Towing tips for SUVs
-mike
and yeah, I've never seen them either on a boat trailer, just on utility and camping trailer rigs.
I was using 2wd to tow it and had no problems. I flipped on TOD for a few miles of rain. Milage was 15mpg un-ladded (2100lbs) and 12mpg ladden (5000lbs) I have 275-70-16 Pirellis Scorpion AT tires, Rancho 9000 shocks set at 4/front 5/rear during laden rides 4/front 3/rear unladden, and OME rear springs. With the car on the trailer it was about 3/4" from the bump stops with very little sag.
-mike
-mike
-mike
Oops...wrong forum. ;-)
Seriously, going 90 while towing seems a bit...risky. I don't recommend it. But it's good for folks to know that the Trooper does so well.
-mike
But...70+ on downgrade turns fully loaded??? Hmmm...are you into hedge funds, too? ;-)
If yes, how well does it pull it out of the water?
Does it have a hard time or does it pull it right out?
How fast can you go on the interstate?
-mike
-mike
questions: is this a poor choice of vehicle {shorter wheelbase (104") -or with a class 3 hitch and properly wired is it okay? Will I need to have a tranny cooler installed? I know factory tow packages also include a bigger radiator and other goodies. How big a factor is that considering it's a pop-up. Thanks for the help!!!
-mike
-mike
The e-mail address is www.hensleymfg.com/
-David
-mike
Thx MavX
Any thoughts.
Thanks A Lot
With the trailer hooked up to the Tahoe, is the height of the ball from the ground the same as on the F150? I have a theory but want to check this fact before shootin my mouth off.
start shootin
Check the tire pressure on your Tahoe. I would reccommend inflating to maximum cold PSI, probably around 45PSI depending on what tires are on your vehicle.
The other is the weight over the rear wheels. The F150 has an empty bed, with a truck leaf springs for suspension. Most trucks ride smoother after some weight is added to the bed, due to suspesion design for hauling weight. The Tahoe has a SUV goodies like seats AC ducting, interior pieces, etc. that all add up to larger weight over rear wheels. Then this is all on a coil spring suspension tuned for smooth ride not heavy towing. The easiest and best way to correct this problem is to get a weight distributing hitch. These can be bought at any trailer shop, and some are available with anti-sway properties. I'd reccommend getting one for your tow vehicle regardless of what you find is causing the problem. There is nothing you need to add or modify on the Tahoe, the additional hookups are placed on your boat trailer. It is money well spent.
The other is the wheelbase length on your Tahoe vs the F150. Get out a tape and measure from center of front wheel to center of rear wheel.
If the F150 is significantly longer this might contribute to towing difference.
-mike
-mike
My sister wants to trade her car for a smallish SUV (Jeep, Honda, Mazda, she will pick whichever feels right to her) but is aware that there are limits to the amount of stuff you can put into one of these and still drive safely.
Can anybody help me explain to her what is meant by GVWR, payload, tow capacity, tongue weight, etc? My current understanding is that GVWR is the max the vehicle can safely weigh including all passengers, luggage, etc (things INSIDE the vehicle and on the roof rack), and the actual amount of stuff you can haul is equal to (GVWR-curb weight), stated as "payload" in vehicle specs.
How does towing factor into this? Let's take an example: 2003 Explorer (just the 1st one I clicked on).
Under dimensions, weight is listed as 3963; this is curb weight, right? Payload is listed as 600, meaning GVWR=(3963+600)=4563 pounds. That means this vehicle is fully loaded when carrying 3 average Americans?
Then max tow capacity is 4940 lbs; could this vehicle carry 600 lbs of payload and also tow the 4940 lb trailer?
DjB
Passengers
Gear
etc.
The towing capacity is how much weight the trailer can be, this doesn't come out of the GVWR but in general 10% of the trailer weight is the tounge weight, so a 4940 trailer would have a tounge weight of 494lbs. which is subtracted from the Payload.
