In researching places to do it - I bought my 99 Blazer 4x4 4dr from a used dealer so no warranty - I was asked if "it is welded" because if it is I'll need to take the truck to a body shop.
Now, the hinge appears to be welded to the frame, but the pin and bushings aren't. Will I be coughing up extra cash to get the pin and bushings replaced at a shop just because the hinge is welded? Call me naive, but can't they just hoist the door up, hold it suspended and swap it all?
Help!
57,000 miles on it.
I purchased my Blazer at a dealership used. About a month (if that) later my mom tried to recline the front passenger seat and it snapped off in her hand. Since then, the door locks (electric) the button in the car will not work, my hatch button does not work (both on the inside and outside of the car, the rear wiper blades only work sometimes and when they do, they sound possessed (it scares my 3 year old!) The lights on my radio are slowly but surely dying, and my gas gauge just dances around so I have to watch the trip meter for mileage (hopefully that doesn't break next)! My front driver door hinge broke, and my heat only works occasionally. Probably am forgetting something, but hey, this seems like enough problems for my first post
And after reading your post, I am scared because I am just over 75K miles, so does this mean my front wheel bearing is next?!?! OH and my AC is funky too.
Any suggestions would be wonderful!!!!!
THANKS
Amie
Amie
I've run into the same problem. I went down to the part store today and picked up some replacement pins and bushings.... The only problem is.... That stinking spring underneath the top hinge pin.... I'm thinking that the entire hinge is mounted to the vehicle as well. Tell me how your experience goes. Back to the garage for me...
Also has any one noted that after cleaning the fuel injectors (about 2 weeks or so) the fuel pressure regulator has to be replaced (which isn't fun on my v6 because the air intake manifold (plenum) has to be removed and torked back on! I have a manual that states don't run solvent through the fuel pressure regulater or it will destroy the diaphram. A sign the pressure regulator is going is excesive cranking to start the engine. Ive approached the shops and they say we've never heard of this happening but what a way for return business at $200.and up?
Is there something i can do like splicing wires or something or do I need to get a new motor?
thanx.
cold in buffalo.
Or, take it to the dealer and fixed in 1 hour.
thelush
I changed the relay on the firewall and the climate control unit in the dash. No luck.
A check behind the fuse box, (boy, that bezel is fun to get out), with a tester proves the number 6 fuse position is now hot all the time. I'm thinking something is shorted out and maybe getting some feedback into the circuit.
The vehicle has 165000 on it, and what I'm reading in this forum is making me wonder if it's time to peddle it. It still has the original heater core and I'm not wanting to pull the dash out. Just call me lazy I guess. By the way, I wondered why the antifreeze looks like sewage. I flushed it a couple years ago, but it's still not pretty. No more Dexicool for me.
Any help would be appreciated. Waynezo :confuse: ">
http://www.automotiveforums.com/vbulletin/showthread.php?t=503195&highlight=heat- er+blower
I'll report back. I've already got it partially resolved, but my wife NEEDS the computer now. Later. Waynezo.
Visited the link you advised. WOW! This guy knows his stuff.
The featured problem child Blazer he wrote of is a 98, but I'm sure it's basically the same. I'll check out a couple things.
Here's what I did before your post.
Tested the fuse block and switched the brown heater wire to the radio circuit. Vwalah, the heater fan now shuts off with the ignition key again and everything works like it should on the heater control.
The problem seems resolved, but I'm concerned that there's still a short somewhere just waiting to burn me down. I need to take some time with the wiring diagram.
Another benefit of my labors is the fact that the service engine soon light is now back off. Don't know if it's related to the current situation, but the light has been on so much since I've owned the vehicle that after awhile, you tend to ignore it. I'm told that black electrical tape over the light fixes lots of problems too
That's it in a nutshell, any further input would be appreciated.
Sincerely,
Bill, NJ :confuse:
new tires,shocks,and and idler arm. Is somwhat better
but still has vibration from 60 and up. Small imperfection
in the road makes it worse. Were you able to get rid of
the vibration in yours.
I somehow managed to get my arm up over the torsion bar then squeezed my hand between the floor pan and the tranny housing and found what I think is a dust cap. I slid it back on the line and noticed that the clip is still in place.
I had my wife start it up (while I had had morbid thoughts of her forgetting about the task at hand and going into a shopping flashback and running my greasey [non-permissible content removed] over!) what I saw was a steady leak from where the line it-self went into the fitting.
Will I have to replace the whole line? Or if I use a pick and remove the clip will the line slide out? And will there or should there be a O-ring to be found/replaced? And do I need to break the (what I think is a) 11/16 fitting loose?
Jeeezzz.... I hope I'm allowed to ask more than one question,....
Any ideas or suggestions would be great, and allow me to get back to my beer!
Thanks, Bob :sick:
As for the brakes, the rears on yours are drums so about 75-90% done by the fronts. Have them all looked at ASAP.
then it may be as good as it gets. If the shake is in the seat (of your pants) look at the rear. My 01 had out of round rear disc/drum that hopped over 60 - the disc was round but the parking brake drum part was oval. Also look at the drive shaft u-joints and balancing the drive shaft (about $100) for all if you pull it out yourself.
