Visitor Agreement.
The DTC will lead to info displayed on a diagnostic tree. This tree can be found in the GM Service Manual, a CD set or a service computer. Of course a good tech will often short cut, due to his/her previous experience.
They do work for their money. Nothing can beat effective training, experience and a dyed in the wool service tech that loves his/her job. ( A tech or whatever they are called today )
The 2004 vehicles will get redesigned sheetmetal. The Suburban takes on a Trailblazer type front end look. The GMC stays pretty much the same to the untrained eye. Devotees will notice the grill takes on a more squatty stance.
They removed the spare from inside to underneath. I carry a lot of eqpt. for service purposes. The small amount of space that was taken up by the spare tire has never been a problem. Don`t need a rolling BOOM BOX - I think they had to get rid of the spare just so they could put that big speaker in its place.
They restrict some options to try to sell lift gates don`t want - don`t need.
Don`t appreciate reading that they don`t want to -or can`t - service a truck just because there are no DTC`s set. Like when the engine cuts out on a 65 mph expressway. There are test sets that can capture the code. Won`t go into the three other long term problems tied into the computer that they can`t find answers to.
I finally came to the conclusion that GM no longer can provide a truck that is reliable and offers the full range of options that I want. Again for me - I want my truck my way - not some bundled jumble of options that GM wants me to take. ( Yes I`m a option Nut )
Has nothing to do with money I can write a $65,000 check today for a vehicle that has the options I want. Will look at three or so SUV`s to see which comes closer to my pics. At this time it is not likely to be GM. Would have been willing to pay 2,000 for 4 wheel steering and 1,000 more for real wheel independent suspension like on the new 2003 Fords.
They don`t seem to be offering much on the new 2003 - just some gingerbread on the inside that doesn`t turn me on. Same old body, same old colors and no two tone, as far as I heard.
Thanks a lot.
I'd like to read the article. Thanks.
Look do yourself a favor get preapproved with a people first loan, so that you can make out the check in the dealership. One less thing to deal with.
You should be able to get this deal (or possibly even better) just about anywhere. It is not uncommon, despite what some around here say, there is plenty of profit for the dealer at that price, if you consider the time saved by not dickering (among other things).
I am considering a larger SUV. I think the Yukon or Suburban will be a nice fit, but I cannot find these with a Key pad type keyless entry.
Does GM not have this key pad as an option?
Can a key pad be done as an after market option?
Has any one done an aftermarket key pad?
Our main goal is to allow the vehicle to idle with our dog inside when it is hot or very cold outside.
William
Run it through to make sure, but the trade in price I got was around $16,400, and private sale was $17,600. I could have your options and other info wrong, so try it and see. The site is pretty helpful.
Steve
Drej~
the tires are cupping/scalloping ONLY on the inside of the tread..on both front tires... those tires are Firestones that came with it.....it has 15K miles on it.. mainly over the road driving.. 6 trips to Florida from NC in a year
has anyone had this show up on theirs?? any Tech Service Bulletins that anyone is aware of before I bring it in to the local Chevy dealer..
I also have an '01 Z71 Subn with 13K miles on it.. today I checked the tires more closely on my Z71.. they are starting to do the same as on her 'burban...I had noticed the same noise.. it has 13K miles on it.. those tires are Goodyear 17" standard issue..
have had a number of Suburbans, Expeditions, Explorers over the past 9 years.. never had this problem before.. let alone on basically two identical trucks...
thought maybe others were experiencing same.. ??
both trucks are riding straight-on.. not pulling .. not drifting.. not wobbling or vibrating in any way.. the only thing that is noticeable is that the tires are very noisy( for obvious reasons)...
have an appt with the local Chevy dealer this morning for wife's truck... we shall see??..I
can just imagine the soft-shoe shuffle they'll try to dump on me..
will post results.. any input appreciated
thanx much
(I also posted this on the ChevyTalk board http://www.chevytalk.org/forums/Forum11/HTML/000562.html to see if anyone else has had this problem with tires cupping..)
I now have 18000 miles and my emergency brake no longer holds. The dealer pulled the wheels and said the emergency brake shoes (separate drum on the rear hub) need replacement. About $200 - WOW. Their explanation is someone drove with the brake on. "... its a very thin pad, and even just once can do it..." Can I really believe that GM could have such a flimsy design on a truck?
I took it up with GM customer service, and the AVM - area vehicle manager got involved. He says the wear on the pads was even and the brake must have been left on. In the report, he claims to have seen the brakes personally to make his judgment. Only problem there is the truck was not at the dealer on the date he reported to be there. I pointed this out to the GM customer service supervisor, who was reluctant to be available, but she said that's it, case closed.
History of the emergency brake:
> Since the truck was new (last July), the brake always had to be depressed low to the floor to hold. Because the truck was new, I thought this was normal.
> Most of the about 18,000 miles are long trips, e.g. DC to Florida.
> It was after my last trip, about 1800 miles (all highway) that the brake went from being low but holding to push it to the floor with no hold.
