Visitor Agreement.
Seriously, I see no advantage of doing that. I vote for sticking with the OE size.
See my post #307 and comments to Camryfan as to various tire choices. All will be less than $75.00.
Do you have a warehouse club membership?
Only someone who personally has had a set of the Pilots and a set of other tires that meet your desires can really suggest something.
I think it is the tires. I had the suspension checked and everything is OK. I am looking for possible solutions, other than trading the car.
Overall, the car is great and I think I just need a performance oriented tire rather than the all-season 215/60/R16 Goodyear Invicta GA.
Thank you community for your input - it is much appreciated.
Personally I think they are undsafe and should be pulled off the market.
I would give a set of Pirelli P6000 Sport Veloce a shot on your Lexus. They may be a little noisy for you but I think you will like the performance and the price. I think Pirellis because they don't spend much on advertising are one of the trur bargains of the tire world.
I'm now sure that a set of modern quality tires will improve your car greatly.
But I'd like to hear whether anyone thinks if a roadhazard warranty is worth the extra dough.
At this price, hardly a major source of profit for the tire dealership. Do not mind, though, if they will make a couple of bucks. Or $10-$20 for this matter. I like the dealer.
To me, it's one of those things that is a good idea as long as you are in a position to use it. For example, a travelling sales rep would be exposed to all kinds of road hazards and possible high costs to replace a damaged tire. They would be great candidates for the warranty. But what are the chances that person could get warranty service when they're on the road? Even with a national chain, would you be close enough to a store to actually use the warranty if needed?
Now, if you stayed close to home then the likelihood of having a damaged tire might be lower (this is hypothetical, of course). And if you did have tire damage, the chances of being close to a store that can fix it are higher.
So I guess its one of those dichotomies: The people that could really benefit from it stand a greater chance of not being able to use it. And the people who could easily use it may never need to.
Whew!! Way too much thought went into that~~~~~~~
Drew
Thanks for the advice in the past.
I did purchase the BF Goodrich Advantage Plus at SAM's Club for our 98 Minivan (215/70/R15). It appears to be the same tire as the Control TA M80.
The price was great, the service was good, and everything is running smooth. $280 for four tires with 65K warranty, road hazard, balance, install, tax and disposal.
I will be going back to Sam's when my car needs tires later this year.
Vezini
I have become interested in the Continental Contitrac SUV as they are available and $50 per tire less in price. This company is popular in Europe but need some comments from those who have used this brand.
David
Of course it's the tires. Are you kidding me? Lowering a Lexus? I think the spring kit available from H&R comes with a free gold tooth and a 10-inch subwoofer. Tweaking with the suspension would have no effect on your unsolicited yaw moments because the surface area of your windward side has not changed; nor has the pivot point of your front wheels.
Obviously you're kicking yourself in the rear for going from a BMW to a Toyota and expecting the same performance. Don't take it out on Bret; he's just trying to help.
You're right, installing a rear spoiler would not solve your problem at regular speeds, though an increase in downforce (and friction at the contact points) at VERY high speeds, would help. Unfortunately, most rear wings are purely cosmetic, and those which aren't don't go into effect until around 90 mph. If there were an aeronautical engineer in this forum, he or she would probably tell you that the only way you could correct this problem aerodynamically would be to increase longitudinal stability (not lateral), aft of your vehicle's center of gravity. Have you considered welding a five-foot vertical stabilizer to your trunk? You could attach the rudder to your steering wheel and use the trim tabs to compensate for continuous crosswinds on those long trips. Wouldn't that be great?
Or maybe you could just purchase some better (non-Goodyear) tires with more robust sidewalls, eh?
----Chris
Think of road hazard coverage not as a warranty, but more like once-and-done insurance. Every tire (except for blems and used tires) will carry a manufacturer's warranty against any defects (separated layers, broken belts, or other things resulting from improper manufacturing), automatically, just like a new vehicle warranty.
If your new car throws a rod, the vehicle warranty will cover it. Similarly, if the tire's tread layer becomes separated from the inner layer (ala Firestone), the manufacturer's warranty should cover the cost of replacement.
If you run into a telephone pole, your vehicle warranty will not benefit you, whereas your insurance will. Road hazard protection is the same type of covereage--protecting you aginst things that are not the manufacturer's fault.
If a tire is defective, the warranty should cover it; if you destroy a tire, it is protected by your road hazard coverage.
Anyone who doesn't purchase road hazard coverage is either a fool or a gambler. But the odds really don't pay off. I'd much rather pay $10 now than risk paying $80-$200 later.
--Chris
Yep, I drive a lot of Fords.
TG will give you the scoop between the Symmetry and the XW4 but check our Michelin's website also.
Chris
and Chuasan personally i go by what feels good. and how the wear looks. ive gotten to where i can feel a difference between a 2 psi difference in the tires and there is a handling difference notable. i think you should try out what feels best for you. and the front and rear do not need to be the similar psi. my manufacturer's suggestion is 29/29 but i have it on 32/27 because it allows for better turn in and road feel. and i started messing around with the tire pressure in the first place only after a conversation with an autocrosser frien of mine. but to answer your question. 32psi is a pretty standard pressure for cars. in many auto shops they even use 35psi as the standard when they check fluids and pressures or you. rarely will a shop look in the door jam for the suggested psi. you should be fine with the manufacturers suggestion.
Well, I am quite exctied about my new tires - Continental TouringContact CH95. I chose it because my friend's car has it and the ride is quiet and decent cornering. On top of that, it's affordable. I will post a comparison soon with my previous tire - firestone Affinity.
