Chad
1. Any thoughts on replacing the spare with a matching alloy wheel? I found one at aaarims.com for $178 not including the center cap or lug nuts. I assume the spare would fit on this wheel, and that the wheel would mount on the door okay.
2. Should I call a body shop for an estimate on repainting the cover vs. ordering new? My dealer said the body shop would have to paint a new one to match anyway. The mark is right across the trooper lettering, with another big mark near the bottom of the tire.
3. Do you think if I'd caught the s.o.# that did this, that he would be alive to talk about it?
Thanks for any advice -
Drew
Nashville TN
Also, I also think the flashing light is the "major" warning and the constant one more of a "minor" warning. Thus, you shouldn't let this go. No doubt if I am wrong someone will quickly jump in.
-mike
-mike
Try a set of 235-85-16 tires for taller but not heavier for better MPG. Be sure not to get load range E those are for heavy trucks. A lighter load range will mean a lighter tire. Some tire stores can get tire weight information, you want a light tall skinny tire for max MPG.
-mike
About that tire cover - if the letterring is messed up I'm not too sure how they would fix that - they are not painted - probably have to replace the cover and paint to match -on the other hand I sort of like your idea of getting a spare alloy wheel - I think that would look really good too - sort of like the Jeep Liberty and Wrangler - for $178 that actually might cost less - depends on your deductible - be sure to use locking tire lug.
-mike
My spare is a fifth alloy wheel that I bought, with 265/75R15 tire on it. Of course with that size tire I can't use my spare tire cover, but it looks good without the cover IMHO.
Yep on the adhesive for the Trooper letters on the spare tire cover.
-mike
Steve
-mike
-mike
Anyone buy their 5th wheel from a reputable after market dealer? I assume a wheel is a wheel - but our dealer charges $350-400 for the 12 spoke limited wheel, vs $178 I found on my first online search.
Thanks-
Drew
To confirm, Feb. 2000 is the build date on my '00 Ltd. - w/ a factory 12 spoke alloy hanging on the rear door...for whatever reason.
Addendum: Not realizing that an alloy spare rim is not standard, I'm not divulging my Troop.'s color & keeping the hard shell cover on....heheh.
Anyway, the naked spare tire would look a lot better with an ISUZU spindle cover, too. Any ideas where to get one other than the dealer? BTW, I think the uncovered spare makes the truck look better. I wonder whether it's bad for the tire, though. UV rays and all.
On another topic, is there a way to reprogram the keyless entry to it doesn't beep when you lock/unlock? My wife's Toyota's lights flash. Much better in a lot with lots of people walking around.
-mike
Thankfully the thing is plastic, if it were fiberglass or metal, it would have been dented or cracked.
Drew
-mike
Chad
That and Isuzu is selling its interest in the Subaru plant means only a short while now and our Troopers will be orphans like the legendary International Scouts.
If the cover can't be buffed out, I would paint it myself. It can't be that expensive. I have painted enire cars for $30. to $50. and they looked great. I wouldn't pay anyone more than $75. to paint it.
I have a 1999 Trooper it's been to the dealer four times and the only item they found was a faulty mass air sensor.
I have also had it only when shifting to "Park", and before I shut the ignition off, but as long as I left it in drive, it will run fine.
Let me know what you find out.
I can't remember what the code was for now, but was told if it happened again they'd put in a new transmission, no problem (48K miles at the time). Of course, no check engine light since.
As for spare, steel wheel, built around August 1999.
P.S. Love the vehicle so far, it's very solid and spacious.
-mike
One of the reasons I bought my brand new 1984 Trooper is that I wanted the room inside of a van and the off road ability to have fun finding remote fishing on rivers in the mountains. I describe the space inside the 1984 (and my 1995) as almost large enough to park another Trooper inside.
I never towed with the 1984 1.9L. I tow a lot with the 1995 3.2L and I am happy to say that based on my experiences (towing my same trailer with a full size GM conversion van handling was way worse than with my little Trooper) and stories from this discussion and other discussions about trailering that the 1992-2002 Troopers tow like a much larger truck.
Trooper only takes as much parking lot area as a Toyota Camry car and yet it does holds so much and tows so well it is amazing.
-mike
Refusing to pay Isuzu $569 for the 30K service on our 01 LS I had the transmission filter and fluid changed for $35. The transfercase and both differentials changed - plus limited slip additive for $99. I asked them if they did bearing repacks and their mechanic asked if the Trooper was a 4X4 and quoted $60 for both front bearings - he seemed familiar with Troopers - next months it will be done. I had this service done at Skill Lube one of the local Quick Oil Change services here in Alabama. Skill Lube had all the Trooper fluid change specifics in their computer data base.
-mike
I asked my dealer about it and he said wait until you need new brakes, it is only like $10 to do along with a brake job.
