2015 Jeep Grand Cherokee Lease Questions
2456743
  • mikeysedmikeysed Member Posts: 63
    Hi my dealer has a 2014 Jeep Grand Cherokee Altitude ... for Sept what are the MF and residual for 15K a year... 33/36/39 months.. not sure what the best is?
    Also, they have a 2015 Altitude ... what are the MF and residual for the 2015?
    I want to compare both as I can still lease both... wonder how big of a diff there is.
    Thank you in advance kyfdx!
  • kyfdxkyfdx Moderator Posts: 271,698
    kris301 said:
    Looking for the numbers for 2015 Limited 4x4 24 or 27 months at 10k/yr in MA. Also 2015 Altitude 4x4 same, 24/27 at 10k/yr. Thanks!
    Altitude: .00056 MF and 61% residual
    Limited: .00020 MF and 61% residual
    2014: .00016 and 50% residual for 39mo, 15K/yr
    2015: .00093 and 51% residual
    Thank you! The above numbers for kris301 look like much better for 2015 model. I know he has less miles but still seem off... maybe 24/27 better? what about 24/27 months for me at 15K a year on Altitude
    Altitude: .00056 MF and 59% residual for 27mo, 15K/yr.
    That won't be any cheaper than the 39 month lease.... probably more.
  • kris301kris301 Member Posts: 34
    Thanks kyfdx! Could you also supply me with 2014 numbers for same setup. Very much appreciated.
  • MichaellMichaell Moderator Posts: 268,062
    kris301 said:
    Looking for the numbers for 2014 Limited 4x4 24 or 27 months at 10k/yr in MA. Also 2014 Altitude 4x4 same, 24/27 at 10k/yr. Thanks!
    2014 numbers - 27 months is the preferred lease term this month.
    Limited - .00020 and 53%
    Altitude - .00014 and 51%
  • ec61ec61 Member Posts: 2
    Looking for numbers for 2015 Limited 4x4, 12k/year, 36 months. Also, same numbers for 2014, although assuming that the 2014 would be less expensive.
    What state is this? Chrysler numbers this month are regional.
    Sorry. Massachusetts, although I am on the RI line, so could work a deal there as well.
    ec61 said:
    Looking for numbers for 2015 Limited 4x4, 12k/year, 36 months. Also, same numbers for 2014, although assuming that the 2014 would be less expensive. Massachusetts, although I am on the RI line, so could work a deal there as well.
    2015 - .00053 and 53% for 36/15
    2014 - .00020 and 52% for 39/15
  • cheyjey1cheyjey1 Member Posts: 11
    edited September 2014
    Could I please have Residual and MF in California on
    2015 Overland 4x2 24m/10k
    2014 Overland 4x2 24m/10k
    2015: .00034 MF and 62% residual
    2014: .00034 MF and 53% residual (27 months on 2014 model. No 24 month term avail.)
  • wakka26wakka26 Member Posts: 4
    Residual and MF in NYC over a variety of options:
    4x4
    2014 & 2015 Overland - 27m & 36m/ 12K
    2014 & 2015 Summit - 27m & 36m/ 12K
    Thanks for everything, this forum has been helpful.
    4x4
    2015 Overland:
    27/12 - .00029 and 61%
    36/12 - .00038 and 51%
    2015 Summit:
    27/12 - .00011 and 56%
    36/12 - .00044 and 47%
    2014 Overland:
    27/12 - .00027 and 61%
    39/12 - .00012 and 50%
    2014 Summit:
    27/12 - .00028 and 56%
    39/12 - .00012 and 46%
  • joh2731joh2731 Member Posts: 3
    Looking for MF and Residual for a '14 and '15 overland. 36/10 and 12 in the charlotte NC area. Would it be worth it to wait until end of November or Decemeber to try and take advantage of any specials, maybe dealers trying to move '14 models? Thanks in advance!
  • cschugercschuger Member Posts: 2
    Looking for numbers for 2015 Overland4x4, 12k/year, 36 months, Diesel in Michigan.Also, same numbers for 2014, if there is a significant difference
    RWD or AWD?
    Waiting another month or two might get you a better deal, but I'm also pretty certain that the availability will be a lot thinner, as folks snap up deals now.
    2015 - .00082 and 53% for 36/10
    2014 - .00012 and 53% for 39/10
  • car_fan_flcar_fan_fl Member Posts: 4
    Hi Folks! Early September, I ordered a 2015 Grand Cherokee Summit 4x4 at my local dealer in the Tampa Bay. Got a decent deal on my trade and due to Affiliate Pricing, a good deal on the Jeep as well. However, the lease-numbers were awful.
    The rate from Chrysler Finance was .00044 with a Residual of 46% (!!) at 39 months with 12K miles/year. My dealer told me that this rate would be "worst case scenario" and if the rates were to improve, I could take advantage of that.
    Since it's October now, can anybody tell me if the October-numbers are any different/better? I won't take delivery until the first week of November, so if October is still as bad as September, there is still hope.(;
    Thank you for your input!
  • rawarren83rawarren83 Member Posts: 2
    I'd like to know the lease rates for a 2014 and 2015 GC Limited Diesel 4x4 for 36/39 mo and 12k miles per year.
    .00017 MF and 46% residual for 39mo, 12K/yr
    2015: .00018 MF and 55% residual for 36mo, 12K/yr. 53% for 39/12
    2014: .00020 MF and 54% residual for 39 mo, 12K/yr.
