I own a 2003 Allroad and recently the front right shock has been deflating over night. I can start the car and raise it up (with a few restarts of the engine) but we notice the problem getting worst.
I plan to purchase my replacement parts from Arnott so my question is, Do I purchase 1 replacement front shock or that and the compressor?
The compressor still raises the car, but I do notice it makes some noise when it kicks on.
Also a mechanic within his 3-4K quote, said I need to also replace the "Valve Body" which is only available through Audi and is controlled by the ECM.
would replaceing the whole compressor unit fix this issue as well? What is the Valve Body and should I look to replace it?
I sincerely apprecaite the assistance with this post.
-Eden
peace-out AUDI.
the most high maintenance car i have ever owned. and i only had it for 6 months!
1 Fault Found:
01437 - Control Position not Learned
the fuce is fine, the relay is OK, the compressor work, I dont see any other reason, please help if you have any experiance, with issue like that!
I have a 2005 Allroad with 40,000 miles on it, last year the suspension would drop from level 2 down below 1 where the warning light would flash on the instrument cluster. This would happen within a few hours and was consistent. So when I put soapy water on the front suspension you could see the bubbles and they were replaced.
Now a similar thing is happening so I am wondering if it is the rear, but it is a bit inconsistent and I am not sure.
It only drops from 2 → 1, never below.
The whole car drops down, where before the front was lower.
It can sometimes take an hour and others 4 days, last time it was a few hours all the time.
Do you think it is the rear air bags or could it be something else ?
Any help would be great.
hope that is helpful. i love my audi, and this air system issue is the only really big issue with this car. arnott is a good company.
Thanks for your help.
To fix the problem, I ended up replacing the right front shock. When I came out the the garage one night, the right front was dropped down. I figured replacing that shock would bandade the issue.
As t turns out the car now drives fine on the highway at level 2. Before replacing he shock, we could drive and park over night fine at level 3. The only issue is that when driving you are limited to 50 mph and then a sensor lowers the car if you go over.
If you have the financial means it might make sense to replace both front shocks at the same time. You might get a better deal on labor to do both. I spoke with a mechanic who said you will never have to replace the rear. Because the frog absorb engine weight, those are the only ones that leak.
I have not addressed the ease light kicking on yet. As for now a quick fix is to just shut off and turn the car back on. It will kick on the compressor and get the car lifted again.
I went with Arnott shocks through amazon. Lifetime warranty and cost effective. Although spending about $550 in total, I feel selling the car with its original features is better than swapping it for fixed shocks and no lift system.
With the car running at L2 - place a jackstand under the suspect rear bag side, but just an inch below. This is for your safety. Get under the car(WATCH that hot exhaust!) and spray soapy water all over the rubber bladder. Look for bubbles and listen if the air compressor comes on periodically. If it comes on - it is trying to bring a leaking bag to level. Your only option is to replace.
With the right tools, this can be performed by yourself in under 2 hours.
I own a 2004 allroad and have had suspension problems for the past two years. Started changing compressor,then front suspension 1yr ago and now just recently rear suspension (both with Arnott). I had had figured the problem was the rear suspension and when I changed that it didnt change my problems. Everytime I park the car in a hill the suspension drops. When it's parked on the flat sometimes it falls to below 1 and sometimes not. When I drive and I hit a pot hole, then the air suspension lights are activated. When I try to inflate suspension, the compressor works the suspension get's stiff but all lights continue flashing. I then turn off engine and restart it and we are good to go. THe compressor then stops working. Someimes I can even raise the car to level 2 and sometimes I can't. My mechanic has no idea what the problem is! I dont think its a hardware problem. Can it be a computer problem? thks
I just took my Allroad to the dealer and they said it needs a new air compressor for the suspension and said it would cost $1600 to repair. After looking on the web it seems like you can by the OEM replacement for < $400. The instructions on the web looks like it pretty much plug and play. Does anyone have any experience with this? Do I need the computer after I change it and is the suspension going to go down to the tires when I pull the compressor out?
Thanks in advance for any assistance!!
Thanks in advance.
Trying to figure out if the problem is the compressor or the air bags. Maybe something else. Little faith in the dealer at this point.
I have a 2001 Allroad and love it. I, too, had suspension problems and am able to fix them or get them fixed. What I have found is that you can blame anything or everything associated with the suspension system and you would probably be wrong, unless you targeted the airbags. My experience is that, first and foremost, make certain that none of the airbags, leak at any level, be it 1, 2, 3 or 4. using the soapy water method described by me in an early posting. Once you are totally satisfied that there are no leaks in the airbags and you still have a problem, it becomes a lot easier to isolate the cause. MY feeling is that the electronics are pretty much bullet-proof and the compressor pretty darn reliable. My car has 120k and has no problems. Only the front airbags have been replaced and I would use the Arnott replacements over Audi's anytime.
