I have not gotten stuck or had the traction control system shut down once this winter even in 8" of snow.
Just wanted to make sure folks know that there is an option that allows you to stick with the original factory size tires.
In my opinion, at least for me, the Toyo HT was the best choice. Like you, I didn't want the expense of switching wheels.
I bought mine online at treadepot.com - price was pretty good and the service they gave was amazing. When I ordered mine, they were on national backorder, but the following week a shipment came in. Treadepot shipped mine to me in literally 2 days from when they received the shipment.
I thank you for your help.
JP
After much deliberation, I decided to spend the money now and get rid of that awful 19" tire and limited choices. I expect the Michelins to last long enough to offset the poor mileage performance (that I've read about) of ALL 19" tires. Also I am anticipating a better ride with the 18" tires. They are going on early this week. Will let you know how they worked out.
BTW I am not a fan of Hancook tires based on experience with our work trucks.
Did you mean to type "treadepot" instead of "tirerack?" I don't think tirerack carries Toyo.
Consider yourself lucky...
Besides, the time to ask for consideration is while you are negotiating the deal. Once you've made the purchase, it's too late!
Costco has a sale on Bridgestone Dueler H/T 225/65 R17 101S for my 2007 HH.
$543 for 4 out the door.
3/32 and 4/32 tread left on my tires. They will try to push the Open Country HT Tires which are very respectable tires if you drive a lot of highway mileage, but I opted for the Versado CUV's to help me with driving in the rain and snow in the Denver area and they offered me the same discount on these tires.
The A20 tires on new vehicles have been reformulated to wear longer. Do NOT expect your Toyota dealer to tell you about the Toyo discount program - the two in my area said nothing.
Good luck everyone!
At least this thread is giving me ideas on what tires to get.
Toyo H/T.
I now have over 9000 miles on mine with no perceptible wear (still at 12/32"), great snow and rain traction, good handling. Completely different tire from the stock A/Ts.
The Toyo Open Country H/T tires are great - a whole different animal than the A20.
I had them installed at my favorite tire place where a friend of mine works, and had him pay particular to alignment. That was the key element. The net toe-in met manufacturer’s specs. However, one side had too much toe-in while the other side had too little toe-in. My friend said that is what caused my excessive tire wear. This toe-in problem does not show up in driving or handling, but causes excessive wear.
If you need to have your tires replaced, have them check alignment, paying particular to toe-in on each front wheel.
After 13,000 miles, my tires still look brand new.
The 1st set of Toyos got 15,000 miles. Went to the dealer and they said the origional issue tires we always of lesser quality.?? I switched to Bridgstone, the only other tire maker of 19" tires at that time and they are bald at 19,500 miles. I am now thinking strongly of changing to an 17" wheel instead of 19" to get a better selection of tires to work with in hopes of getting better milage. I know the dealership is going to charge me up the wazzu to recalibrate my vehicle to go to 17". I drive about 1,000 miles a month and at that rate, it costs me about $53.00 per month in just tires. If I'd known that at the time I was shopping for a Hybrid, I would not have bought the car. Very expensive mistake.
So that said those who have changed over to the HT's any updates, are you happy? Not many choices out there in this size :mad:
I have 11,000 miles on mine. They had 12/32nds tread thickness when new, and now measure 11 or 12/32nds. Great snow traction, too.
Clearly a completely different tire from the A/Ts.
Now, if you read through this forum, it seems the problem with tires starts with the 08 and up HH - 18 inch and up - no Michelins to fit. I started looking at this forum to find out about Nokian - seems to be the best, but horrendously expensive here in B.C. That would probably be your best, if available, but I love Michelin.
I recently went to my local Costco here in Southern California, and they now carry a Bridgestone Dueler H/L 400 P245/55R19 103S Light Truck/SUV tire for $199.49 (plus $15 for install, unless you buy all 4 tires, then you get $70 off, which basically covers the installation of the tires).
On the description it said the tires had a UTGO Rating of 400/B/B and have an "All Season Track."
My wife and I will be nearing the 20,000 mile mark on our 2009 Highlander Hybrid LImited, and with all the snow this season, we will be making the upgrade sometime soon. I'll post back when I have some experience with the tires.
On a final note, I checked on costco.com and they still didn't have the tires listed on their website. They might only be at certain warehouses, so it might be wise to check with your local warehouse before planning on getting the tires there.
The associate at Costco said they were fairly new and were being carried because of frequent requests for the tire size. (I know the year we bought our Highlander, Consumer Reports had it rated #1 in its class, so there has to be quite a bit of demand out there).
Happy shopping!
Gusto
Lots of very negative reviews.
I continue to be very happy with my Toyo HTs. Now a year old, virtually imperceptible wear, great winter traction.
My local tire dealer had quoted me just over $1000 for the Bridgestone dueler (same tires I had put on at 13,000 miles). They talked to their Yokohama rep and weren't able to get the tire size I needed so advised me to go with the dealer.
I dropped my car off after hours on Thanksgiving. The next day I got a very apologetic call from the dealership. Apparently, my vin number had indicated at common 17" replacment tire and that was what they had based their quote on. After much "mea culpa" talk from the dealership, they offered to put on the Michelin duelers for $780. Naturally, I took them up on the deal.
Still wonder why the VIN inquiry was wrong but satisfied with my dealerships response.
245/60/R18 from Belle Tire for about $1000. The new tire diameter is exactly the same as the 19" toyos so no calibration was needed and the toyo spare on the 19" wheel can be used if needed. The ride is fantastic and after a year there is no noticable wear on the tires.
This cost me some bucks but the problem is solved.
1. for people heavy into winter, get Blizzak snow tires. Great in snow and ice. Huge snow fall here in New England, these tires inspired the confidence in me that I had in my previous tank of a vehicle, Jeep Grand Cherokee. Scared to death the previous winter in the A20's, crashed in one inch of snow at 10mph. The Blizzaks are totally worth the money to me, nothing is as important as feeling safe on the road. Yes, mileage was 22-23 instead of 26-27, but to me a small trade off.
2. I just emailed Toyo to complain about the a20's. I was lucky to squeeze 23k out of mine, but they are about to be reinstalled for the spring, and are completely bald. Anyway, I sent an email to them, complaining about lack of grip and treadwear. I literally was called back by a customer service rep in <30min, stating they have a program where I bring the tires to a Toyo dealer, and will get a discount. We'll see how much. I think they are nervous that their reputation is going to be very damaged by this, so use it to your advantage.
3. Is it then worth it to get the Toyo H/T? Seems like people here really like them. What kind of mileage are people getting? I was getting 26-27 from the A20, sometimes more.
4. Tirerack is listing a Goodyear Assurance CS Fuelmax as a new tire in the 245/55/19. Anybody have any knowledge about these?
