Chevrolet Impala: Problems & Solutions
I took a '96 Z28 to a chevy dealer after it failed an emissions check with high hydrocarbons (unburnt fuel). They told me there was nothing wrong with the car, but because it was driven so little (8000 miles in 5 years) that it was "all carboned up" and that was why it failed. Of course their solution was the M.O.C. treatment for $167. First of all, I know that the car was NOT "carboned up"... I make sure of that regularly when I drive it!!!
It turned out that the AIR pump had failed, and both of the Catalytic converters had failed from all of the unburnt fuel allowed to build up in them while the motor was warming up. Also the OBD-II system was malfunctioning and not properly monitoring the cats and O2 sensors, so no warnings were ever shown. All of these issues were of course covered by the GM emissions warranty, but all the dealer wanted was to get $167 from me for something that wouldn't even come close to fixing the problem. Of course it WOULD have made them more money than they probably made on all the repairs they actually did have to do on the car.
Put a can of any good brand fuel injector cleaner in your tank maybe once a year, twice a year if you do nothing more than a lot of stop-&-go puttering around town and you'll be fine
But honestly, the Impala's acceleration got more responsive afterwards. The fuel filter was also replaced.
Thanks for the info, dennisw3. I will keep that in mind next time.
I have thought about replacing the pads and plan to do so before Winter.
Usually, using a GOOD injector cleaner like Red Line SI-1 or BG 44K will clean out the injectors. Manually spraying an air intake cleaner into the throttle bottle will clean the intake. And, a GOOD oil additive, such as BG MOA or RF7 or even Marvel Mystery Oil (which, by the way is good at removing carbon, when added to the gas tank), can keep the crankcase clean.
You should always change your oil after using using a good fuel system cleaner. Much of the displaced carbon ends up in the oil.
I have an '01 Impala LS with 32,000+ miles (bought used at 29,000+) build date 1/01. I have read the posts and links regarding an ISS problem. I feel a slight (hard to describe) jolt or maybe a clunk in the steering wheel -when driving. It does not seem related to any particular direction or speed and definitely do not hear anything or feel anything in the brake pedal.
Could this just be normal road feel I am getting? Am I becoming paranoid with all the posts I have read on problems?
Car also had low coolant light come on for 5 seconds when driving ( I have put 3,000 miles on car since getting it). Coolant reservoir bottle was very low. Chevy dealer said the coolant level might have been overlooked when they got the car into the shop. I added a pint of Dex Cool/water mix as per manual. But I have a tough time seeing where the coolant level is due to the bottles position. No coolant on ground and car engine temp did not go up when low coolant light came on.
Any comments?
Had a brief period last year when I smelled coolant in the garage, but never found any leaking. Saw the level was low, and topped it off with Dexcool, but my indicator light never came on. Never had a problem since; hoping it was just a one-time fluke.
I hope my coolant was just low too. Thanks for the reply.
Marty
Marty
Any comments
They gave me a free loaner. I bought the car used with 29000mi on it and the dealer gave me a free loaner (an Olds Intrigue). My last Chevy dealer never did that! What a difference. Now the acid test - will they find the problem and fix it. Keeping my fingers crossed.
I will keep track of both ISS and coolant - If I have further problems I may go to an independent mechanic I know - get his opinion then go to the dealer. I hope the problems are solved as I really like this car and the ride.
I also seem to have a short in my horn. I get a clicking sound when I try to hook up the relay.
I really need to know of a good mechanic in the Belleville NJ area.
I own an Impala 2000 LS with approx. 34K miles. The problem: Several times when driving between northern and southern California, I have found that the car would not shift to the overdrive gear. Perhaps more accurately, it was as if the transmission was "stuck." As a result, I was driving approx. 75mph and the engine was running at 3200rpm (and worrying). I also noticed that this problem seemed to occur when the engine temp was rather high. The problem would seem to go away after a bit -- when the engine temp went down as well.
I did take it to the dealer for this problem once, but they said that they could find nothing wrong. Has anybody heard of such a problem? I skimmed a number of the previous posts, but didn't see anything similar.
Thanks in advance, LH
Has anybody else had a problem with the EGR valve?
BTW, another consequence of a faulty EGR valve is smog test failure if the exhaust gases are not being burned (I don't know how stringent it is up there in Canadia), and rough idling/low speed performance if the gases are getting back into the engine at idle/low speeds (They're only supposed to be recycled at higher speeds).
We do have emission testing (drive clean) in Ontario for cars older than 3 years and less than 20 years. Your vehicle must be tested once every two years if you want to renew your plates. I know the Impala will flunk the Drive Clean test without the EGR, but I don't have to do the test until next May. So the repair isn't -that- urgent.
Thanks again as always, friends!
I was quite surprised to see the recent posts. Just last night I spoke with a friend regarding my smoking at start up and he suggested that perhaps there is coolant leaking into the oil/engine. I figure I would write the possibility here today but it seems that a few others have had the problem already.
First, I missed it in the posts so can someone define the "ISS problem" that is mentioned?
Second can anyone with the oil/coolant problem tell me everything they know about it...ie the signs that it was happening, the way you convinced the dealer to check for it and the eventual fix if one exists?