My feeling is that the brake had some sort of factory problem/defect that allowed the pads to touch even though the emergency brake pedal was not engaged. Logically, if the car was driven with the brake on slightly, assuming the noticeable light was overlooked, wear to the pads would be to a certain level. It would probably require several/many episodes like this to wear the pads out - on a truck one would hope so! The problem with that scenario is I have not driven with the brake on.
This is my first Suburban after two consecutive Tahoes - and I never had this problem in the past on these or any cars for that matter.
I'm appalled by this problem, and even worse, GM attitude and unethical behavior in their report. If I can find a pattern, I taking this to Channel 7 News Investigative Team. It's a dangerous situation among other things.
Has anyone else had this problem? Please post or reply to my direct email - acmarcus@fuelmanagement.com
Thanks, Alex
My dealer informed me there is no adjustment to the parking brake. Was he wrong?
The dealer said that they would adjust under warranty but replacement is $200. There is a star adjuster than can be used to adjust (similar to the adjuster on standard drum brakes). To adjust simply, remove rear wheel, remove calipers, remove rotor, turn star wheel several turns and reassemble.
Many have complained about the soft pedal on these vehicles.
The clearance for the shoes to the drum are extremely tight, it is .026" so if that is off then that is the problem, not that you burned up the shoes. My guess is that the dealer is trying to make some $$$ off of you, not that you even need the parts.
Here is what the service manual says on how to adjust the park brake. The special too they are referring to is a brake drum measuring tool.
1. Set the J 21177-A so that it contacts the inside diameter of the rotor.
2. Position the J 21177-A over the shoe and the lining at the widest point.
3. Turn the adjuster nut until the lining just contacts the J 21177-A .
4. Repeat steps 1-3 for the opposite side.
5. The clearance between the park brake shoe and the rotor is 0.6604 mm (0.026 in).
Important:
Before you adjust the park brake, verify that the park brake shoes are adjusted to provide a clearance of 0.6604 mm (0.026 in).
Best bet is to take it to a different dealer.
In addition, I do the wheels in (or out) deal to help the thing stay against the curb if it should roll.
But, where are you guys that you are even in a position to worry about it, or am I just a city slicker who does not use it as there are not too many emergency needs for me to try it out?
I did have to use the emergency brakes to stop my old (really old) chevette and an T-Bird -- going down a mountain in Hawaii after we saw the sun rise -- if I had not had that great Hawaiian coffee I am sure it would have been the last one my new wife (we were on honeymoon) and I would have seen.
SO, what am I missing here?
Neither invoice had an entry for advertising on either my '00 Silverado or my wife's '01 Suburban. This is another addon in the catagory of dealer prep, undercoating, exterior coating, documentation fee. Pure profit for the dealer.
Why doesn't the dealer list things such as shop cleanup, waste disposal, rent, labor, vacations for employees on the addon list? You know the answer ready.
This brings me back to how can this happen -- assuming that the above is incorrect?
sensor in the Steering column. $550
Here is the information (direct from email). No pricing as of yet.
In answer to your question about the 2003 Yukons. It has a couple new colors,
Sandalwood Metallic,
and Carbon Metallic.
New up level rearview mirror
available power adjustable camper mirrors
Revised body side molding
all new seats
Redesigned instrument panel
new driver's information center
new steering wheel w/ available 8 button control
optional 2nd row captain's chairs available on all models
dual level occupant sensing front air bags
new radios /new Bose sound system
new standard automatic Tri-zone HVAC system
Available adjustable brake and accelerator pedals
available rear seat entertainment system (DVD)
new floor console
Stabilitrak
Quadrasteer
high powered 145 amp generator
Electronic throttle control
Enhanced Auto Trac System
Improved Brake System
AM/FMstero w/CD and cassette now standard
New Packages available:
Cargo Package
Security Plus Package
Sound System Plus package
Z28 trailering package now available vs standard
Did he possibly mean Z82? That is the current trailering pkg that has been around for awhile
I don't know. He is expecting them to arrive at the end of august or early september.
AS
The updated rear view mirror isn't really all that new, they moved on-star buttons from the dash to the mirror, Cadillac has used that mirror for 2 years now. Another money saving move by GM, and another way to cut a job on the assembly line. GM will get a better deal on the mirrors because they are going to be buying so many more of them and the guy that used to install that part on the dash gets his job cut, so it's win/win for GM, and 1 big loss for another worker.
I am strugglnig with the 2003 predictions. I have heard varying reports from varying people. I have drilled the GMC reps at the detriot auto show. I contacted my local dealership.... Does anyone know when the details of the 2003's will be released? I know the vehicle according to GMC corporate offices will be on the lots in August. I want to the cold facts about the 03 Yuk XL's to compare to the new Cadillac Suburban. They must have a consumer education or release date. NO?
If you can't find it let me know and I will repost it here.
AS
I have a 99 GMC Suburban SLT with 4 wheel drive and 42,000 miles. While backing into my driveway a couple of days ago, the power steering suddenly quit working. I checked the belt, the hoses, and the fluid and can find no reason for the system to quit. No dealer in the Dallas Metroplex can look at it till next week. My question is, could it be something electronic with the PS? Anyone else ever experience this problem? Thanks for any assistance anyone can offer...
Officer Oz...