Not long ago, I had to replace the right front headlight leveling sensor which actually does more than level the headlights - it caused the compressor to unnecessarily cycle. The replacement of that item normalized the suspension. I was able to isolate the problem, but don't remember if the VAG-COM helped me - sorry.
Bottom line: Replace any leaky airbag and your problems will probably disappear. And don't trust even a reliable mechanic to check for airbag leaks - it requires a patience, some time and real concentration to make certain you inspect all surfaces of each airbag with the soapy water at each level with a strong focus on the two front airbags.
Hopes this helps!
I used the Gen I and have had zero problems. If doing it again, I would probably use Gen I again, but I would check out Gen II before making my decision. From my viewpoint, Gen I is a much, much better design than Audi's. If you are handy with tools and working a little on cars, it's a very simple job to replace the airbags yourself - maybe 2 hours with proper jacks. If I remember correctly, only two bolts are involved in the removal process after the wheel is removed, but one of those requires WD40 and some finesse. An impact wrench works great. Once off the car, there are about 7 bolts/nuts to be removed the old airbag and re-installed on the new one. The only problem is a single shaft nut that is impossible to get tightened without an impact wrench because there is no way to hold things without scarring the shaft - forget torque wrench. The re-install is simple, but requires some finesse to get mounting holes aligned to insert bolts. Connect the air and away you go. Best!
Thanks for the tips on doing it myself. Would have tried except hat I became disabled 3 years ago. Getting under the car would not be easy.
I am happy owner of 2003 Allroad. This week my Front Right suspension has sunk completely. When engine running, pump lifts car to almost correct Level. Once engine off, it deflates and sinks completely. I can hear air excaping, so pretty certain its leaking Air.
My question is regarding replacement parts.
My Audi Specilist has lost confidence in Arnotts products, he used to love them.
(They had about 10 in last 12 months, that did not last 18 months, Arnott's weaseled out of honouring lifetime guarantee).
What is the Generation 1 Units mentioned (are these the Arnott's???)
What options are there out there Genuine Audi, Arnott's Gen1????
Regards
Seb
Can anyone suggest an answer to the following. If I park the Allroad in suspension position 3 it stays up for ever. I parked at the airport and a week later it was still up. However if I park it in position 1 or 2 then it goes to the ground and won't come back up. Compressor seems to overheat and cut out. However,if I leave the car overnight it can be raised again to position 3 and don't go much over 40 mph it will stay up for ever. If I drive at 60-70 mph the level goes down to position 1 (flashing) and is accompanied by yellow warning light on the dashboard. If I park overnight it can be once again raised to position 3. Are there different seals within the bag that help it to maintain different levels? Do one of the front bags need to be replaced?? Appreciate any help
No more problems with with air suspension since.. , but the car feels very much different now.
Very soft, very comfortable on bad non paved roads though, only you can't drive fast... Dampers are way too soft to asure good tyre contact.
It can be pretty frustrating, as original Audi dampers are top quality, enabling you to drive very fast even on worst roads (but not so comfortable though...).
Pulling into the parking lot, there was the same exact model car as mine, with the same issue (so I didn't feel like my suspension drop was uncommon). The dealer told me that they would have to replace the two front airbags (at a cost of $2,300). I asked if they could do a diagnostic to see what error codes might come up (as some have suggested on here) but they tried to talk me out of it since I would just be wasting the $129 diagnostic fee. When I asked if there was any way they could check the air hoses, the valve, the compressor, or the sensor they said no, it was the airbags. They also told me that if the compressor was broken, it would be an additional $1,300 AFTER the cost of the front suspension work.
Unhappy with the dealer's response, I went to Broadway Auto Clinic in Albany, NY. They hooked up the computer, ran a diagnostic and came up with a Front Pressure Sensor issue. They simply reset the code, and the front end started to raise up. 15 minutes later and no charge to me, I was driving away with the issue fixed (at least for now). I will continue to monitor the front end (it might be a stuck or faulty valve, or in fact a leak) and will report back.
The mechanic also suggested that if the front drops again and I cannot get to the shop, to disconnect the battery and drain the remaining electricity from the battery (Even though the battery has been disconnected, there will still be a small amount of electricity that is stored in the engine. The easiest way to drain the electricity is to hold down on either the brakes until there is no power left. This will deplete all electrical components of having power, including the car's central computer), then reconnect.
Hopefully this helps some of you out there, and saves your hard earned money from the greedy dealers.
I am hoping that this is the case. Everything else goes on, lifting lights flash and the pump growls and gets frustrated, the car stays down, then I get frustrated and leave.
I will have to reset the computer, yes?