For those who didn't read my posts about 40 posts back, I have a 2000 LS that smokes at start up after sitting for a few hours. I've been to the service station 3 times and most recently "had words" with the service manager of BELL MOTOR CO. MD after I called and he ranted in a rude manner that "I've looked at your DAMN car 3 times and there's nothing wrong or nothing we can do" he continued on with "We've seen the smoke at start up and we feel it is within the specs offered by Chevy as "normal operation"" I usually don't go off too much but I couldn't let that one go. I proceeded with (I'll drop the expletives for web sake) "I may not be the professional who charges $65/hr to so called fix cars but even I know that when I turn the key and my trunk disappears into a cloud...something aint right".
I have an appointment with a different dealer for Weds afternoon and I would appreciate any information regarding the ISS ? And the oil/coolant problem so maybe I'll have half a chance at convincing this garage that there is a problem.
I had one dealer tell me the wobbling drivers seat was perfectly normal. I went to another, and they ordered the parts and fixed it. Night and day between the two dealers.
Maybe you'll have a similar experience. Either way, you need to escalate this problem. Smoke at startup indicates either oil or water in the engine. (Oil has a strong odor.) Either is bad, especially on a new car.
Totally agree with garypen re different dealers. Be cool, but persistent. Go to another dealer and take it to the next level. We're their customers and they should be happy we're buying their vehicles. Good luck...keep us posted.
It is amazing how fast attitudes change and things move when a paper trail starts. A friend of mine purchased a new car from a local dealer and just found out that the car had been sold to someone, had a problem that the dealer couldn't fix, was exchanged for a new car, then was sold to him as a new car. He spent a week trying to get a straight answer. He would get handed off to different people and no one would return his calls (including the owner of the dealership). After we drafted a letter, always using professional but firm language, he faxed it to the owner and went to lunch. When he got back, there were messages from the owner, sales manager, and general manager all asking him to return their calls.
The 3.8L isn't known for wearing out the seals, but I've heard that an episode of overheating can burn them. The dealer can tell if this has occurred and if he hasn't mentioned it, it probably hasn't. The ECM records the event and there's also a thermal indicator on the block which melts. Damaged valve seals are usually replaced so that the repeated oil burning won't poison the catalytic conterter.
If the smoke is steam, it's from antifreeze in the cylinders. The only way I know of that it can get there is a head gasket leak. I've seen a few reports of the 3.8L intake plenum gasket leaking but I don't think it lets the coolant into the cylinders; it drains into the valve gallery, contaminating the crankcase. The other Chev V-6, the 3.4L family, has a bad reputation for intake plenum gasket leaks and when it happens it's serious. If your engine has antifreeze in the cylinders, it will drift past the rings into the crankcase, too.
Antifreeze in the crankcase becomes visible as emulsified oil clinging to the interior of the valve covers. You can see it and touch it through the oil filler hole. It looks like dirty mayonnaise. This isn't what causes the engine damage, though. Ethylene glycol is a petroleum derivative which is miscible with the oil but changes it's lubricating properties. The engine soon suffers extensive friction damage which can't be repaired.
I don't know what a "normal" puff of smoke is. I have a 3.8L (in a Lumina) but I've never seen any smoke. If your car is under warrenty and the dealer continues to stonewall you, I'd suggest an oil analysis which will cost you 20 or 30 dollars and will tell you if there's an antifreeze leak. It will also tell you if the dissolved metals are signalling bearing damage.
Everything I've mentioned is serious and expensive to fix so I hope you won't give up until you're satisfied that the engine's really okay. Good luck.
Would that be before or after he's tells you it's normal and they all do that? I have a feeling they didn't even get that far in this instance. He needs to find a different dealer.
I have the LS at a different dealer today and likely through the weekend. I provided a very suggestive summary of the problems....suggetive in a manner that would steer the service guy toward the problem without outright saying "fix this and that"....gotta try to make them feel important even when you're telling them about things they wouldn't catch on their own.
With any luck the problem will be solved and I can go about with more Chevy friendly comments, however...if I get a BS story or turn the key and see smoke, I will be getting the oil analysis and then maybe a some legal advice.
"BEARMER" you're right, I'm not going to drop this until I feel the car is running proper and I'm out danger as far as high priced engine repairs go.
I also have the service guy checking the HVAC and the paint. The HVAC since no matter how well I clean the windows, an hour with the vents on and I have a film on the inside of the glass that makes driving not so pleasant. The paint, since I have noticed, aside from the obvious road damage (pebbles and stuff)that it would appear the paint is beginning to "spider" beneath the clear coat in a few areas....especially bad looking on a black car.
Ok, gotta run..I hope to hear from the dealer this afternoon...for once let it be good news
Nutz
Any information regarding the quality of the paint and the cheap "12 month/12,000 mile" limit on paint defects?? I have defects but they haven't turned to rust yet so the service place said I'm outta luck.
My next concern is having the documentation to show that coolant got into the oil and into the engine. I'll need it in case the engine goes bad after the 3/36 is done.
nutz
I hope they flushed the crankcase, changed the oil and filter, and removed and cleaned the pan, in addition to replacing that manifold gasket.
I would insist on a second FREE oil change, to make sure the crankcase is free of coolant.
As for whine, it can often be caused by something as simple as low fluid level. Of course, low fluid level would mean a possible leak somewhere.
It might be a bad PS pump. Maybe a bad or loose PS pump belt. Check the rack too. You only have 1000 miles left on that warranty, so get it taken care of soon!
Obviously it was money well spent.