So for the example above on the Explorer:
GVWR: 4563
weight: 3963
payload: 600
Towing capacity: 4940
tounge weight: 494
This would mean 600-494 = 106lbs for the passengers + gear in the truck.
A GVWR of 4563 seems very low for an Explorer IMHO. I would think it would be up near 5500 or more.
I just looked up on http://cars.com which has real good specs on vehicles my 2000 Trooper.
GVWR: 5510
weight: 4500
Payload: 1010
Towing: 5000
That means 1010-500 = 510lbs for gear and people inside the vehicle when towing a 5000lb trailer with a 500lb tounge weight.
You can measure your tounge weight by placing the tounge of the trailer on a bathroom scale if the scale has enough capacity for the trailer you are planning on weighing. Also a trailer place could weigh it for you and let you know. The general rule of thumb is 10% of the trailer gross weight = tounge weight which in turn is subtracted from the payload of the tow vehicle.
-mike
http://www.nhtsa.dot.gov/cars/problems/Equipment/towing/index.htm
-mike
my exploder had a real good rundown on the load factor issues in the towing section of the manual. alas, ford doesn't put any sort of load control info in online vehicle selection stuff, or in brochures. it's quite uncommon to find it in any of the sales stuff, frankly. if you can't find a sales person who knows this down pat, keep looking, don't take "close enough" as an answer.
for instance, gross vehicle weight rating of my machine with the tow package is 11,000 pounds. the curb weight is something like 5380 pounds with all fluids full, all the mats and tire-changing tools, and two people. this means you can at the absolute maximum safely load up another 5620 pounds at all points. two more people, 165 pound average, and 500 pounds of camping crud means the vehicle can handle at the most another 4800 pounds. I seem to remember at this awful hour of night that the usual calculation of weight distribution is 10% of the towed weight should be on the hitch, so max 480 pounds of hitch weight on the 4800. a little less may be great if you have an equalizer hitch.
and that means ALL of the load... not just the trailer, but the water in the drinking and blackwater tanks (along with the usual "other"), the food in the fridge and the shelves, the crud in the drawers and cubbies, the extra pillows, the cat litter, wheel chocks and charcoal, fishing rods and barley pops, the whole bit, in 4800 maximum pounds. ford also lists a maximum recommended wind front of 50 square inches before you need to go to a sway-control and equalized hitch system.
and I strongly believe if you have any questions about whether you are pushing the load capacity, you weigh the trailer without the junk added at a commercial scale. if you're close to the line and need more than two trips up from the basement to load up, you're overloaded.
if you're pulling more than one ton, you really ought to be using an equalizing hitch no matter what you tow with IMHO.
basically, serious towing means serious added equipment. you can get lots of pickup trucks that can't tow their own weight as shipped, you can also get trucks from the big three that can tow 11,000 or more pounds of load in addition to a seats-full truck. the difference can be twice the price of a comfy standard truck, and you can't bolt it all on after the fact. the engine, tranny, brakes and tires, multiple cooling systems, and frame and suspension are not affordably upgraded aftermarket, except for booster springs and heavier shocks, and that all factors in.
Most mid-size pickups and SUVs require that any trailer over 1000 pounds must have brakes. GM requires any full-size pickup or SUV pulling a trailer of over 2000 pounds, have trailer brakes. All GM light trucks/SUVs mention these trailer brake restrictions in their sales brochures, as well as in the owner's manuals.
Bob
-mike
Maybe the cop won't give you a ticket, because Ford said you were safe. LMAO.
Perhaps the laws of physics do not apply to Ford vehicles???
Thanks to bob a while back.
-mike
This was e-mailed to me by a friend. Judging by the size of the boat, I would say this truck had a Class IV hitch. It could be a Class III, but I would suspect a Class IV is more likely.
Bob
-mike
but for realism sake it does look like a bayliner (are those fenders still hanging on the outside of the hull?)
steve-v
