Visitor Agreement.
I'm always surprised by how heavy a trailer feels even if it's not much of a load. I have a full-size diesel I've pulled over 15,000# with, but you can feel a 5,000# trailer back there as well. Anytime you're pulling something that weighs as much as your vehicle, things start getting hairly. A short wheelbase, light-duty frame/brakes, and low torque makes things even worse. Long trips at/over maximum capability is asking for trouble. Nothing like causing an accident and getting sued by 10 people. Your insurance has a maximum ya know?
To clarify, I'm looking for something to replace my 1991 Explorer and for short-distance boat towing in South Florida. Will do rare trips to the Keys or the lakes in Central Florida, otherwise will stay close to Lantana.
I'm worried/paranoid about some of our local ramps, which can get very slippery at low tide. I won't take my stick-shift, no 4WD Explorer to them. I'm thinking (and boat-towing friends agree) that the front-wheel drive, automatic transmission Escape should do the trick. Locals tell me I don't even need the 4WD.
I'm not locked into anything yet though, will keep watching for your tips. THANkS
Good job 1,000,000 expo's in 4 years must be a reason. Reliability, good looks, and will pull your boat and 4 kids with no problem. You can even take your hubby along is so inclined.
Have a great time with your purchase.
Frankk
Odie.
P.S. If anybody has experience towing with other cars, I would be interested in that too.
Yes, the '02 Impreza does have a 2000 pound tow limit—if your trailer has brakes. If it doesn't, the tow limit is 1000 pounds.
I've got a 670 pound 5x8 utility trailer (no brakes) that I tow with my Explorer. Juice (one of the Subie Crew Leaders) has towed my trailer with his 5-speed Forester (same tow specs as the Impreza) with a 3 yards of mulch in it. I'm sure he was well over 1000 pounds, and he did fine with it. I'm not sure I would recommend doing that on a regular basis, but in a pinch, if you're careful, it will make do.
BTW, Subies are great cars. We've got two: an '01 Forester S Premium, and a '96 Impreza Outback.
Also, you might check out the all-new '02 Honda CRV. The engine is now a 2.4L unit, and is within 5 HP of the Subarus. It can tow 1500 pounds. I don't think(?) there are any non-trailer brake restrictions. The new CRV will be arriving in dealerships within a few days.
Bob
Steve
-mike
Steve
-mike
Paisan, I know you routinely tow with the trooper to the limit of 5000 lbs. There's a guy around here called heatwave who says GMs are great tow vehicles and says to only use 80% of the vehicle's tow rating (i.e. that would be 4000 lbs for the trooper). Anyone else have comments?
As for the S-hooks, actually you run the chain through the hole of the safety hole, and use the S hook to reconnect it back onto the chain loops.
-mike
I think there's a lot of confusion about trailering judging from posts here ( I mean in TH generally...not so in this topic).
One thing I've heard conlicting reports on is whether the weight in the towing vehicle should be counted towards the tow rating number. For example, if you are rated at 5000# and you pull a 4500# boat/trailer and you have 800# of bodies and stuff in the towing vehicle...are you over your limit? I've read that you are, but others say you're not.
As far as the 80% thing...AFAIK, if your vehicle is rated at 5000# that means you can safely tow 5000# on level ground. I've always understood that if you are pulling a boat up a ramp, you should have some margin...I figure 80% for that. I'm not aware that you need a margin for level ground.
I don't however run the chains through the hitch openings and loop them back on themselves. I wouldn't have enough slack.
paisan is right on target with his recommendations for bearings on boat trailers. They should be repacked at least every other season and should be replace every other repacking. Its a relatively inexpensive insurance policy to avoid the much dreaded bearing burn-up.
Also there is very good reason for only using about 80% of a vehicle's tow capacity. Most people overload their trailers some time during its ownership. If you bought a vehicle that is only using 80% of its tow capacity you'll be in a much safer position. Additionally, when it comes to breaking, handling and acceleration the by not using 100% of the tow capacity routinely you'll be in a much safer position in emergency handling not to mention the wear and tear on the vehicle.
The first is the Max tow capacity which identifies the maximum weight that a vehicle can have attached to the properly rated hitch platform, receiver, tow bar and ball. The rating of each of these must exceed the total weight of the entire trailer package.
Next is payload. This is important when towing because 10% of the trailer's weight should be appropriately "resting" on the tow ball. This 10% is important to ensure the vehicle is not too lightly loaded resulting in a trailer that rebounds upwards after potholes and other bumps in the road. Its also important not too exceed to avoid the vehicle's rear suspension being overly loaded. The 10% weight must also be deducted from the payload capacity of the vehicle the balance of which is now the remaining payload for passengers and cargo inside the vehicle
For example: If a vehicle has a 5000lb tow capacity and a 1200lb payload, you should set the trailer up with about 500lbs resting on the trailer hitch. This leaves the tow vehicle with 700lbs for passengers and cargo (not very much in my opinion in this example.)
