Pontiac GTO
As far as pictures, they're on a picture hosting site. Can I post links directly to the pictures?
Is there a real spare tire or one of those space saver tires in the trunk?
I am just trying to access, whether, I should run down to the Pontiac dealer.
Don
Just a guess but at only 7 cu ft of trunk space, I'd have to believe its a space saver spare.
Daytime running lamps are standard on most if not all GM vehicles- GTO no exception.
Curious- When your driving the car you cant tell the DRL's are on. So, how is that annoying?
The Four-Speed Automatic Transmission GTO has PN 12497318 4L60E, which, according the GM Goodwrench can only handle no more than 370 lb-ft of gross engine torque. This means more transmission upgrades, than normal for a supercharger on the auto GTO.
GM Goodwrench lists the PN 24221888 4L65-E Automatic Transmission for the power of the LS6-405 HP Corvette engines (induction hardened turbine input shafts, larger intermediate servo, an additional three-four clutch plate). I wonder how much this transmission costs or whether there will be a GM upgrade kit?
Don
Don
The big Pontiac dealer in New England is Paul Masse in Rhode Island. http://www.paulmasse.com shows a Silver/Red/Manual in their inventory. He uses a pricing program, so it shows MSRP and dealer invoice cost, so not sure if they are above MSRP. They show 4 cars.
Here's a few of it coming off the car carrier
http://e.1asphost.com/colt1911/DSC00377.JPG
http://e.1asphost.com/colt1911/DSC00378.JPG
http://e.1asphost.com/colt1911/DSC00379.JPG
Of course, it had a dead battery...
http://e.1asphost.com/colt1911/DSC00380.JPG
Here's some detail shots:
http://e.1asphost.com/colt1911/DSC00381.JPG
http://e.1asphost.com/colt1911/DSC00385.JPG
Naturally the logic of the test differs from real world driving where the 3-4 shift can be made simply by keeping the throttle down and revs up which will (you guessed it) burn more fuel.
Now you know where the phrase "close enough for government work" comes from. :^)
Kinda funny, Yeats said he doubted that anyone would ever write a song about the current ones ala the Beach Boys LOL !
HUD
It rarely applies itself in my 02 Formula yet I still can achieve 29 MPG on the highway. Incredible economy for a large V-8 with 3.42 posi gearing.
Can't wait to test drive a new GTO!!
After driving the car, I can say that it is inspring to drive. Brock, like most old farts, is just stuck in the 60's.
So now, it appears that the local dealers here, are only allocated 1 or 2 GTO's, and they are all sold already. Can't even go on a test drive until mid year?
I don't mind the price, I thought it was fine. Now, I know people already ranted about the lack of a moon-roof, etc. However, I currently have a 98 GTP coupe, which has a moon-roof, dual zone climate control, etc. I looked at a new GTP Comp G, which also has stability control, and side airbags.
That was really the deal breaker for me. I didn't understand how a car that is a step up from the GTP could have less content. Granted, th LS1 is probably worth it
It sucks to be torn between two cars you love so much. Since I kept the GTP, I can always look at the front, and pretend its a GTO
(Hey ruski, what year is your TLS? I got the wife an 03, and was wondering if I have the same tranny issues...)
The website is a little kludgy, once the first set of dealers with your zip code come up, then clear the zip code, enter a city and state, this will allow a larger search area.
There are quite a few cars available, just need to drive a few miles.
Don
I read elsewhere than one was sold for $500 under MSRP... anyone else able to do this yet?
Salesman at my local dealership said he heard they may increase the hp for the 2005 to 405hp... only way this would happen is if they switch to the same LS2 that the 2005 'Vette will get. (Personally I doubt this will happen... I'm sure the LS2 will be "reserved" for the 'Vette for the first couple of years.)
He also mentioned the possibility of a convertible for 2006??? That's the first I've ever heard THAT! Anyone else heard this?? (Where would the top retract to? That space (in the trunk) is already taken by the gas tank!
The seats, both front and back are very comfortable. Getting into the back seat is an experience, one must wait for the seat motor, to slowly move the seat forward. The trick is to get in feet last, get out feet first.
The steering wheel tilt/telescopic is like an Audi. The interior shape is very similar to a late model mustang, but nicer. The parking brake has what looks like a Firebird/70s handle.
Visibility, inside appears to be good.
The control on the door, where window controls or door locks normally go, is only for controlling the side mirrors. The window controls are in the center console. The door locks are activated by the remote, putting the car in gear or if the doors are shut and one pulls up on the physical lock, a switch activates the solenoids for both doors. There are no other access controls to the door locks.
The trunk release is inside the tiny glove box, must be just for gloves. The gas release, I think, was on the dash or center console. The truck is even smaller than I imagined. The spoiler is attached to the rear deck lid, with four T-bolts, about 1/4inch diameter. I forgot to check the spare.
