We have an updated look. Click here for information on how to manage your settings. If you run into any issues, please email [email protected]
The only prob I seem to have now is my car smells like gas when driving. Hmmm. Wonder what could of happened at the shop the other day. Now I have to call Meineke AGAIN to see why I'm getting that smell.. They gave my husband a list of things that needed replacing but he didnt write it down. Ughhhh
The first thing they did was replace starter/starter relay and that was 410.00. A year later and they just did the fuel pump relay and had to do diagnostics twice.. at 80.00 a pop. WTH. The total for the fix the other day was 240.00 and included the tow charge to get it there.. Not too bad.
I'm tired of spending money on this car but can't afford a new one. Grrr.
Now I'm ready to change the ASD relay after the dealership charged me 60 bucks for it! grrr Which of the three relay boxes on the driverside firewall is the ASD relay?
Car runs great for a little while after the first time I start it up for the day, but after awhile it seems to idle like hell at traffic lights and stops. Sometimes it will even shut off if I am just coasting slowly, like in a parking lot. Took it back to the garage, had the TPS replaced, no luck. Went and got a MAP sensor, that isn't it either. It has a rebuilt transmission, and sometimes won't shift properly, so I have to feather the gas when I pull out. Also tried gumout and some stp fuel treatment after the last few fill ups, seemed to fix the problem temporarily.
This is aggravating... any ideas?
It will run for about 20 miles then stalls... I can let it sit for an hour or two and it will run and do the same thing. I have already changed the fuel pump, inline fuel filter, and the distributor. I also changed the fuel relay. It seems to stall when then engine gets heated up. After it stalled i checked one of the spark plugs and they wasn't getting spark thats wat made me check the distributor but it does the same thing after i replaced it so next i was going to check my coil pack and the ignition module but if you could help me if you got it figured out on your car they seem to be having the same problem????
Chuck
The Dodge dealership wants $60 for one! I ordered one online for $10. It's an exact replacement of what's in there already, which is not a dealer part ...... this must have happened before with the previous owner. The ASD relay is a Zettler AZ973-1C-12DC1R1.
1. Stalls when on stoplight.
2. vibrating hard when on drive
3. Lagging on acceleration. Feels really heavy.
Heres what ive done so far,
Checked
1. Crankshaft pos sensor
2. Camshaft pos sensor
3. Fuel relay
4. ASD relay
Completed/ Replaced
1. Fuel relay
2. Full Tune up
3. Crank pos sensor
Please Help! What should I check next?
Let me know if it works for you.
I'm gonna check that out and I'll let you know...
Then I started the car 3 hous later same problem stalling rpm jumping from 500 to 1000 running rough please help.