  • nsull410nsull410 Member Posts: 13
    Could you provide the 2015 JGC Altitude 4x4 mf and residual for a 36/12k lease in New England.
    .00052 and 55%
    @Michaell - Do you know if the 39/12 MF and RV are better this month than the 36/12 figures for the 4x4 Altitude?
    edited October 2014
    Thank you so much for the numbers, kyfdx!
    So it seems residual is unchanged compared to September.
    Do you know by any chance what the MF for September was? I'm asking because I'm trying to figure out if the quoted .00044 I got from my dealer included some sort of mark-up.
    Thanks again!
  • schneller78schneller78 Member Posts: 21
    I'd like to know the lease rates for a 2014 and 2015 Summit Diesel 4x4 for 39/12k.
    edited October 2014
    For the 2015 model year, the 36 month numbers are better than for the 39 month numbers.
    For the 2014 model year, 39 months is the sweet spot.
  • jcarloughjcarlough Member Posts: 90
    2015: .00018 MF and 55% residual for 36mo, 12K/yr. 53% for 39/12 2014: .00020 MF and 54% residual for 39 mo, 12K/yr.
    So at 10k is the Residual 1% or 2% higher?
    10K residual is 1% higher than 12K.
  • ad1das101ad1das101 Member Posts: 14
    What are the MF and residual for 2015 overland diesel 4x4 for 36/15k. In PA. Thanks.
    edited October 2014
    Hi Folks! Early September, I ordered a 2015 Grand Cherokee Summit 4x4 at my local dealer in the Tampa Bay. Got a decent deal on my trade and due to Affiliate Pricing, a good deal on the Jeep as well. However, the lease-numbers were awful. The rate from Chrysler Finance was .00044 with a Residual of 46% (!!) at 39 months with 12K miles/year. My dealer told me that this rate would be "worst case scenario" and if the rates were to improve, I could take advantage of that. Since it's October now, can anybody tell me if the October-numbers are any different/better? I won't take delivery until the first week of November, so if October is still as bad as September, there is still hope.(; Thank you for your input!
    So is that 46% because it's a Summit? Or am I misreading something? Seems like that's signicantly different residual vs say a 4x4 in Limited trim?
    The higher the trim level, the worse the residual.. As a rule of thumb.
    .00008 MF and 51% residual
    Thank you. This forum is very educational.
    So, to compare (taking info I've seen here) -
    A 39mos lease, 12k per year
    Summit 4x4 V6 - 46% Residual
    vs.
    Limited 4x4 Diesel - 53% Residual
    The Limited is 7% higher because it's a lower trim line AND it's a Diesel?
    Also - can I get the Residual and MF for:
    2015 Limited 4x4 V6
    vs.
    You got it.
    2015 Limited 4x4 V6
    .00018 and 54%
  • reldausareldausa Member Posts: 23
    edited October 2014
    Hi
    Can you please post MF and residual for 36mo/12k in California:
    2015 JGC Altitude 4x2
    reldausa said:
    Hi
    .00069 MF and 54% residual
    .00052 MF and 55% residual
  • ezericsezerics Member Posts: 49
    HI could you please tell me the MF and residual for a 2015 JGC Limited 4x4 for 10 & 12k miles, 36 mo. term as I believe it was mentioned that was better than 39 for the 2015s.
    .00018 MF and 53% for 36mo, 12K/yr.
    Subtract 2% for 39 months, Add 1% for 10K/yr
  • subglottissubglottis Member Posts: 10
    This forum has been very helpful.
    Dealers in NY are still telling me that the best deals on 2015 JGC limited are with 39 month term. Does anyone know why? Could the deals in NY be different?
    Thanks in advance
    Thanks in advance
    The numbers we have from Chrysler finance show 39 month residuals as being stronger than the 36 month residuals for both September and October - for the 2014 models. This is true for the entire country, not just NY state. For the Limited 4x4, the 36/15 residual is 46%, while the 39/15 residual is 50%.
    For the 2015's, that is not true. For the JGC Limited 4x4, the 36/15 residual is 51% while the 39/15 residual is 49%.
    Thanks in advance
    The numbers we have from Chrysler finance show 39 month residuals as being stronger than the 36 month residuals for both September and October - for the 2014 models. This is true for the entire country, not just NY state. For the Limited 4x4, the 36/15 residual is 46%, while the 39/15 residual is 50%. For the 2015's, that is not true. For the JGC Limited 4x4, the 36/15 residual is 51% while the 39/15 residual is 49%.
    Thank you Michaell,
    Are the MF numbers the same on 39 vs 36?
    Thanks in advance
    Thank you Michaell,
    Yes - .00020 for the 2014 and .00018 for the 2015.
  • hindoghindog Member Posts: 1
    I'm shopping for a new JGC 2015 Overland 4x4. I'm in LA. Dealer came back with payments of $590 +$5,000 out the door (includes tax/fees/etc). Is that a decent deal or can I negotiate lower?
    I haven't looked at the lease terms yet, but what MF/residual should I be looking for tier 1?
    We would need to know the MSRP and selling price.
    MF and residual for the 2015 Overland 4x4 are .0008 and 49% for 36 months, 15K per year.
  • bmwfan53bmwfan53 Member Posts: 39
    What is the MF and Residual on a 2015 JCG V8 Overland for 36 and 39 months for 15K per year in NJ and TX.
