Visitor Agreement.
P.S. I always start from the simple solutions and go from there.
-mike
Paisan posted earlier keeping the TOD fluid clean, feel free to laugh but is that the transmission fluid??
I'm not sure why the sensors aren't part of the drivetrain, I think Isuzu gave you a line of BS on that one.
-mike
The book states if the TOD fluid is low it may cause the light to come on. (I found this under "automatic transmission").
Where and how do you check the TOD fluid?
Per my entry last night I meant to say I have a "99" not a 98.
Thanks, or should I say "Mille Gracias!"
-mike
Personally, I would be reluctant to buy a vehicle with a problem like what you described. It could be something very minor, but I would rather agree on a price for the truck with a provision that they resolve the problem first.
What kind of maintenance documentation is available? If the differential, transfer case, TOD, brake, power steering, coolant, etc. fluids have not been changed at least once or twice on this truck, that's not a good thing.
Proper maintenance is worth paying for when buying a used vehicle, especially an SUV which has more complex mechanicals than many cars.
Thanks for your patience everyone.
Yes - I can't change the color of text but bold and italics work fine.
Town Hall New Look!
thanks for your input on my decision on 98 S for $ 6995. the dealer will do alignment on it so I can test drive again to see if the problem still exist. In the meantime, can you think of any reason why the front wheels vibrate especially on highway speed?
...they were also supposed to check my brakes, but that is another story.
Although weather may have played a part in the early retirement of my speed sensors they did not quit until after my 8 hour summer trip. I hate to say it but...I take care of my truck with the exception of pulling a boat several times a summer.
What about heat build up from breaking? Possibly the extra friction created while stopping with a load (boat) builds up extra heat causing the sensor to overheat.
I am going to get my bad sensors from the shop for my own investigation.
Be sure to let us know what your post-mortem turns up (e.g. bad connections? burnt circuit board?, or ?). Also, ask your shop if the ATF level in the TOD is low. A low level would add to the heat generated by the TOD. It would also help validate the heat theory/give all of us some incentive for checking our TOD fluid level.
-mike
Almost all the TOD problems I remember were SOTF related. The few speed sensors I have read about, other than yours, ALL happened in hot weather.
You can safely increase the tire size a decent amount without any rubbing issues.
Note: the search feature wasn't working about 30 minutes ago when I tried it.
-mike
I agree that if you run with low fluid and a functioning TOD, it will get hotter than if the fluid is at a normal level.
Tom
However, I have noticed that if I engage TOD after driving for a while, there is a noticeable clunk, which was attributed to heat differences between the rear driveline and front...hmmm I guess I don't know.
-mike
It'd be kinda pathetic (and costly for some) if it became a widespread issue...
"Every single "check TOD" example i've seen across all the boards I monitor have to do with Wet/snow combined with cold weather."
-mike
Question, I've put Amsoil synthetics front to back, but think I may have missed something. Is the TOD unit the same as the transfer case? You can laugh all you want, doesn't bother me.
Unfortunately, the owners manual (at least for '98 Troopers, and probably '99s as well) is very confusing in this regard, probably because it describes both TOD and shift-on-the-fly Troopers and isn't clear on the differences.
You might try a search on this topic or the Isuzu Maintenance & Repair to see what you find.
All newer 4wd Trooper also have a SOTF unit. That is the thing on the front driveline on the drivers side.
That's also why your mileage improves when TOD is not on; there is no excess energy being expended to turn the front driveshaft.
I am unclear whether the front halfshafts are permanently connected to the front wheels. If they are, adding manual hubs to the system would disengage them. However, I fail to see the reason for having hubs in there at all if they never disengage. My guess is that the front halfshafts do not spin unless TOD is engaged.
Tom
Tom
-mike
-mike
I didn't consider another because of the GM "take-over". No offense, but I am not a fan of GM or anything they touch. But I do miss that vehicle.
Happy motoring! (or is that trucking?)
P.S. I have read on other sites that many have gotten a slight increase in fuel mileage by using synthetic oil.
