Chevrolet Monte Carlo Electrical Problems
I've rented a monte carlo ls (I was told it was 2007). The rental agency lost the owner's manual. When I turn it on to drive, the dome light comes on & stays on. Anyone know how to turn it off? It turns off by itself about 10 minutes after I shut down the car. However driving with a dome light on is really annoying. Any ideas?
Thank you in advance
I am having problems with my 2001 Monte Carlo SS. Sometimes the turn signals wont work, or they start and then quit blinking.
When it got cold out. My temperature gauge quit working. The heater fan setting #5 quit. Then 1 thru 4 went out. Can someone help me with this??
My car shifts hard when the fluid is warm and I notice bubbles in the fluid. Checked it because I thought it was low. The bubbles make it read high.
Also lost use of my heated seats and rear defroster. Working on those problems next. Probably have more toggle switches to install. Let me know if you have any insight on my problems and I'll do the same for yours. rvac99@cox.net
95 monte has been an absolute trooper, 167k mi, no real issues to speak of, only maint. has been normal, alternator, starter, shocks, brakes, etc. drove to the store one night, came back out, no go. chime inside sounds dim and fades to poop after a bit, tried jumping but to no avail. i know the blinker switch on the steering column is going, but now when there is no key in it a crazy buzzing/ticking comes from behind the speedo cluster and a metal box behind the steering wheel column is buzzing angrily...where do i go from here???
thanks for any help!
rk
I have a 2000 monte carlo ss and it keeps blowing the fuse that controls my cooling fans causing my car to heat up to a high temp unless I get onto the high way. Have you heard of anything like this?
Chevyone
Stopped it by a good friends shop, just to verify; if it's the body control module (bcm) a new one can only be programmed by the dealer. Went by the dealer also, they said that it also could be in the ignition switch, the service rep said it could be the bcm as well but pushed more for the Ign Sw. My gut feeling and past experience if it was the switch when keyed to start and blower/cruise does not run/work they would continue to not run/work until the next time that the key was turned. My problems will stop and start intermittley while driving. It also does not run/work when first started. Also I have the info center for mileage and traveling direction (N, E, W & S) it also does other functions. I have noticed most times that the blower/cruise is not working it also goes out, but there has been times that it does continue to work. Are you seeing this also? Don’t know if you have this option on your car. They would have to pull the codes for a cost of $89+. Don't know about you but I'm old school and like my 67 Chevy PU. I have been turning wenches along time and can fix anything on the truck. New is great as long as it is working but when it's not working on these new rides it can be costly. Please let me know if your fix works. My problems have also been acting up for almost a year now. Just a side note; always liked the name Ralph see I’m bias being my father carries this name. Thanks,
Chevy One
My wifes 2001 SS is doing the exact same thing. The overhead console goes out an no heater or A/C. Did you find a fix.
Thanks'
Bruce
Ralph.
at least I know it's not an isolated problem, looks like quite a few have this.
I was wondering if anyone can give me instructions on how to remove the hazard switch on a '97 Monte Carlo (my son just bought, its his first car) . There are no screws under the steering column behind the steering wheel so I know you can't remove the cover that way, the cover looks to be 1 piece and I'm guessing you have to remove the steering wheel(which has the airbag and I've never dealt with that before- don't want that to go off if I'm messing with it!!) and slide the cover off, after somehow removing the ignition key cylinder. The hole for the hazard switch is on top of the steering column, towards the right(passenger) side, just in front of the ignition key cylinder. I've seen all the electrical problems posted here, I just hope he doesn't start having all those problems. Thanks in advance for any and all help, its much appereciated. :shades:
Thanks Brad
I can start my car without problem when its warm outside or the car is warm already, let it sit overnight it takes around 30 to get it started and keep it started. Once it is started there is clicking noise coming from all within the car. The steering column clicks, the fuse box clicks, the door locks click they stayed unlocked but ifyou lock them they unlock. The lights flash, the windows roll up and down to the clicks as well as the wipers whipping at the speed of the clicks. Whats your diagnosis?
I apologize that you are experiencing a concern with your vehicle. Have you had the vehicle diagnosed for the concerns? How long have the concerns been present? Thank you,
Mariah GM Customer Service
