Its an allroad, keep it that way.
Thanks for the tip. I called Arnott and thet said "we were waiting for you to call" They offered free replacement parts but no $ towards installation. If they knew the parts were bad why didn't they call me??
The thud is gone with the new parts.
Art65
Was it just the rear suspension that was making the noise?
The fault indicator light is on for the Air Suspension.
On the controls the center indicator lights show the top yellow light on continuously and the green light below it blinking.
I was able to push both the up and down buttons to get into manual mode but nothing happens when trying to adjust it.
Just looking over everything I am thinking the first thing to do is replace the compressor. Looks like it would easy enough to do.
Anyone have any input that I am on the right track or any suggestions on what to do instead of the above?
Any thoughts?
Yesterday and today if it's left to sit for more than a few hours it seems like the front deflates completely - it almost looks as if the car is actually sitting on the two front tires.
Any ideas? Hoping I dont have to spend an arm and a leg but have a feeling I am wrong!
- over a period of a few months on returning to the it would settle on one side or on one corner, then pump itself up and be OK.
- then, following sharp braking, after returning home the back drivers side suspension bag just wouldn't pump up and looked like it was sitting almost on the rim.
- at this point I took it to Audi, they said that the computer had failed and that I needed to replace that first (£600+) then they would see if a bag needed replacing. I said its clearly a bag and not the computer, the diagnostic would say that computer was showing an error because the bag had failed. They said that although I was probably right, they have to work by process of elimination (something that consistently pisses me off about Audi and causes far more expense than is needed). I decided (after some research) that as this point if I wanted to keep my allroad I would either be facing replacement of all four corners, the compressor and most likely the computer as well or go for the Arrnott coil spring replacement set.
- I choose the replacement set as I never need a suspension level higher than 2 (other than for mucking around and having fun) so removing that function wasn't going to be a problem.
- they finally arrived, I had to pay to get them fitted. Immediately I realised that they were too spongy - especially at the back and I had the problem previously mentioned where there would be a loud knock when you went over even a small pothole or bump, the car would bounce at high speeds too.
- So (gutted) I complained to Arrnott and they sent me a new set of more beefed up back units. I again had to pay to get them swopped out. They are much, much better - still a little soft compared with the air springs. I've had them on the car for 2 months now and they feel like they are starting to go a little - they also seem to have developed a knock of their own, but this happens only once unusually the first time you drive it and go around a corner or a hit a bump, then its OK.
- So, to summarise, I thought I was being smart switching to the coil/spring and saving me money (and worry) in the long term, and if the Arrnott conversion kit had been what it says it is, it would have been a smart move. Now I regret it because I have no faith in the units that they have supplied and am just waiting for them to give up or deteriorate - hopefully not when I'm doing 140mph on the motorway though! The feedback on the replacement air springs is that they are good, so if I could do it again I would use these instead and keep the car more original. Also, every now and again when I see an allroad they are always on level 3 and look awesome!
I have a 2005 Allroad with 28,000 miles on it, so not a lot really. I have noticed over the past 3 months when I go over the normal pot holes the left side sounds loose / rattly, I think it is worse on level 3 and not as noticeable at 1, but it might be me. It is fine on smooth or lightly rough roads.
The Air suspension stays at the level I leave it at and does not appear to leak or I do not have any warning lights that are coming on.
Has anyone else had a problem like this.
Thanks for any help.
I will get it checked out, It was in for its MOT a month ago at an Audi garage and I asked them to check it but they said it was OK.
However I do not have a lot of confidence in them as the brakes passed and they missed that it needed new pads and disks.
Only after the purchase I found that the steering was sometimes odd (difficult) during hard turns. Since I remember that the last repair was done in the car repair shop where they replaced the air supension on both front wheels, I intend to drive back on Monday when they reopen to check it out.
This morning when I backed out of my drive way (paved, flat), there was an audible crack followed by metallic scraping sound so I immediately stopped and found out that the steering link, a part of the suspension is mechanically broken off, something totally unexpected out of a quality car that both past inspection and have been serviced in an Audi dealership just last month!
Any of you had this problem before? And what was the main cause?
Any thought or advice how to confront the repair shop who sold me this used car? As mentioned, an important factor is that they worked on the suspension just a week ago before selling the car to me. And I assume this is done after the state inspection.
So I need to sort out two questions:
1. the origin of the rupture of the steering link:
My plan is is show the picture that I took to someone who knows about the problems of the drive train and suspension, for example a local Mavis Tires and ask them how and under which circumstance such a rupture can happen.
On top of that, I could ask the opinion of the head mechanic of an official Audio dealer.
2. Fault responsibility (my main question):
Barring the aspect of the potential and severe injury (I would have been paralyzed in a car accident with the current condition of my spine), who bears the cost of the car repair in this case?
Thanks in advance!
Visiting Host
The 02 allroad you purchased is it silver with the winter package and came with a set of snow tires without the rims also seller said the timing belt was recently replaced? Is the seller's car repair shop near Bedford in Westchester, NY?
I've scoured the web and Audi dealers to find these 3 parts but have come up empty.
Wife drove 100 miles today to get Audi part #4Z7698505, only to find that the intake valve and the pigtails aaren't part of that compressor accessory package.
Any suggestions as to where I may locate these compressor connectors? Thanks in advance for any help.
By way of example; the front end drops as I pull into the garage, in the morning the front end is once again level only to drop once more when the door is opened to retrieve something from the car. No issues observed at the rear end.
Another time on a road trip the front end dropped after 4 hours of driving only to raise again after a short lunch break.
This has happened 4-5 times in the last 30 days, the car has 79,000 miles on it.
An independent Audi shop checked the air bags and could find no leaks or any other faults. Any advice would be welcomed.
I'm wondering if it could be a valve, fitting or a software issue. After reading all these blogs I'm perplexed about how something that's rubber can leak intermittently. It would seem to me that when the suspension is kept on level 2 that it would either leak or not leak. I've not varied the suspension level since the onset of these symptoms. Will take your advice and re-do the test.
You should be fine for a while. On my car the air springs lasted another year after the first symptom.
Thank you for your time.
Many thanks!
matt
I replaced one air bag with an Arnott bag. The replacement failed in about 2 months so I decided to replace the entire air system. I did the exact same thing with my car including the air compressor. I did not disable the air system in the trunk so the electronic stability control is not working properly (cannot be disabled on the dash next to the old up-down buttons).
I experienced the same floating feeling and I think that it can be fixed by disabling the computer in the trunk.
Bests,
Augusto
I waited too long to replace the leaking factory bag so the compressor was tired. The level sensors also were acting up so I opted to get rid of the air system.
Arnott offered to replace the bag but I chose a credit on the suspension replacement kit.
My first replacement kit resulted in clunking coming from rear, which burned out a set of tires in 1k or so.
Arnott replaced both rear shocks and that seems to have fixed the problem.
My only remaining issue is to get the traction control system straigntened out.
Since I have a 2002 the check engine light should not remain on when I unplug the air suspension computer in the trunk.
Arnott has good customer service which makes up for possibly releasing a product before adequate QC/QA is complted. Would have saved me some installation labor, or I could have waited for others to do it first and learned from them.
If I did it again I would go straight to the stiffer replacement suspension from Arnott.