The engine compartment is just big enough to work on the motor, better than a firebird or camaro, but not as good as a mustang. Those funky GTO covers, over the valve covers, appear to be covers for the ignition coils & injectors.
It does have a real mechanical throttle cable connection, instead of the mickey mouse electronic "drive by wire" system, that so many new cars have, these days, where the driver is isolated from the engine, by a computer, with slow & delayed response.
All in all, it's pretty nice, but why is it so long on the outside, with so little space on the inside???
Also the dealer had a stupid DAP sticker with $9900 markup over MSRP, how ridiculous, no reasonable person will pay over MSRP. The dealer says they will get 5 cars total,
Don
2004 GTO auto
Pro - new, cheap to maintain and modify, has warranty. Not flashy, inconspicuous
2004 GTO auto
Con - very small trunk, only two doors, harder to get into. bad freeway gas mileage, only four speed automatic
1999 E55
Pro - has four doors, over twice the trunk size, easier to get into. has five speed automatic, ok freeway mileage.
1999 E55
Con - expensive to maintain and modify, flashy, pretentious, used, no warranty
Latest issue of AMI Auto World has article on the GTO. Did a side bar comparo to the Mustang - 2004 SVT Cobra to be up to equivalent performance.
The Mustang is supercharged and (est) to be 0.3sec faster to 60mph than the GTO... but it runs $2500 MORE than the GTO. I expect the new Stang will likely cost as much, once Ford offers the SVT Cobra in the new skin.
Same cost, same power, same size.
They've put significant time and money to get the GTO out the door. Changine something as small as adding HUD would cause GM to redesign the dash and replace the windshield.
The Corvette is GMs top line performance model. They go out of their way to keep that "pecking order" in line, so I doubt they'd drop the C6 engine in the GTO. Plus, the C5 engine has already been amortized by the General. No need to re-tool the current GTO for a different engine when they can use something that's essentially already paid for.
I do agree that as dealers get some stock, discounting will occur at some point. I wouldn't hold out for an upgrade and/or cheaper MSRP for next years model, however.
If anything, GM has been known to "decontent" future offerings to save cost of the vast majority of their offerings.
I'm 6-3, but wouldn't know if I fit or not; local Pontiac dealer won't let anyone touch their GTO. I told them they might have a bit of a problem selling a car that nobody is allowed to touch...
why would a one-off test car be made on an assembly line? Doesn't make sense to me. i don't even see how it could be done. They stopped the line completely and said, "wait a minute, we gotta put a different engine in this one right here." Nah, sorry, i don't buy it.
By the way, I just saw a commercial for the GTO last night. I'm glad they are starting fairly early. Not quite as early as the new Vette, but not as late as something like the Volvo S60R or RX8 (not comparing the cars, just adverstising strategies).
I'd be surprised if there were any changes more than some different colors offered in subsequent model years....maybe a change to a Delco stereo as opposed to the more costly Blaupunkt ones.
Although, if I wasn't such a car nut I probably wouldn't even have noticed it. Also, the badging is so discreet that if I didn't already recognize the shape, I wouldn't have been able to figure it out either.
One has to wonder if this is supposed to be the reincarnation of the GTO, or an M5 competitor in coupe form!
But, the results were 305 HP and 328 lb-ft of torque at the rear wheels. Assuming 15% drivetrain loss in my 6 speed, that puts it right at 350 HP and 385 lb-ft. The air/fuel mixture got a little lean (about 11.9:1) in the top end so a few minor changes to the computer and I should gain several HP. The torque curve was fairly flat, hitting 300 at about 2250 RPM and holding it above that line until right at about 5252 where the HP and torque lines cross. The extra fuel in the top end will probably pull that part of the line up. The peak came in at just over 4000 RPM. HP peaked at just over 5500.
MODERATOR /ADMINISTRATOR
Review your vehicle
The mustang GT auto is too flashy. and does not have IRS. The mach1 mustang auto has the DOHC motor, but gets a cast crank and redline limited to 5800rpm and is WAY too flashy, plus no IRS. One would need to find a regular hood for a Mach1.
The BIG drawbacks to the GTO are the excessive length, 189 inches, small trunk 7 cu ft, and only a four speed auto (gas guzzler). The inside is a snug fit, especially for a person 73 in tall.
Don
This is the location for the tank in MANY cars. That's how they come up with these "roomy interiors" that they can all brag about.
I have a feeling that is where it is in the Mustang, too, but can't find any info on that right now. It was there on my '66, that's for sure.
Looks? Well, that is personal preference. I saw the 2005 Mustang at the St. Louis auto show. It looked better than the pictures I have seen, but still has a heavy, somewhat truckish look to the front. With all of the crowds around it, though, it was hard to really get a good look at it, as a whole.
If Pontiac was hoping to move a lot of GTO's I think they will be discounting them heavy by late fall/early winter.
Review your vehicle
