Toyota Sienna Maintenance and Repair (2004+)
Does anyone else have this problem? let me know at bjenks@bellsouth.net. We love the van, but are very disappointed in the hitch design.
[1] The correct number to call is 1-800-331-4331 ext.3
[2] The lady I spoke with said there is NO design flaw or mistake. She told me that if someone in the van operates their own personal light, "there must be a reason they want the light on" therefore the system will not override and shut the light off when you shut the van off and exit. No changes are in progress.
I voiced my point of view on the the subject to her and was told my comments would be noted.....I guess in a file that is closed!
With as many lights in this van I really think Toyota should design an auto off option after say 10 minutes.
Is this feature not working?
"I just read in the brochure that the Battery Saving feature is standard on all Sienna's and deactivates personal lights after 30 minutes.
Is this feature not working? "
No, this feature is not working reliably, thus the jumper cables.
Getting to the cold season. Not good.
For those of you reading this that are thinking about buying a Sienna I'd say go for it. This small service issue is absolutely nothing compared to ALL the years of problems I had with my 98 Dodge Caravan.
Read page 154 and 155. It clearly states that (last paragraph on the page 155) the lights will turn off automatically aftr 20min when the key is removed and the door is left opened with the switch at "door" position for 20 minutes or more. but wait..what if the door is closed...hmmnnn damn japaneses...kidding..
I don't have a Sienna, yet, but I do recall the sales guy being confused when I asked about this. I turned on the lights and the off and the rear personal lights remained on. He simply pressed each and they turned off. This happened each time I turned them on then off which tells me something isn't exactly right with this.
Someone should take the time and document how theirs operates and post the results here.
They said that you can tell if lights are inadvertently on when you lock the van, as the ones turned on manually stay on and others go off. The problem I've run into is that I don't lock the van when I park it in the garage.
And the other reason this is a crock is that, if the Sienna's window tint is anything like that on my GCS, it's real hard to see whether the reading lamps are on in a lighted garage (which mine is for several minutes due to time delay on the door opener light). So those reading lights get left on all the time in my van. Fortunately, the power drain is negligible and the van always starts, even in January, in Minnesota.
I would still call my dealer back and find out what the holdup is...
Make: TOYOTA
Model: SIENNA
Year: 2004
Recall Number: 03V291000
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, A PART OF THE FUEL TANK MAY BECOME DAMAGED WHEN CRASHED IN THE INSURANCE INSTITUTE FOR HIGHWAY SAFETY’S 40 MPH FRONTAL OFFSET CRASH TEST CONDITIONS, DUE TO THE SEVERE IMPACT FORCES GENERATED.
Consequence:
IF THE FUEL TANK BECOMES DAMAGED AND FUEL LEAKAGE OCCURS, A FIRE MAY RESULT IN THE PRESENCE OF AN IGNITION SOURCE.
This was in IIHS testing.
This was a big surprise to Toyota because, iirc, they had no leaks in their internal crash testing. They must have convinced the NHTSA that chances of it happening were pretty remote (as suggested by your recall notice) since they didn't immediately try to get the vans off the road.
Any suggestion on what would be the problem.
Larry in New York
I've seen this problem before, but I don't recall the vehicle model(s) involved. I read the SUVs discussions too, so the model could be just about anything. Maybe an Advanced Search will turn something up.
My mail account is marked "public" for an email reply for the programming feature question.
In fact, I am highly suspicious that the same explanation is valid for most of the hesitation-on-cornering complaints posted earlier.
Again, this is just speculation. You might truly have a problem.
The dethrottle delay is selected to give the driver time to sense the event and react by lifting the throttle him/herself. The early versions could be quite frustrating, finding yourself pulling into a line of traffic with no engine response.
I'm wondering if the hesitation folks are reporting isn't the result of the few milliseconds it takes to "retune", reset, the VVTI and intake plenum servomotors with a sudden large movement of the throttle.
I don't know if all the dealerships provide the 1,000 mile check up, but it's free and I figure it couldn't hurt.
(Wheaton, IL)
Getting it to be perfect will be an ever changing quest, especially after changing tires, as different tires of the same size can actually exhibit different diameters.
