I bought the car from a dealer, and the inspection showed not apparent problems.
I can buy a "Gold" extended warranty from the Lexus dealership which covers up to 2 yeras or 100k miles (whichever is first). The warranty costs about $1400, and seems to cover most powertrain and electrical things (though it is not the "platinum" bumper-bumper warranty).
The question is: Is it worth it to buy the warranty? What are the chances that I will spend more than $1400 in repairs for the next 16,000 miles?
Any thoughts/comments appreciated.
The Edmunds Maintenance Guide
Get information for other cars
Recalls
There are no Recalls for your vehicle.
Technical Service Bulletins
Check to see what service notices have been issued on your vehicle. The vehicle manufacturer typically provides information on what parts might need to be replaced or repaired.
28 TSB Report(s) for your vehicle
Next Maintenance Service
2000 Lexus RX 300 4 Dr STD 4WD Wagon
To learn more about a specific part, click on the name under Part Description. To learn more about how the estimated cost for a part or service is determined, click on the Part Cost or Labor Cost links.
Mileage Range
24,999
or less 25,000
to 49,999 50,000
to 74,999 75,000
to 99,999 100,000
or more
Service
75,000
80,000
85,000
90,000
95,000
Part Description Part Cost
Engine oil $ 13.25
Oil filter $ 6.60
Timing belt $ 44.60
Total Estimated Parts Cost $ 64.45
Labor Action Item Labor Cost
Inspect Air conditioning system $ 5.46
Check level Automatic transmission fluid $ 1.09
Inspect Ball joints $ 5.46
Inspect Body $ 2.73
Inspect Brake lines, hoses & connections $ 1.09
Inspect Brake system $ 21.84
Inspect Cabin air filter $ 16.38
Inspect Chassis & body $ 2.73
Check level Differential fluid $ 5.46
Retorque bolts Drive shaft $ 5.46
Change Engine oil $ 10.92
Inspect Fuel system $ 5.46
Inspect Fuel tank, cap & lines $ 2.73
Replace Oil filter $ 5.46
Perform Road test $ 5.46
Inspect Steering linkage $ 5.46
Inspect Steering rack $ 5.46
Replace Timing belt $ 169.26
Rotate Wheels & tires $ 16.38
Total Estimated Labor Cost $ 294.29
Total Estimated Costs
Total Estimated Parts Cost For Your Area $ 64.45
Total Estimated Labor Cost For Your Area $ 294.29
Total Estimated Cost (excluding tax)* $ 358.74
*This Total Estimated Cost includes the preventive maintenance items recommended by Lexus. The facility that services your vehicle may perform different, greater, or fewer procedures that can affect the cost you incur. For example, engine oil change and filter replacement are commonly performed by dealer and independent service facilities at special prices. These "special price" services do not typically include all of the additional procedures recommended by Lexus at each service interval.
Printer Friendly Version | Get information for other cars
Pete
?) that prevented the car from starting up normally. Supposedly, the fuel additive, used regularly, will prohibit that from happening. Also, I have to admit that I always buy the cheapest 87 octane so that probably doesn't help.
Pete
Mike
I have asked Lexus why this might be so and they keep telling me to go to the dealer for an answer.
I suspect its something they don't wish to put in writing.
Pete
Replaced the air filter myself using genuine Toyota part from irontoad.com. Fluid levels etc. were all checked as part of the included multi-point inspection.
Pete
Brake fluid flush. The brake system is completely sealed, it has to be to sustain the high pressures that it must.
Personally I think there is more potential for compromising my safety by having a third party mess with my brakes than there will ever be from extending the fluid useage for the life of the system components exposed to the fluid.
Pete
The heat died (again) last night so maybe she won't notice.
Midsized SUV: Lexus RX330
The RX330 is our top-pick midsized SUV. The refined and responsive 230-hp, 3.3-liter V6 and smooth-shifting five-speed automatic work well. Handling is fairly agile. Emergency handling is forgiving and secure, thanks to the standard electronic-stability-control (ESC) system. The ride is very comfortable. The well-detailed interior is as plush and quiet as in many luxury cars. The rear seat is roomy, but cargo capacity is modest. The rear roof pillars create a large blind spot. An optional rear-view camera that helps when backing up is bundled with the navigation system. The 400h hybrid version is expected to arrive in early 2005.
