Chevrolet Impala: Problems & Solutions
Why is it back at the dealer? Because of the same Intermediate Steering Shaft problem, or something else?
A car is an expensive purchase and it has to bring some enjoyment. If it no longer does that or your confidence has been eroded, then your best bet is to sell it and move on.
Just a piece of advice, that's all.
I have had many repairs done to my car. Since I only have one chevy dealership close me, it sucks.
Anyway I have had the insulators installed on the gas tank, the shim fix for the cradle, a new rack, new center caps, new wheel well inserts, and new front rotors installed by me since the dealership has no clue what quality is. Pending repairs are a left ball joint, right tie rod and a new ISS that will be lubricated via TSB.
This latest repair will be paid by the extended warranty I bought last year.
My advice is if you plan to keep your Impala beyond OEM warranty, buy an extended one!!!
http://www.autowarrantyreviews.org/
I love my Impala and someday we'll have everything replaced with good stuff.
I'm going to find a place to fix the dent, then I'll try the paint stick/langka(?) approach. Unfortunately I'll have to wait for spring for the weather to be good enough to do this. Does anyone have any suggestions on how to protect this area through the rest of winter?
Brad
Rear wheel drive cars can be driven out of situations using throttle to "push" the car out of certain attitudes and the steering returns to neutral more easily.
Front wheel drive cars "suffering from torque steer" must be "driven" out of the same situations. In a hard turn, letting go of the wheel and expecting the car to roll through the turn results in very interesting behavior to say the least, as the car will continue in the "last known direction. IE. sidewalks, curbs, etc.
Sorry to hear about the diagnosis. You can definitely do better going elsewhere.
Hope this helps and GOOD LUCK.
RR
Brad
Steve
I'm removing them for boot and oring replacement, anyway, so it's a good time.
Isn't there some kind of jelly? Naval jelly, or something? I tried navel lint, but that didn't seem to work.
Corrosion - Metal reverting back to its original state.
Once de-rusted, I think I'll just use high temp black enamel. It's only the outside of the caliper. There are no leaks, so no worry about fluid.
Or, I may just coat it with oil or grease, to keep it from rusting again for a while.
Right now, the rust just looks crappy on such an otherwise nice looking car. Although, it's behind the wheel, so not that noticable.
On a similar note, when did painting an ugly mechanical part of a car, such as a brake caliper, bright red become fashionable? Why would someone want to bring attention to it? Are people going to start painting their tie rod ends and mufflers bright red as well?
Nathan, your site really is amazing. Thanks for giving all of us a fantastic source for everything Impala.
Brad
I have a 2001 Impala LS and I wanted to rotate my tires....but I have a small problem.
My wheels have locks on them and I cannot remember if I ever received the lock nuts to take them off. My dealer told me usually Impalas do not have lock nuts on them. They tried all 20 lock nuts that they had, none of them worked. HELP!
Don
Who wants to tell him about the steering shaft? Please form a single line, tallest first.
http://home.hawaii.rr.com/impala/
It was surprusing because the leak was hidden by that huge plastic "beauty" cover that all cars seem to have nowadays. I would recommend others to remove that cover and look for leaks.
Thanks for any input,
Jay
Brian
webbrian@yahoo.com
I am also having some major ISS "clunk" and he commented that it may indeed be the ISS or a cradle shim issue, and that he would check both. That was reassuring. He also related that this was a more COMMON problem than the manifold leak in his service department.
I guess it is all relative.
Sorry I don't buy it.
I always heard that the 3400 V6 (Aluminum head) has a much, much greater tendency for manifol leaks, but the cast iron 3800???
Couldn't find any supporting record logs to that effect. I did searches for 2000 & 2001 Impala as well as other recent GM vehicles equipped with the 3800 in both N/A and Supercharged models...nothing.
So in conclusion, I am afraid your *Mechanic* is full of it and he is obviously lying thru his teeth.
I suggest to get a second opinion from a different mechanic.
Or, he's seen a few of 'em. His definition of "common" may be different from yours. He may see one a week, or one a month, but enough to think it "common". Perhaps, along the lines of the leaky battery condition that a few people have mentioned. Not ISS, Cradle, or Amplifier type of "common", but something that has cropped up from time to time with this engine at that dealership.
It's a model of car, not a member of your family. Why always so protective of it's reputation?
I take issue with the mechanics' comment that all 3800 Series II V6 have manifold leaks...a lie. His comments are not supported by any available data in CR, NHTSA or any other source that tracks reliability.
If that were the case, lots of newer 3800 Series II V6 equipped cars would be piling up in dealer's service bays with manifold intake leaks and other issues.
If he has data that supports his statements, fine, so far they are ludicrous in context.
Get off the line that I am defending the car. If your experience has been less than positive, I symphatize with you but it doesn't mean that everyone's else should be as bad as yours. My first car was very average, this one has been great. Again sorry to hear that your 2001 has been less than perfect. I still contend your dealership has been for the most part the cause of why you soured on your car. You have a bad incompetent dealer, a not so good car and a very unresponsive BBB arbitration board. I don't blame you, trust me.
But, I take issue with "professional" individuals (Or they claim to be) that issue false statements such as this.
If you have data that supports claims on frequent 3800 V6 manifold coolant leaks, please pass it along, I'll be very interested in seeing it.
You have to admit that you've been a little defensive about Impalas. Remember, not too long ago, when you were emphatically swearing that there is no longer an issue with the ISS for 2001 and later Impalas? ;-)
