Do the doors unlock using the individual switches?If so it is probably the master ( Drivers Side) switch. Child lock out?
I am a new and happy '07 Azera Limited owner ... purchased it 10/31 w/ 19 miles on the odometer. As of 11/04, it has 150 miles. It is quiet, accelerates easily and smoothly, handles w/ minimal float around corners. Perhaps it's the seat position, but I feel the driver's side blind spot is sizeable. I'm on the tall side, at 5'7" Other than that, I am very pleased.
My basis for comparison (not all are the same class as the Azera, obviously) includes other cars I've owned: Mitsui 3000GT, Toyota Celica and Solara, Nissan Maxima SE Limited.
As for mileage, more to follow ... I have always gotten exceptional gas mileage, compared to the EPA ratings. And, that's irrespective of manufacturer.
I agree w/ you, CBRTurbo, Hyundai hit a homer w/ this vehicle. Any potential owners, take note: Hyundai is dealing to get these off the lot. I negotiated $1500 under dealer invoice, and full Kelly Blue Book/Edmunds trade-in for mine.
Since when did 5'7" = tall (for a man or a woman)?
JJTEE
not use the air conditioner much.
Just checked the door locks. Back doors lock,
both manually and using the switch.Front doors
will not lock manually or using the switch.This
is from the inside.
Wow! You sure are!!
just sign me....Joe the midget.
That sounds like an utter load of crap.
Is there no end to the nonsense from car dealers?
I believe he told you that, but I don't believe for a second that it's true.
If it were, that would be the end of Hyundai for me as a possibility.
key,inside switch and inside door handles.
Back doors work. They lock from the inside,
using any method.
I am curious though...when did 5'7" become tall?
Can you select presets or select discs on Infiniti system?
If 07 Azera and 07 Grandeur TG(Korean name of Azera) has same funtion of Steerign wheel audio control, you can use preset seek fubtion in Radio pressing seek button short.
Radio: 'Preset Seek' with Short Pressing & 'Channel up/dn' with Long Pressing
Tape: 'AMS up/dn' with Short Pressing & 'FF/REW' with Long Pressing
6 CD: 'Track up/dn' with Short Pressing & 'Disc up/dn' with Long Pressing
http://www.youtube.com/watch?v=q6BdhBkH_lg
Thanks for your reply1
The ability to select presets is a great improvement, as I usually listen to just a few stations when in town. My guess is that most drivers have similar favorite stations.
It appears that from what I have read from those who have upgraded from 06 to 07 switch, this function is unavailable.
Have you made the modification on the 06 to the 07 switch?
I wonder if they made a modification to the audio system to accomodate the extra features or available in the 07,( preset activation) or is it just a change in the switch and wire harness?
My '07 Azera steering wheel feature allows me to switch modes (AM/FM1/FM2/disc) as well as radio stations, disc tracks within a mode. You're right, these are great features!
Can you select or scroll thru presets?
Yes, I can scroll through the presets using the up/down arrow on the steering wheel. Very nice feature, since you can keep your eyes on the road.
Here's to a great day!
Thanks for reply! Thats the feature I really want.
If your dealer is knowledgable about the 06 vs.07 audio systems, perhaps they can tell us why all features can't be duplicated. If the wire harness and head units are same for both years there must be something else that restricts these new features. Software changes and eproms are good guesses, but neverless they are guesses.
Susan
I found the correct phone number and contacted Cliff.
He is a very nice guy, but was unable to help because he says that he has the same problem that many owners have.
The company has not provided dealers with updated information about many models.
He has been attempting to install a radio in a new Elantra ( can you believe the model comes with no radio) and the company can't give him installation kit or wire harness information.
He suggested that maybe the manufacturer of the head unit updated the equipment to provide the additional features, but Hyundai assigned it the same part number.
It is a guess on his part, but he claims that they have done similar things in the past.
Has anyone been able to get any other information?
Mark
Ball Ground, GA
Mark
Ball Ground, GA
Mark
Ball Ground, GA
Mark
Ball Ground, GA
I do have on niggle which has been there since day one. I have problems loading CDs into the 6 disk CD player. It just does not seem to pick them up and slide them in. I thought maybe the problem was just the way I tried to gently slide them in. It has taken some without problems and others on a second or third try. At this time I just don't seem to be able to get any to go in. Anyhow, I will try to get this fixed as a warranty issue.
Anyone else out there with similar problems?
Good to hear.
Does the memory seat function work without key in ignition?
Did they add back "tilt in reverse" rear view mirrors?
Can power pedals be set into memory function?
What brand of tires are they now using?
I thought the power pedals could be set into the memory function, at least that's what the salesman told me when I was looking. My understanding was steering wheel, seat, mirrors and pedals would all be programmed into the memory setting.
Do you have an 07 Azera?
The 06 does not have the ability to program the power pedals into the memory system.
Minor peeves- After or during a rain, when you open the trunk lid, water that has built up behind the tailights tends to drip in mass into the trunk and if you have items in the trunk they get soaked from these edge drippings. The storage drawer under the radio is sized just a bit too small and cannot fully fit a typical CD case. Seems like a terrible waste of space for an obvious use.
This is probably the best value in the large car class and even comes with a cigarette lighter standard.
Damn, this is a GREAT car. I also have had no problems.
My pet peeve would be the visbility of the trip computer info during day light hours. Speedo and Tach are fantasic, but the poor little trip computer between the two doesn't have the same brightness.
I also have had valet parkers who really liked it "Swanky" one called it.
The safety rating along with theft deterrents and the eight air bags kept my insurance cost down also for a new car. My wife enjoys driving this car and she is tough to satisfy.
We drove round-trip from suburban northwest Denver to Santa Fe, Taos and Albuquerque, NM. With two adults and a trunk full of luggage, the car performed well.
The Azera was so road quiet, even with a howling winter wind. It handled very well, on roads that were frequently snowy and icy. My traveling companion, who needs a new car this year, will look closely at the Azera; he fell in love w/ mine!
Happy Driving, everyone!
Susan
Susan,
Never sell that car. Both you and your Azera are blessed.
Continued good luck!
