Visitor Agreement.
According to Edmunds, the Sequoia is "Structurally identical to the Tundra from the front doors forward." Although the Tundra did pretty well in the IIHS test, it didn't fair so well in the NHTSA tests (3 stars frontal ratings on both sides).
Anyone have thoughts about how this would apply to the Sequoia?
Thanks in advance.
I've got one of the "tickers"....in my drive to appointments yesterday, i noticed that the ticking went away when i played a cd! ticking only seems to come on when am or fm is on, not tape or cd...leads me to believe that it's a wiring/grounding/antenna problem? i wonder if ticking will permanently go away if i replace the antenna...
The barbed tabs that snap around the metal piece at the end of the belt did not seem to be damaged, but it also did not appear to be a very secure attachment. I've been tempted to fuss about it, but thought I would wait and see how big (or frequent) a problem it becomes.
1. In 3032, vondrlm1 mentioned that he pulled the female sleeves out of his trailer wiring harness connector. Well, guess what I had replaced at the dealer today. Yup, same problem. Cheezy connector if you ask me. I asked for the old part (to make a reliable spare), but the dealer said they had to send it back to the factory to get warranty credit.
2. In 3038, minuteman26 mentioned a couple of things.
First, that the new SR5 4x4 caster alignment specs improved the highway ride, and I want to concur. The vehicle was unstable at 70 (and really pulled with the wind) prior to realignment to the new specs, and now is solid as a rock.
Second, he indicated that he couldn't find any touchup paint for his bumper. Most SR5's (except black and ??) have "Warm Silver" bumpers and trim, and the paint code for that color is UCAD7 (PN 00258-UCAD7 for a 14 ml tube). It took me quite a while to find that -- the paint books weren't up to date, and we had to look under a Sienna. I tried it and it's pretty close.
3. Thanks Cliffy -- I never looked at my spare. I just assumed it was steel, but it is alloy, like the others.
4. My gas mileage on long trips jumped abruptly from 15-16 mpg to 17-18 mpg a few months ago (all in 4WD mode). Good news, but WHY? Possibilities:
-- The vehicle is broken in now.
-- I switched to synthetic oil.
-- Summer gas gives better mileage (no ethanol)
-- I run the tires at 35 psi instead of 32.
-- All of the above ?? Any opinions??
5. Cliffy -- Can one "extend" an extended warranty by paying the difference (i.e., from 6yr/60K to 6yr/100K)? I am putting on miles much faster than I thought I would! Boy is this thing fun...
6. I am thinking of switching to load range C tires when the Bridgestones die. My current pick would be Michelin A/T LT275/75R16's. Does anyone know (or would like to speculate) whether the 275/75 would rub either the wheel well or the mud flaps, and would they fit the spare well? My backoff size would be 265/75's.
Is there any reason to believe that the difference in the frame of the Sequoia would improve the crash test results?
My physics may be a bit rusty so if anyone wants to add to this, please do so. I formulate the following:
p=m*v where
p=momentum
m=mass
v=velocity
Assume skimmel is correct when stating that the Tundra and Sequoia are structurally identical from the front doors forward. Therefore, with an increase in mass, additional momentum would cause additional or more damage. Is there something I'm or you're missing?
Really need to get answer to piston slap problem. Friend has Sequoia and we read the oil burning problem and piston slap of the female owner on the site above and need to find out how problem was solved short of new pistions/re boaring cyclinders.
Thanks in advance
David
I generally don't get extended warranties, but since this is the Sequoia's first year, it is made in the USA, and the warranty includes off-road coverage (including towing), it seemed like a sensible thing to do. One breakdown behind Elephant Hill near Moab, and the towing fee of $1,500 + miles pays for the warranty several times over.
Not that I want or would encourage anything like that to happen -- I am generally very careful, and am not even sure the Sequoia would fit the narrow "slot" on the way in from Elephant Hill, but all it takes is one engineering underestimate or manufacturing cost reduction (like the plug on the trailer wiring harness) ...
As for whether it is 8 years or 6 years, at the rate I am burning miles (12k in 6 months), it won't matter! Maybe the winter will be less.
I don't have the trip computer, so I have to do mileage on a tank-by-tank basis, and on long trips that works just fine. What the trip computer would tell you (and would be very interesting) is the difference in mileage between 65 and 75, and between a 20 mph headwind and 20 mph tailwind.
Perhaps the Sequoia's cavernous interior makes an excellent resonant chamber for your driving condition.
Crack open another window and the problem will go away. It's really simple.
Or, have I just figured out how to do it more efficiently without realizing I've adapted to the machine?
Some of the alleged piston slap and ticking problems were "solved" by insulating or padding some fuel injection harness or something like that. But check the Tundrasolutions.com for yourself to find more definitive information.
It's terrible that the service department was denying that the problem exists. As a result, I'm without wheels for a third day.
Also to OBYONE #3280, it is a little simplistic to say that the Sequoia will do worse in a crash test just because it is heavier than the Tundra. You are not taking into account the possibility that the overall vehicle is stronger or stiffer due to the increased strength of the larger body/box behind the front doors compared to the Tundra. I don't know that this is actually the case, but you can't just look at weight alone. In many ways, this is a different vehicle.
That would make my day. I'd snap mine off and ask for a whip replacement.
A properly charged and performing A/C should have duct temps between approximately 40degF and 60degF with ambients of about 70deg and 85 deg respectively.
I have noticed after my A/C gets cold it has a duct temp of just over 40, so you should expect the same.
Suggestions: You might run is Auto and not to see if there is a thermostat problem.
Did you check the sight glass?? After the A/C runs for 10 mins or so, there should be no bubbles or foam it should be clear. When you turn off the A/C it might foam a little and then get clear. This would indicate a perfectly charged system. If the sight glass stays clear, it might be overcharged.
They are probably looking at guage pressures and seeing them in spec, so the next step would be to look at therostat calibration in the cabin, there may be a sensor problem, etc. Also the hot/cold temp valve may be bad.
It doesn't sound like you service dept did a complete troubleshooting job, you might go somewhere else.
Good Luck
I'm taking this matter directly to Toyota next, as the dealer and their managers do not seem able to solve the AC problem. It's disappointing that the truck only is four months old and has about 1700 miles and already has problems that can's seem to be fixable by the service dept.
Then again, another salesman told me today that I could not order a 2002 until Sept/Oct. while a different dealer told me I could order one now, but he did not have a whole lot of details on options,colors, changes, etc.
Somebody help me!
The technician never was able to explain why a new Seq. at the dealer that I've tested was able to put out 43.9 deg. while mine was only able to put out 58 deg. under the same condition.
If anyone actually takes accurate temperature readings of their AC, please let me know what your readings are for max cooling mode and outside temperature and humidity.
If the Technician was truthful about the poor performance of the AC on Sequoias, I think that potential buyers of the Sequoia should consider very carefully about this AC weakness before buying one.
There isnt really a good reason why you should not be able to get that output colder. Even converted freon systems do better.
Good luck
Did I miss anything while I was out?
I once had a skipper yell at me during a sailboat race, "Baldwin! Ya keep standin' there you're gonna be singin' soprano!"
I had straddled myself over the jib sheet during a manouver. Fortunately I'm still singing base.
Bringing it into the dealer to fix.
NL
