It is most likely,speaking from knowledge and exp.your fuel pump is a motor and the longer you run it the hotter it gets and obviously heat makes things expand so what your expieriencing is the built in check valve has expanded ,and/or distorted therefore letting fuel pass back to the tank when the key is off ...next time try
,when it happens turn the key to "on" not crank
for 5 seconds three times and see if starts right up
if it does the problem can be easily fixed by replacing the fuel pump assembly with screen...good luck
A few months ago I posted about two new shredded belts. I happen to put a used belt on my 92 rodeo and the shredding stopped. But my new belts were shredded after about 2 drives along the ribs. The shredded belts did not shred anymore after the first three pieces of some lines were gone. But I was not comfortable driving on half a belt. My friend said my harmonic balancer pulley (crankshaft pulley) was causing it. But the problem stopped with the O.E.M. belt. Go figure??
On my '95 Isuzu Rodeo V6 2WD manual, at the dashboard I have a light coming on and off when I'm driving showing M/S. I believe is related to transmission, but I'm not sure. Can someone tell me what that means?
There is anybody who might know that?
Please let me know.
"Isuzu dealers sold just 638 vehicles in the U.S. in May, down 48 percent from the previous year."
Isuzu's 2007 Line May Be Final Year in U.S. (Inside Line)
1) The engine fan sounds like a plane when I turn it on, after a while it calm down but randomly the noise come and go. I replace the fan cluth and the noise still there, Does anybody has an idea of how to fix this problem, or have experience the same issue. :sick:
2) I notice a noise when I turn on the A/C, it sounds like It needs gas, but if I acelerate a little bit, the noise goes away, any idea what could it be the problem? :confuse:
Please advise
JP
The driver's side spray nozzle on my girlfriend's '99 Passport stopped working. I tried removing it, but it was a PITA.
Went to buy a replacement nozzle and was advise to just take a very, very thin piece of wire and insert it into the nozzle to clean it out. The Honda service guy I spoke to gave me a service tag and I used the wire from that. Worked like a charm.
Mechanics refer me to autolecs, autoelecs refer me to mechanics.
Anyone have any ideas?
Can you Rodeo owners give me some advice on whether I should consider buying?
Thanks...... :confuse:
Bill
bought it with 120,000 miles on it it has 157,000 on it now.. ive abused her off road and on the streets but if you take care of her shell take care of you..i havent had the first major problem with it and would definitly recomend a rodeo to anyone looking for a reliable vehicle .
hope i helped
jay
late
Call Isuzu for more info
For Ownership and Vehicle Inquiries:
Owner Relations
(800) 255-6727
Should I just get use to the pretty light?
ok so i have a isuzu rodeo and it has been pretty good so far. I bought it new. However, recently a problem has emerged. When i turn on the car, sometimes the transmission light doesn't appear on the dashboard (the middle column of lights labeled P R D and so on). The car is able to drive and reverse but when driving the car, I like feel something is wrong. It makes werid sounds and creates a boom feeling under the car. However, its not always like that, sometimes the transmission light does turn on (middle column on dash board) and the car drives fine.
Any suggestions on what is wrong??THANKS ALOT U GUYS
I am a new memeber and have a question to anyone that can help me. I own a 1992 isuzu rodeo. It runs wonderful when it is cool outside...like fall weather. But when it is 80 degrees or hotter it runs like crap. I changed plugs, oil chnage, changed filters....but acts like it skips. Also the abs light comes on...but only once in a while.... I would be so grateful if someone could help me ..thanks.
Cheers!