This is one of the reasons the Sequoia with its light payload (1305lbs) and high tow capacity (6200lbs) could leave you with very little room for weight in the vehicle itself if it were pulling a 6200lb trailer.
The final important measure is the CGVWR (Combined Gross vehicle weight rating) which is the "master" weight that should never be exceeded. This is the total weight of the entire package, trailer, passengers, cargo and the weight of the vehicle loaded with gas.
Any manufacturer serious abouts the towing capabilities of its vehicles should provide its CGVWR on its vehicles.
Wonder why our tow video and article neglects to mention safety chains at all?
Steve
now, anybody here have a tested working detach switch with electric brakes, so if the rig comes off, say your whole hitch carrier breaks free, the cable to the detach switch at a different spot puts the electric brakes on full from the trailer's battery? I saw a racecar transporter slew across the interstate, across the median, and straight into the other lanes of traffic some 12 years ago because their ball broke off, the chains snapped, and there was no safety switch to hit the trailer brakes.
If the trailer breaks free from the hitch this cable activates and locks the master cylinder which in turn locks the brakes on the trailer to avoid it from rolling freely down the road.
I also use a "safety pin" on the hitch clasp, so that it won't accidently pop off the ball. I've also used a padlock several times, instead of the pin.
I had my 5'x8' utility trailer gone over in August, packed the bearings, etc,. before driving roughly 900 miles (had to move our daughter into college).
Bob
Bob
rsholland "Trailer Brakes" Nov 1, 2001 2:17pm
PS.
You need to scroll back to post #1.
-mike
My trooper does have 4 wheel disc and it seems to stop it w/o a problem from highway speeds.
But...it's not just a question of stopping it...it's a question of fishtailing. If the trailer has no brakes, this is always possible.
I thought that anything over 2000 lbs (trailer weight/not sure about that number) was required to have trailer brakes.
It's 1500 pounds here in Idaho, for example, unless you are hauling hay or cattle within 50 miles of your farm.
Steve
Here's a link
Steve
If you are trailering through a state, you have to comply with their laws, even if your home state doesn't require something. My state doesn't require that trailers be licensed, but neighboring ones do. If I travel through those states I have to have a license on my trailer. I had that explained to me once by an Ohio state trooper.
Actually...you already did when you said the state laws vary from 1000# to 3000# :-)
Edmunds towing guide recommends anything over 2000# use brakes and I would think some 'margin' is probably a good idea.
Reminds me that I should try to check to make sure they really are working. I thought I'd pull it on snow, hit the brakes and see if the wheels lock up (no abs on my trailer ;-) ). 'Course, I'd have to have someone else looking at the wheels.
Some people just deserve the extra attention! ;-)
tidester
SUVs
Steve
-mike
-mike
The Maryland law says any trailer 3000 pounds or over must have brakes. From what I've read, 3000 pounds seems to be the most common figure for brake usage among states.
Bob
My sense, is if you have a trailer like mine, in which the weight can vary by almost 2000 pounds, electric brakes would be better. The reason being, I believe with electric brakes you can adjust the amount of braking needed, depending on how much the trailer weighs at any given time. Less braking is needed with no load, whereas more braking power is needed with heavy loads.
Trailers that pretty much weight the same all the time, such as boat trailers, camper trailers, motorcycle trailers, etc., could probably get away with surge-type brakes.
Bob
As far as surge brakes...since the force of the trailer pushing forward (when the vehicle is braking) is what applies the brakes...wouldn't the force of the brakes be proportional to the weight of the trailer?
Bob
-mike
There is no braking on a surge brake trailer set-up when backing up, however its usually done at low speeds and therefore there is little load on the tow vehicle's brakes. Most modern surge brakes do automatically adjust themselves when backing up to continuously adjust for the wearing of the brakes pads.
If you're dropping your boat in salt water you will certainly increase the performance and longevity of your brakes by installing a simple flush kit that is installed on the back side of both brake plates and is attached with a fitting on one side of the trailer. This fitting can be attached to a garden hose to rinse the drums and pads of salt water before heading off on a long tow.
-mike
Interesting, the consensus so far is for surge brakes. IIFC, my trailer dealer preferred electric brakes, but I don't remember why...
Bob
-mike
I thought the "electric" part on electric brakes was basically an electrically powered master cyl up near the hitch - I didn't think it was anywhere near the axle, and, therefore, shouldn't preclude you from using electric brakes on a boat trailer. Am I wrong?
-mike
