I still can't figure out why GM is not willing to admit they are having a problem with their remote start and get a "Customer Satisfaction Recall" on this.
Can't they see that a happy customer tells another while a dissatisfied one tells at least 7... that's called business.
Get your dealer to get involved and have the manufacturer do something for their regular customers at least...
It sounds as if the receiver is going bad since you're having problems with the FOB and the TPS system. Hopefully the TSB will cover you even though your warranty has expired. Let us know when you find out.
I think I may need to get the receiver replaced as so many have mentioned here. I better do it before the warranty runs out at 36k.
So when I go in, I should probably mention TSB #3764, correct?
If you're not far out of warranty, you might appeal to your favorite dealer for a little Goodwill. They may be able to get GM to foot the bill, or part of the bill. Remember, you get more flies with honey than with vinegar. They don't owe you anything. You are asking for a favor.
i also have some other issues:
1. pinging noise after i turn off my car
2.while i'm driving my ca feels like its choking, or like its gonna stall... then sometimes it's totally fine. and sometimes it does it at a stop light while the car is sitting there. normally when starts happening then i go and get a fuel treatment and fill up with prem. gas... and it does fine for a while like a couple to a few months and then i have to do it again ... and sometimes after the treatment it will do it but it's not as hard of a choke and it's very less noticeable and far and few between.
are either of these major concerns????....should i do anything more?... or what????? please help!!!!!!
