I bought a T&C 2 years ago with 170K miles from a friend. I put about 30K miles on it with no problems.
Last month I was rear ended by a GMC 1T pickup doing 60mph to my 15mph. Van is totaled. PROBLEM: The driver seat back collapsed with the rear impact. Since I had no support, I was yanked backward enough that my weight bent the upper part of the steering wheel about 6 inches backward. The impact over-extended my elbows, sprained my wrists and shoulders, and exacerbated the arthritis pain in my neck and lower back (I am 70 years old, but in good shape). Question: Is there a history of broken driver seat backs in Chrysler products? Good van to the end, but that seat problem is causing a lot of grief.
Dinos
Tonight I tried to get the panels off the inside of the rear lift gate, but was not able to get down to the lock to take a closer look....">link title
Any suggestions?????????? <a href="
I have a feeling that giving the mechanism a good spraying with lithium grease would help tremendously, but I have not taken this step yet, nor have I taken apart the paneling to do so.
KEith
question: do we think the fuses is going bad or is it the connection to the fuse?
Stacey
:confuse:
Stacey
I don't think you should see these problems in a 2 year old van. Any help would be appreciated. Thanks in advance.
One question for everyone, though... if you manually open or close your sliding doors, are they pretty heavy? Mine are, but I thought that was normal, beings how they have a motor and all. The rental I had for the last 2 days was a 2007 Caravan with power sliding doors and they were about 1/2 as heavy. I kept slamming them by accident since I was used to really putting some muscle into opening or shutting them. Kind of wonder if this may be a connection to the locks not working. I know, I'm probably grasping at straws, here.
I came to this site like many of you to get some questions answered about my power sliding doors.
The passenger power sliding door stopped working about 2 months ago. Sometimes it would work then nothing...
Well yesterday I opened the door and was surprised to see sparks flying down near the track at the bottom of the door.
After some inspecting, I have found a wire that has been cut in two and making contact with the body of the van causing the sparks. Could this be the problem with my sliding door? The answer is yes. I just installed a new plastic wire track and everything works fine. $56.70 later... This is an 2005 model should this be happening already? Its a bad design. All the engineers have to do is wrap the exposed wires in another plastic wire loom...
Problem solved. If anybody else is having problems with your power sliding door check your wires.
Jody
