Visitor Agreement.
Please let me know how to correct it when you find out?
Luke :mad:
according to the owners book the fuse is the same as the radio for the vents.
and becous the cruse works once and awhile I am not shure what to look at
any help would be appreciated.
(tbar1) :confuse: ">
(tbar1) :confuse: ogletbar@yahoo.com
#2 the rear windows aren't working, I press the vent buttons but nothing happens.
Why and what to do ? and # 3 my horn stopped working. why and what to do ? .
however these problems did not happen all at once its just that i came across this site, and figuered might as well kill 3 birds with 1 stone if at all possible. i am mechanically inclined so if you tell me what to do , i should be able to get it corrected.
ABS light on our '97 was on one time, the cause was just low brake fluid.
My van did the same thing and usually in cold weather. Turned out that I had water in my gas and I put some HEAT treatment in with my gas to get the water out of the gas and I don't have that problem.
Hope this helps.
Echo1
is it just one style of intake for those years? 98, 99, 2000.
good luck
You can check the voltage drain by removing the negative terminal and remove fuses and see if you have small spark when touching the terminal to the post, gives you an idea where the drain is, or you can use a test lite as well between the battery post and the negitive terminal and pull one fuse out at a time.
Of course this forum is for "Ford Windstar Problems" so naturally that is what you are going to read about.
How do I tell the dealer I want to have it looked over by a mechanic? or can I send a mechanic there to look at it ?
I see that in the past there were some problems...
what do you all think good price for a good car ... or bad idea?
Thanks !!!
In my case I had to buy the master cylinder besides the brake pressure switch, it cost me $50.00. So I spent $65.23 in total and the problem is fixed.
HELP! Any ideas on what is wrong are greatly appreciated.
If you are in luck than maybe it is only muck which was washed between sensor and sensing ring.
I have a '98 Windstar and just had to replace the CMP (CPM) (?....on board computer module)...My TRAC Control light cme on one day and stayed on for sometime. Shortly after, the ABS light came on and stayed on (dealer checked and found no problem with the either). While it was in the shop for service (the check engine light came on) the maintenance code showed cylender #1 wasn't firing. I had the plugs and wires changed out and the next day, the engine light came on again and the engine began to mis-fire badly. After many hours (and many $) the mechanic discovered that the wiring harness leading into the CMP (CPM?) had been burned and a wire inside the protective coating was burned as well. This fed into the CPM and caused false codes. The CPM was replaced, no difference. The wire was fixed, presto....no more false codes.
Possibly the burn as caused by current arcing from the #1 wire to the harness. They were in very close proximity and the plug wires were in bad shape. Might be worth a look.
Good luck
MarkinOttawa
Trac control & ABS lights came on on my '98 WS. When the engine light finally came on, I decided to have it checked. After many hours and many dollars (long story) it turned out that the wiring harness leading into the CPM (CMP??) had been burned by current arcing from #1 plug wire. Changed plugs & wires and (unfortunately CPM) and no worries since then.
May be worth having it checked.
MarkinOttawa
Is this a common problem with the windstars and if so why has there not been a recall issued?
