Visitor Agreement.
I actually have a second one since there was a nick in the first one I bought so they sent another for free. I was kind of saving it in case it happens again, but we will probably sell the van in the next few months.
appreciated,
kevin
kvnimrls@yahoo.com
The door seems to function, (opening and closing with all switches, remote and manually) but I have noticed something odd that the passenger door is doing that the drivers side is not doing. When the door closes, you can hear, and see, the rear latch engage, but about 1-2 seconds later, you hear the latch again, and the door pops out ever so slightly. The other odd part of this is that when it first latches, the door is actually pulled in beyond the body line of the rear quarter. It's almost like it is pulling the door in to far. After the 1-2 second delay, and you hear the latch again, the door pops out a little, but at this point, the door is now in perfect line with the quarter panel like it should be. I tried pushing from the inside, and prying from the outside to teat the latch, but the door does not move.
I'm sure this is not normal, (as the drivers side does not do this) and now we don't know if it is going to fly open again at some point or if it is truly latched. Have you heard or seen this before? Any suggestions on what might be causing the the rear latch to disengage slightly?
Your part number is still valid today. I called local Toyota dealer who quoted same part (85620-08061) at $149 while the same part at Toyotapart.com (http://www.toyotapart.com/85620-08061.html) is only $80 as of this post. And the dealer was only quoting part cost not part and installation cost.
I am ok around mechanical things and I am cheap and refuse to pay $$$$ for this repair so this *shouldn't* be a problem to change out. The extra notes about the motor screws location being on the back of the control panel was good.
Hopefully this repair doesn't require any special tools you have to purchase from toyota.
Thanks so much for your very detailed post. It made a world of difference. It helped me diagnose and locate the issue without having to pull the door panel off first. Before ordering I will go ahead and pull the panel and verify the release motor is not functioning.
Good grief I have flipp'n electric toy motors that last longer than this!
I'm new to this forum.
If you wouldn't mind emailing it to me: sononeshot@yahoo.com
Thank you so much!
I have similar problems with my '05 Sienna, so whoever mentioned not buying a first year in production model needs to reconsider that thought!
I take care of routine and all preventative maintenance on this van because it's paid off and I don't want another car payment (kids in college and private HS). We live in the Mid-Atlantic (East Coast) area and this is a summary of the problems I've had with my '05 Sienna LE:
Trim fell off from exterior window between mid-window and rear window; interior bolt and
screw covers have fallen off and cannot be repaired
Power door motor failed (fortunately for me, before my extended warranty expired)
There are more, but those are the ones that have bugged me the most. I also know that Toyota quality went out the door when our vehicles were manufactured. Don't know if I'll ever go back after this van. I never had quality issues like this with Honda!
I'm beginning to have the same door latch release issues with my '05 Sienna, but it's definitely intermittent. Having replaced the door motor and cable assembly once already, I was told to turn off the sliding door motor when on a hill so the door motor and cable assembly don't get overworked. Since then (5+ years ago), the door has been functioning properly.
Also, does anyone have trouble getting the sliding doors to "lock" open? IOW, the door should click and hold open when fully opened, but many times, those latches don't catch.
I replaced the sliding door cable assembly and gave detailed instructions how to repair yours too on my blog at: http://johnfixesstuff.blogspot.com/2014/01/how-to-replace-the-power-sliding-door-cables-2004-207-toyota-sienna-xle.html
I recently had the cable break on my 2004 Toyota Sienna sliding door. I replaced the cable assembly and I share all the details of how to replace yours on my blog at: http://johnfixesstuff.blogspot.com/2014/01/how-to-replace-the-power-sliding-door-cables-2004-207-toyota-sienna-xle.html
If you need to replace the cable assembly I detailed the entire process with lots of diagrams and pictures on my blog: http://johnfixesstuff.blogspot.com/2014/01/how-to-replace-the-power-sliding-door-cables-2004-207-toyota-sienna-xle.html
How do you find post #321?
I think this is the comment you're seeking?
http://forums.edmunds.com/discussion/comment/3275999/#Comment_3275999
"The door seems to function, (opening and closing with all switches, remote and manually) but I have noticed something odd that the passenger door is doing that the drivers side is not doing. When the door closes, you can hear, and see, the rear latch engage, but about 1-2 seconds later, you hear the latch again, and the door pops out ever so slightly. The other odd part of this is that when it first latches, the door is actually pulled in beyond the body line of the rear quarter. It's almost like it is pulling the door in to far. After the 1-2 second delay, and you hear the latch again, the door pops out a little, but at this point, the door is now in perfect line with the quarter panel like it should be. I tried pushing from the inside, and prying from the outside to teat the latch, but the door does not move.
I'm sure this is not normal, (as the drivers side does not do this) and now we don't know if it is going to fly open again at some point or if it is truly latched. Have you heard or seen this before? Any suggestions on what might be causing the the rear latch to disengage slightly?"
You might experiment with some electrical tape on the front and rear latches (assuming they are |_| shaped like the ones on my Grand Caravan). I did that with all of mine and it stopped the sliders from rattling. Be nice to rule out a simple maladjustment before taking it to a dealer or body shop.
how if i turn off the power sliding door option, i am able to close it manually fine. I have shared a video of that problem.
https://drive.google.com/file/d/0BxOVFLaP6JWfQ0Z0LTVLUnVwbm8/view?usp=sharing
if any one know what is problem is please let me know thanks in advance
Sam
