To make a long story short, my father-in-law who is the main driver of the car told me that this happened to him a few times and the way to get the car to start is to push this tiny button under the steering wheel while turning the key. In our Jimmy, the button is located to the left of the steering wheel, right above the connecter plug to connect diagnostic equipment. You won't see the button sitting at the steering wheel, though, you will have to kneel on the ground next to your driver's seat and stick your head in where the pedals are to see it. Anyway, once you find it, simply hold it down for 15-30 seconds and then turn your key normally to start the engine.
Good luck!
Brought it to the mechanic with suspicion of a transmission problem (slow to start up from stop and seemed like I was pulling a tractor trailer behind me) also suggish when trying to pick up speed when merging into traffic. Plenty of rpm, just not much reaction.
The "check engine" light came on last week (why I brought it to mechanic) and he put it on the computer and said there was a "selenoid code" showing up. I then took it to a transmission place but his computer showed NO code problem at all. Of course, he was more than happy to pull the transmission and rebuild it.
But,,,a couple of other weird problems have just developed in the past couple days. Yesterday, when pulling out of the driveway, all the gauges when to flat or "0"; gas, speed, oil, everything. Battery seemed fine and when I restarted the car a few minutes later it was fine. Also, the wipers tend to stop in mid-swipe every once in while, for about 20 seconds, then start again. This happens erratically, not like the normal time-delay option.
Right now the car is still under warranty with C.A.R.S. but only for another 400 miles or so.
Could this be a computer or electrical problem and not the transmission at all??
thanks for you help!
rick
I finally found a GM document that addresses the drivability issues I am concerned with. ID# 1561407 Front axle grind whine noise in 2wd gone in 4wd.
Date Oct 29 2004
I am a little miffed that after two months the truck is still at the dealer and both TAC and the dealer could not look in their own computer and find this document.
The document says to confirm the noise is coming from the front diff, check the ride height and if all is okay, replace the carrier/case assembly, spider gears pilot bearing thrust washer and right axle bearing. They already have replaced the axle and axle bearing.
Everything is still under GMPP.
hopefully this fixes it....
PLS HELP!!!
Can anyone tell me where the interior lamp control module is located on this
vehicle. I went to the dealer and they said it was under the lower center of
instrument panel but there is nothing there but the flashers. I did find one box
on the left side of lower panel but it has an FCC ID number on it so I don't think
that's it.
thanks for any help I get..
GM Blazer/Jimmy/Typhoon/Bravada 1983-1993 Repair Guide
FOUR WHEEL DRIVE TRUCKS
When necessary for access from underneath the truck, raise and support the vehicle safely using jackstands.
1. Disconnect the negative battery cable.
On some vehicles access to the wiring may be easier from above. Before raising and supporting the vehicle, check to see if the solenoid wiring is accessible. If so, tag and disconnect it at this time.
2. On 2.5L engines, remove the brush end mounting bracket from the starter motor.
3. Tag and disconnect the solenoid wiring.
If the wiring is difficult to access with the starter installed, remove the bolts and partially lower the starter for access to the wiring. If this is done, be careful not to stretch or damage the wiring.
4. If not done already, raise and support the front of the truck safely using jackstands.
5. If equipped, loosen the retaining bolts and remove the skid plate.
6. Remove the retainers and the brackets holding the brake line to the crossmember located just behind the oil pan. Reposition the brake line slightly in order to clear the crossmember.
7. Remove the crossmember retaining bolts, there are usually 3 on each side, then carefully lower the crossmember and remove it from the vehicle for access.
8. As applicable and necessary, remove the bracket holding the transmission fluid cooler lines to the flywheel housing, brace rod to the flywheel housing and/or the lower flywheel housing.
9. Remove the starter-to-engine block bolts. When removing the last bolt, be sure to support the starter to keep it from falling and possibly injuring you.
On some vehicles, even with the crossmember removed, clearance for starter removal is tight. As the starter is lowered, it may be necessary to rotate it upside down in order for the end to clear the motor mount, then lower the nose behind the bell housing and rotate it back so the solenoid is on top and the starter may be removed.
10. Carefully lower the starter and shims (if equipped) from the vehicle.
To install:
11. Position the starter in the vehicle (along with any shims which were removed) and support while threading the starter mounting bolts. Tighten the starter mounting bolts to 30-33 ft. lbs. (40-45 Nm).
12. If removed, install the lower flywheel housing.
13. If equipped, install the transmission cooler line bracket and/or the brace rod to the housing.
14. Install the crossmember to the frame and secure using the retaining bolts.
15. Carefully reposition the brake line and secure to the crossmember using the retaining brackets.
16. If equipped, install and secure the skid plate.
17. Remove the jackstands and carefully lower the truck.
18. For the 2.5L engine, install the brush end mounting bracket.
19. Connect the solenoid wiring as noted during removal.
20. Connect the negative battery cable.
melts all over the place. I'd just like to find a "new" wiring harness and install a new wiring harness on my Jimmy. Does anyone know the best place to purchase a wiring harness for my truck? Thanks for any and all help!
