and its due for maintenance.What kind of maintenance work i need to do for my car?
I'd love to hear about what people are paying for the 4cyl and v6 models around 2001-2003. Is it true that if i waited until around november the price of a new 2004 would still be around the same as a 2003? I'm super cheap like that and would appreciate any suggestions on how to get an awesome deal.
Joel
It's your alternator. Common problem. Should be a cheap fix.
-mike
Their deal is actually a bit too good so I was wondering if anybody used them. Also any suggestions about extended warranty for 2001 Rodeo LS 4x4 will be appreciated. I got about 41K mi right now and need to start thinking more serios about it.
Joel
-mike
Joel
Gang
Thanks for your help.
Also, anybody knows if 4WD components are covered under powertrain warranty? The manual is not too specific about it.
-mike
Anyways, I was using 4wd two weeks ago, about a month ago and up to April in Winter. I know it was working fine during winter because I was able to drive in really bad snow storm that basically shut down Denver for 3 days. However, all three trips to lake beach that I had this summer, even though I was using it extensively, I don't know if it was working right. I didn't get stuck during my first two trips but I had troubles pulling my friend's subaru from the sand while early 90s Pathfinder got me out very easily. Considering the fact that SUbaru was much lighter than Rodeo and wasn't that badly stuck it makes me wonder if 4wd was actually working.
Also, when I was pulling Subaru and when I was trying to get out on rear wheels this last weekend I had a HUGE vibration occur when I was revving up. It only took place when I was on 4Lo. I was barely mooving, or should I say I wasn't really mooving but rather digging myself deeper into the sand but the car would start vibrating so badly that I had to stop and try again.
The problem is that I doubt they'll be able to duplicate the problem as I haven't seen a dirt ditch next to them to test 4wd :-)
Hmm if there is a vibration, it could be a transfer-case, in which case, it would be covered under the PT warranty. Bring it to the dealer and see if they can diagnose it. It could be something even simpler like a fuse.
-mike
Joel
BTW, are the front tires independent fron each other? I mean I understand there is not lockable differential on the front axle but if, say, left front tire starts spinning, will the right one still be rotating or it'll just sit there? On the rear axle both of the tires were spinning independently so I was just wondering it the front ones are like that too.
I will drop it off at the dealer today and let them take their time. It's still under Bumper-to-bumper warranty anyways so I'll let them figure it out. I'll mention SOTF actuator though...
Joel
-mike
Anyways, I got a call from Courtesy Isuzu today. They told me that whoever did 30K service (Midas) didn't do the repacking of the bearing right. THe very first thing they noticed is that the right axle is very loose which cause the ugly noise that I complained to them about and possibly the 4wd failure. What happened is that they put the parts that were supposed to go on the right side on the left and vice versa. Here's what the official diagnosis read:
"Axle clips misinstalled from bearing pack causing clips to come off of axles - axle nut retainers misinstalled - need to R&R right knuckle and clean out bearing and repack both side wheel bearings."
I went to Midas and even though they were not too happy to see me they immediately offered me to have Isuzu put the truck back together and get it to them so that they can fix it right this time. I told him that I don't have any personal problems with them but I'd rather have Isuzu fix it up this time but they will have to reimburse me (about $400). I can't say he was thrilled about it but said he'll take it to corporate and will see what he can do. I asked Isuzu to get an oficial estimate done for me and will ask them to fax it to Midas first thing in the morning. What concerns me is that I've heard that there is a law in Colorado that I must give the original repair facility a chance to fix what they messed up. However, I don't know if I can trust them this time and I don't know if Isuzu can check their work if I take it back to them after Midas fixes it (if it gets to it). Now, I don't know if there is such a law for sure and I don't think i'll have enough time to find that out - my Prepaid Legal Services takes 2 days to get back to me :-( Anybody knows about Colorado?
I specifically asked Isuzu if axles or hub are damaged and they said no, which is a good news but if I do have to take it to Midas I will probably have to face inspection fee and towing (I have absolutely no intentions to drive it with axle barely in place). Hopefully I can get Midas to reimburse me for those expenses. Hopefully it won't get to it but anyways... That's where I stand at the moment... I'll post more as situation progresses...
-mike
I saw posts in Jan 03 by xcokeman, paisan and nato1 which sounds similar, but no note on the temp factor. Any clues?
-mike
First of all they don't come in original sizes so I have to go with 255-70/16 instead of 245. While I don't think it'll be a problem I wanted to find out if anybody have any experience with it.
Second, how do they perform in off-road conditions? I don't do any serious off-road but I do like to be able to drive on the beach or on some moderate off-road sites. They don't need to be really high terrain tires but something comparable to original Dueler. Also, most of my driving is highway driving so they must have a nice ride at high speeds on good pavement.
Any comments?
-mike
-mike
-mike
Joel
I'd get an isuzu part for the replacement and call it a day.
-mike
I have a 98 rodeo with a 6 disc in dash changer. Recently it stopped working, gives me ERROR 3 msg,( although sometimes it does read the disc and plays it) when I took it out of the dash and unplugged it and plugged it back in, it was working until I screwed it back in to the dash. Does any more have a clue what the problem could be? Could it be the wires or something of that nature?
Joel
