http://www.digitalspy.co.uk/tv/listings/displaysched.php
5th Gear on Tue 5/11
Vatnajokull
Removal is pretty straight forward, though the front end caps require a little "twisting and jiggling". (Check with PP if you have any fitment issues.) Do you have any lights in the RBs?
No suspension component issues WRT to the RBs
HTH
Bill
Thanks for any info.
Don
The compass in the rear view mirror does not display anything. Has anyone faced a similiar problem?
The LC and Prodigy worked well with my 16ft 3000lb trailer. Not so for the trailer battery hookup, at least not until I had done some rewiring.
Prior to my first trip this past weekend, I had discovered that the trailer battery would back feed through the LC trailer connection and keep some items in the LC alive with the ignition off. The odometer LCD and AC fan would continue to run and thus discharge the trailer battery while stopped for lunch enroute to the campground.
Before I bought the LC I had discovered a TSB on the web that described such a problem but with the daytime running lights. Mine did not have that problem and the TSB VIN range didn't apply to mine so I thought they had fixed the problem.
I called Toyota and was told the old TSB was canceled and a new one is imminent. But I was ready to tow, so I attacked the issue with my Toyota electrical systems manual in hand. Seems that there is a relay intended to isolate the trailer battery charge line when the ignition is off. However there are other items served by the same relay, namely the AC, the rear wiper, an ECU line, and a gauge line. The battery charge line needs to be separately isolated.
So I added a relay (12v coil, 30amp contacts, Radio Shack 275-226) in series with the trailer battery charge line and fed the coil with an IGNITION ON line from junction connector J4 near the ignition switch. I suspect the upcoming Toyota TSB will do something similar.
An alternate temporary solution, if you don't need trailer battery charging while towing, is to just remove the 30A BATT CHARGE fuse located just above the left kick panel in the driver's foot well.
My guess is that it will be hard to even give an LC away soon, so the residual values are going to hell in a handbasket.
The good news is premium fuel is getting proportionately less expensive. Where I have lived in Texas and New Mexico, it's always been about $0.20 more than reg. unlead. When reg was $0.89, premium was $1.09, 22% more. Now at $1.98 and $2.18, respectively, it's about 10% higher.
If you must, drive it less often and keep it forever.
Just my .02 worth.
Need help diagnosing a whine that seems to be coming from the rear driveshaft or differential. It comes in speeds in excess of 50mph and only when the accelerator is pressed. At steady speeds, on cruise control or otherwise, all's quiet.
For good measure, I got the tranny & coolant flushed and replaced . Also got the LOF done. The greasing of the driveshaft seemed to get rid of the whine for about 300 miles, but now the whine is back.
Any clue what may be wrong?
Do you have any other "symptoms" or info that makes you think what you're hearing is abnormal? You mention cooling and tranny flushes, but nothing about diff/TCase oil check/change, propeller shaft, flange torquing etc.
If you can, get a hold of a shop manual and locate these various areas for lube and possible tightening.
HTH
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2479847134&category=33558.
Anyone know if this works? 4-5 mpg increase (depending on driving style).
mac24 "Jeep Wrangler" Mar 22, 2004 3:17pm
But with an LC easy acceleration and lots of coasting sure helps at least until the hybrid LCs arrive. ;-)
Good point I had almost forgotten about the e BMW's I thought that they ran on diesel? That would explain the low Redline.
I think the "e" engines were only used for about 5 years or so. I'm sure that Toyota has some pretty significant engine changes on the horizon to address not only fuel economy, but emissions too.
Stand by OPEC
Back in 1974 just about 30 years ago we went from cheap gas to over $1.00 per gallon and once again the prices have skyrocketed to $2.00 and $3.00.
When the prices hit $3.00 per gallon I will drive the LC on weekends and perhaps buy a Toyota hybrid or invest in the hydrogen technology, that is not far into the future.
Sorry for changing the present conversation.
I have been very ill for a long while but finally I am seeing a clearing and out of the woods .
Lou
Nothing against the original poster. And thanks for letting me blow my steam.
The high prices of gas in other countries isn't due to market prices... it's due to government overtaxing a commodity. Gas costs roughly the same in Europe as it does here... they just tax the crap out of it.
I like it our way better.
Lets face it we waste gas in the US hand over fist and that thinking also trashes our public transportation system. We have a lousy train and commuter system in most cities.
In conclusion: there is no way I would drive a non-diesel Landcruiser in the UK at $6.50 a gallon I can tell you that. But in the US I do and so I waste gas!
#2789 of 3797 Starter engages but doesn't crank by ndorsey Jun 13, 2003 (12:03 pm)
Has anyone experienced this problem?
This is a 99 LC, Starter engages but doesn't crank, after the second or third try the truck will start. I tried it with both keys thinking it may the emmobilizer but does the same thing. After starting I shut down and it will repeat it self.
I thought it was a weak battery, or loose connections but everything is good, I thought it was a flat spot on the armature but not sure.
Possible computer?
Any suggestions would be helpful
#2790 of 3797 ndorsey by scifi Jun 13, 2003 (12:47 pm)
I currently have a couple of keys without the immobilizer chip in them. The engine will crank over but will not start as the fuel and ignition systems have not been activiated.
Now, I have heard that the engine may fail to start if: the engine immobilizer system key's ring is over the top of the key; a Mobil-type transponder is on the key ring; or if another immobilizer key is on the same key ring.