Kirby Martin
Dallas, Texas
kurbster@swbell.net
I just replaced the A/C Controller but the same problem returned back two days after.
help will be appricated
thanks :confuse:
They said it must be a coincidence that something went wrong with at least one of my tires within the past week and has nothing to do with the brake work they did. There was about 3 or 4 days before and after getting the brake work done where I didn't go above 90km/h so I don't know for sure if it happened on the day they fixed the brakes. Anyways, they think that the steel belt in one of the tires must have slipped a little and all I could do is buy a new set of tires.
Can anyone tell me of anything else that may be causing this vibration and specifically if there's something that may have happened by putting on new rotors or pads?
2Hi, 4Hi and 4 Lo all work. However, when in Auto 4WD, there is a shudder from underneath when starting from a dead stop, turning left or right from a dead stop, and when coming to a stop. I have know idea why 4hi works perfect, and Auto 4WD does not. I just changed the fluid in the front and rear diff so the levels are fine.
ALSO......is it normal for the transfer case to seem to slip when operating in 4 Lo when starting off. Today was the first time in 6 years i tried 4-lo, so i don't really know how it feels in comparison to other 4WD's. My 1981 Jimmy never did that in 4-lo, but its ancient compare to this one.
I bought a 2000 4X4 Blazer about 6 months ago. The car has been great, but about 2 weeks ago, the exact same problem you describe started. Did you ever receive a solution to this problem?
HELP... I REALLY NEED SOME HELP!!
It shifts from 1st to 2nd with no problem and reverse is no problem either but when attempting to go into drive its like it goes into a neautral state.
What should I look for before going to a garage?
I brought it in for service in February. I told the service manager that no non-covered repairs should be started until he called my husband and discussed it. It needed upper and lower ball joints (again), and a hub bearing assembly (again). Dealership also noticed a leaking lower intake manifold gasket. (I verified that the part number on the invoice was for the lower intake manifold gasket). All work authorized by us. Total bill was $1011.22 (the intake manifold gasket was $328.00, of which $229.00 was covered by the service contract.) We were not charged for flushing the coolant system or replacing coolant, and we were not charged for an oil change.
2000 miles later, the #6 rod bearing spun. The engine is a total loss. The service plan company requires a teardown, which we authorized because the car was well maintained. Coverage is denied because inspector found a radiator that was partially restricted with rusted Dex-cool, and because he noticed “fairly new” oil and oil filter, and claimed the oil was changed after the breakdown.
There is no oil visible in the coolant, or coolant in the oil. The oil was checked weekly, and was never low. The oil was changed a week before the bearing spun, and was not low then. The oil was not low after the bearing spun, and even when we heard it start knocking, the oil pressure gauge was OK. The temperature gauge was fine, too.
(We checked the coolant level in the reservoir tank at every fill-up, as required by the owner’s manual. It never needed a drop added. Why? Because the hose from the tank to the radiator was completely blocked with rock solid dexcool. Because it looked so perfect, we never opened the radiator cap.)
We look at the car after it’s been towed to independent mechanic’s lot. Take off
the radiator cap, and it’s disgusting, much worse than any pictures of dexcool contamination I’ve seen on the web. The radiator itself is equally bad. The first thing I do is ask the service manager at the dealership why they didn’t flush the coolant or replace the cap, since they MUST have seen the horrible condition of the thing when replacing the lower intake manifold gasket. (I don’t think you can replace that gasket without losing coolant.) He said the radiator and cap were fine at that time, and we weren’t charged for coolant because they poured the old stuff back in. Well, one thing I am sure about is that that level of contamination didn’t happen in 2000 miles. No way.
Questions I am desperate to have answered are:
How did they manage to replace the intake manifold gasket without noticing a BIG problem with the coolant? If they saw it, shouldn’t they at least have said something or noted it on the invoice? (I have pictures of this stuff, and I’m not exaggerating, believe me! I don’t know how to upload them, but I can email them)
Is it even possible that they didn’t replace the gasket at all? That would explain a lot (like why I wasn’t charged for even a gallon of coolant), but would be unbelievably dishonest. Who would do such a thing for a measly $330.00?
If the car overheated, it did so without registering on the gauge, without smoke or smell, and without significant heat damage to the engine. If there was a lack of lubrication, it wasn’t enough to register on the gauge or leave the car low on oil afterwards. So what happened? What could have caused this?
At least one bearing shell (is that the right term?) is badly scored, with little scratches all over the place. Could that be significant?
Are there any labs that will run tests on an oil filter, so I can prove the filter was there when the bearing spun? The oil is long gone, but the filter is still there.
How can I find an ASE certified mechanic that is experienced and honest and impartial to take a look at this thing and maybe suggest alternative causes? If I could find someone like that, how much would it cost? I live just south of Boston. If anyone has any suggestions or recommendations, my email is adhd@speakeasy.net.
I would be forever grateful for any information or insights you might have about all this.
SusanW
Thanks,.