Pete
Any battery brand, model recommendations would be appreciated. I plan to replace now before a problem develops.
Expensive lesson.
My suspicion about all of this is as follows.
When the Prius was in design phase they decided to eliminate engine lagging torque during "coastdown" in favor of simulating the same "feel" using the battery charging braking regeneration system. Even today the Prius driver can manually select engine lagging torque or battery recharging.
And then via engineering "cross-polination" someone in the FWD design area realized that the same method, eliminating engine "drag" during coastdown by taking the transmission out of gear would result in improved fuel economy. They may have even realized that a side benefit might be fewer loss of control accidents in adverse roadbed conditions due to engine braking on the front drive and STEARING wheels.
I think we have pretty much confirmed that the hesitation issue only applies to Toyota/Lexus FWD models or AWD with front torque bias.
Now, my 01's gas pedal is directly connected to the engine so if I suddenly go WOT while the transmission is not in gear the only design choice they had was to put the thing in gear as quickly as possible.
Sorta like on my 300HP C4 applying WOT and THEN releasing the clutch. Burned smell from the area of the clutch.
My transmission fluid smells and looks burned at only 38k miles, this for a vehicle that has NO factory recommedation for transmission fluid, has a towing package, external transmission fluid cooler, that has never been used. I am seeing reports of transmission failures for my model years between 60k miles and 100k miles.
Anyone want to guess why my Transmission fluid is burned at 38k miles?
So, someone with e-throttle suddenly goes WOT in the same circumstance. The transmission firmware "talks" to the engine and says "wait" I need to get myself into gear and give the transmission clutches and bands an additional few hundred milliseconds to fully seat".
Seems, if true, a problem that could readily fixed in firmware, right?
NOT!
Before even one was shipped these vehicles were EPA qualified for a specific city/hwy fuel economy. What does the EPA say, or do, if the manufacturer, after the fact, wants to go back and revise the fuel economy adversely?
And possibly even more pertainant, what about the PR issue?
Now, I have heard that the hesitation problem in the 05 RX330 has been fixed, and please correct me if I'm wrong, but haven't I seen a posting wherin someone was asking why the MPG rating of the 05 was poorer than the 04 by only a MPG or so?
@ 75 to 80 mph; 23.5 mpg
@ 65 to 70 mph; 25.5 mpg
No apparent oil consumption. Wonderful drive, no "hesitation", terrific brakes, good torque power when needed, steering smooth as warm butter, quiet cabin. Set the RX on CControl at 79mph for long stretches of flat terrain and tach sat on 2250rpm. A few times on heavy climbs without CControl, engine shifted from approx. 2200rpm to 2800rpm; when climb decreased enough, the transmission smoothly shifted up to 5th. Morning window frost cleared with max. heater in a couple of minutes after cold engine start.
First local 900 miles of mixed city/freeway driving averaged 20/21 mpg.
Has anybody else turned a leased car back to Lexus before? What kind of charges can I expect to get hit with? What do I need to bring up to snuff?
The vehicle is 20,000 miles under the allotment, there are a few minor door dings (no paint removed) and the back bumper, which came powder coated, has been scratched up pretty well. Other than that the interior is fine, I've been respectable with the maintenance but I haven't replaced the tires (they have 40,000 miles on them)
Anybody have a conjecture what I might be looking at?
Pete
I was worried about that same thing when it came to lease turn in's but I found a way to get the excess wear and tear dragon off my back...
I simply tell them that I'm REAL close to leasing again with that current dealership BUT I'm still undecided as to what car I want and that I need a few days to think about it. Do you think they'll nickel and dime me on my lease turn-in if they have a potential future customer on their hands? Nah.
Once a week or two goes by (and after 27 calls from the salesman) I just tell them I found another vehicle.
Perhaps that makes me an "inconsiderate customer" but that's a topic for another board!
Happened about once a month over the last 6 months. Keep it running until engine temp rises, then all is OK.
Anyone have first-hand experience servicing the idle air control valve on a 2000 RX?
Lexus repair manual description includes draining radiator, removing throttle body, replacing throttle body gaskets.
I'd like to hear from someone who's been there, done that.
Any ideas on how difficult/easy this is and the price of the filter?
I believe you can get access to the filter by removing the rear seat.
