat down to find out where the noise was coming from - I could put my hand on the torsion bars and the noise went away...voila...