Ideas?
I can not find any info about this subject here. Please tell me if there's a guideline during the break-in period (if it exists!) Also, if it does exist, how long or how many days do tires need to break-in. Thank you
The worse thing about the break in period is that is when most tires handle the worse particularly in the rain.
Chris
Tire suppliers (like Tirerack) do offer this heat cycling at their facility before shipping tires (extra cost service). You need it only if you are going to mount the tires and immediately go racing.
i just got new tires yesturday but im not gonna bother.
I have four 175P65-14 SportIV H714 tires on my Echo. I bought the car used and the Toyota dealer put these new tires on it. I think they are made by Hankook, but that name is not on the tire.
I just have new tires mounted this afternoon. On the way back, I hear more tire noise than my previous ones (supposely new ones should be quieter!) Do you think the tireshop did a bad job on balancing? or I should let the tires "break-in" first? Do you have similar experience when you mount new tires?
Chris
personally, when i buy a tire i look to buy the best tire that is practical. the best tire means the best gripping tire for my weather and road conditions. i drive on paved streets in dry wet and occasionally snowy conditions. so i bought the best performing all season tire i could find, i also bought a wider size. i look at tires more for fuction. as long as it does it's job well i am happy. i would sacrifice a little quiet for better braking and cornering happily. hope that helps a little, good luck.
Can someone who own a 323i give me the tire pressure for front/rear tires. Also we would like to know what's the max. psi for OE tires. Thank you.
Chris
The max PSI will be molded into the tire sidewall. Just tell your cousin to read the sidewall to find it.
Recommended PSI can prolly be found at an online BMW club. I don't think anyone in here can help unless they have a '99 323i with the stock tires on it. I's imagine you'll get a faster response by asking BMW owners.
I bring this up because in yesterday's paper I noticed an article that said that some of the tires that Ford is using to replace the Firestones have a higher failure rate.
"Ken Johnson, a spokesman for the House Commerce Committee, said congressional investigators have analyzed the failure rates of replacement tires Ford is using, made by Michelin, Continental and Goodyear, and found some fail more often than Firestone's Wilderness AT tires that have been recalled."
In my years of driving, I have had a tire blowout, a tire disintegrate, and a tread separation, each in a different vehicle, and I never lost control of the vehicle it was on. I believe that this current situation with Explorers is a combination of driver error and the inherent properties to the Explorer.
I can understand a driver losing control of a vehicle that has a front tire blow out, but most of the deaths have been in cars where the rear tires had a tread separation. I feel that in many of these rollover accidents, the driver's reaction to the tread separation was more responsible for the loss of control than the tread separation itself.
There are two types of traits of the Explorer that exacerbate the problem: the traits that increase the chance of tire failure, and the traits that increase the chance of a rollover. The two traits that come to mind for increasing the chance of tire failure are the fact that the Explorers heavy weight puts more strain on a tire, and that Ford recommends relatively low tire pressure, which causes the tires to heat up more. Ironically, one of the reasons for the low tire pressure is to reduce the chance of a rollover by making the tires have less traction. The traits that increase the likelihood of a rollover are the Explorers poor handling dynamics (compared to a car) that increase the likelihood of loosing control, and the Explorer's high center of gravity. I would tend to blame the loss of control more than the high center of gravity for the Explorer accidents.
Any tire can fail, no matter what brand. If you are truly worried about a tire failure, I would suggest buying a vehicle that has a better chance of surviving the failure than worrying about the tire brand. (For example, a Sienna is certainly a better choice than a 4-Runner)
I can certainly understand the desire to eschew all Firestone tires, but there is no logical reason to do so.
Respectfully,
Tom
At this point, with all the publicity and attention to quality control, the Wilderness AT tires may be one of the best available right now..
It will be interesting to see the Explorer's performance with the Michelin, Conti, and Goodyear tires being noted as possibly inferior by one of our legislators..
The quality of Firestone tires is rather uneven (the same with Goodyear). Some tire models are between the best, other on the bottom. Impossible shop on the brands, only model by model. The user satisfaction surveys are available at tirerack:
http://www.tirerack.com/tires/surveyresults/index.jsp
I have Firehawk SH-30 installed on my Malibu. With the tires it is cornering almost like a sport car, in good weather and bad - it does not matter. The best model in the All-Season High Performance category:
http://www.tirerack.com/tires/surveyresults/hpas.jsp
On the other hand, the Firehawk GTA 02 tires made by the same manufacturer are the worst. The difference in price (215/60-R15 for Malibu) is just $7. This is less than $30 for all 4 tires, a couple of gas tanks. No brainer even would it not be one of the most important safety items!
The same with Goodyear: it produces both the best and the worst tires in the All-Season category of low performance tires, Aquatread 3 and Invicta GL:
http://www.tirerack.com/tires/surveyresults/as.jsp
Although I feel they are valuable for shoppers, one odd thing I've found is that tires that are OEM seem to get poor survey results when compared to a tire that is only available aftermarket.
Yurakm's post is a good example. The Firehawk GTA comes OE on Lincoln LS, some Saturn models, and the Mercury Cougar (I think). But the SH30 is aftermarket only and gets good scores.
Same with Goodyear. Those Invicta's have been OE on all kinds of cars but the Aquatread isn't.
I wonder why owners dis the OE tire (read some the comments on OE tires, they're pretty harsh) but love the aftermarket?
I don't know fer sure but I think it has a lot to do with expectations and the compromise mfr's have to deal with when choosing an OE tire.
Comments?