If your vehicle doesn't crank then you can rule out the immobilizer. If the battery is good, my first thought to you would be to look at the starter.
#2791 of 3797 ndorsey by idahodoug Jun 13, 2003 (4:57 pm)
You need to do a bit more on describing what's happening. For instance, you say the starter "engages", but "doesn't crank". Most people consider an engine cranking over when the starter engages and the engine is spinning. Starting means the engine has caught and is now spinning under it's own power.
Simply getting a single loud click under the hood, but no engine movement is another typical problem.
Tell us more specifically what you hear and feel with an eye toward putting us in mentally in your car.
IdahoDoug
#2792 of 3797 idahodoug by ndorsey Jun 13, 2003 (5:45 pm)
For instance, you say the starter "engages", but "doesn't crank" - Yes the bendix actually engages into the flywheel as if its going to start, but it doesn't rotate the flywheel.
My first thought was Battery, but the batt. is good
It does this about two or three times then it starts. When I shut the engine down it repeats the same sequence.
Does that help any?
#2794 of 3797 starter by bryan28 Jun 14, 2003 (12:23 am)
sounds like a bad starter, if I'm understanding you. It sounds like the starter is shorting out. What happens to the electrical system when it is trying to turn over? Check how much current the starter is drawing when trying to start. What is the sound when it is trying to turn over?
If you want to talk gas in general, try the Your Gas Mileage: Facts & Figures discussion or CAFE Standards; In Line or In Need of Adjustment?, or one of the other topics in News & Views.
People come here (mostly) to talk about the TLC, not health care or gas taxes. Thanks,
If you're a LC devotee, gas mileage is a "nice to have", but not a deal breaker. Would be interesting to know if LC sales have slipped since the gas prices have spiked upward. And consider what other LC owners in the rest of the world pay for their gas.
My observation here in So Cal is that LCs are still in demand. I don't see many advertised and no special blow out prices. When I do see one at a dealer, it's usually gone within a day or so. Same for used ones.
Considerations are price (mid/high $ teens) and safety (doesn't seem to be a problem with the tank-like LC).
1. What should I look for in a high milage (100K+ miles) LC?
2. I'm used to doing all my auto work myself (with the exception of tire mounting and alignments) but I'm concerned about cost of replacement parts.
3. Since I'm in Southern Cal, any possible issues buying one that's lived close to the ocean?
2) Parts cost what they cost. It aint a Taurus. So far with about 105,000 miles on a '98, the only "biggy" items were a water pump and the timing belt, both of which were labor-intensive and not particularly expensive parts.
1) As mine is at 105k, I'm not the best person to comment. My water pump was leaking and discovered during timing belt replacement. Aside from that, spark plugs, fluids, tires,....nothing but normal wear-n-tear items.
1. A one owner vehicle with complete service records available.
2. The look and feel of the vehicle. It was extremely clean, and after some new tires, drove very well.
If you are familiar with maintenance, crawl under a few Landcruisers and look at the suspension and driveline. you'll be impressed how solid everything is put together.
As far as parts, look at Toyota Wholesale Parts at
www.toyota-parts.com. They are friendly, knowledgeable, efficient, and less expensive than dealer prices.
Just my opinion, but you might consider a 99 or newer, since 98 was the first year for the 100 series. I haven't seen more problems reported, but am always curious about the "kinks" being worked out. I suppose after 6-7 years, any kinks would have shown up by now. I saw one 98 on sale on ebay with about 216,000 miles on it.
Just one more thing- if you are fortunate enough to find one, do that beauty a favor and take her off road, at least every once in a while, at least in the snow or something. Every Landcruiser deserves it.
With apologies.
Good luck. My description is based off memory here and nothing more, so you may want to confirm with more authoritative resources before taking things apart.
HiC
Only engine-related issue: bearings failed on one tension pulley for serpentine belt (replaced under warranty).
Only other mechanical issue: seat catch/release for rear jump seat never quite worked properly from factory. Replaced assembly with new unit.
Changed axle/xfer case/trans fluid every 30,000 miles (Mobil 1). Also fuel filter and EGR valve every 30,000 miles.
Changed engine oil every 5,000 miles (Mobil 1 5W30; 0W30 for winter driving) w/K&N Oil Filters.
Lubed driveshaft grease fittings OFTEN.
Only 93 octane gasoline. 17+ mpg highway/average a bit over 15 mpg around town.
Added one bottle of Techron every 10,000 miles.
Best aftermarket item: TRD front & rear sway bars. The TLC was always a great handling vehicle. With the addition of these factory designed sway bars it transforms the TLC. Dare I say "nimble?" E-mail me for info on how to get them: njpaguy@mindspring.com. (NOTE: I'm not selling them; will provide contact information of dealer via e-mail).
Tire to avoid: Yokohama Geolandar G051. Reason: side walls are too soft. Makes the TLC driving characteristics constantly changable. It's a shame too, because they're extremely quiet, have a superb ride, and are excellent in the wet.
Excellent highway tire: Bridgestone Dueler H/P D680. Had to +1 (P285/70HR16) because not available in 275. Quiet, good ride, superb handling (especially in combination with the TRD sway bars). Maybe not able to match the Porsche Cayenne through the twisties, but again the word "nimble" can now be used to describe driving the TLC.
Looking forward to enjoying the next 94,000 miles just as trouble free. Hope you're enjoying the same.
