Visitor Agreement.
~JJ~
my problem is the 95 rodeo i just got is being erratic.when i first crank it up it drives fine but there is a lot of exhaust fumes.once the engine warms up,it doesn't want to accelerate properly and occasionally wants to die.what could be the problem?
Isuzu to quit light-vehicle market in U.S (Straightline)
Is this a sign that the pump is on its way out??? Or could it be something else. Is there anything else that I should look at or try to pinpoint this problem.
The year does have some to do with it, but from my experience and what I've seen, they are pretty good. I own a 2001 with about 75000 miles and I've had very minor problems - one was a small coolant leak from an o-ring on a crossover housing, this apparantly is a common problem for my year range. I also had a problem with my rear brake hardware failing, but this was after I was doing a daily paper route for a few months (hell on the brakes).
A frind of mine owns a 1999 and has had only minor problems too.
Thank you so much in advance for your help/opinion.
I changed mine out with a Duralast from Autozone, but am probably going to do it again around 100K with either an OEM or Napa belt just to make sure the quality is top of the line.
I'll give you some pointers if you'd like from my experience (just done 2, but know a few tricks).
Another thing that comes to mind is the throttle control. I'm trying to remember my friends '99, but I think it is a cable control, looking back on your post, is that what the IAC was - the interconnect cable? If it doesn't have a cable / pulley device on the upper front of the motor that moves when you press the throttle, then you have what mine (2001) has and is a vacuum type control. if this is the case, it might be something as simple as one of the control lines having a small slit in it or a small piece of trash in the line. these lines can be a bit of a booger to get to as they sit behind the upper intake area, might need to use a flashlight and mirror.
Hope that helps
Thank you so much in advance for all the help.
~Sarah
A) I don't know how to move stuff around in there to replace the belts.
C) I've had a 'squeeling' noise for the last few weeks/month every time I start the car, which usually stops after a few minutes. Yesterday, after the noise stopped, all of a sudden the gas, battery & one other indicator all came on & will not go off. I know for a fact that this isn't true, 'cause I have half a tank of gas & the battery seems fine.
Help!!
my problem is the 96 rodeo i just got is being erratic.when i first crank it up it drives fine but there is a lot of exhaust fumes.once the engine warms up,it doesn't want to accelerate properly and occasionally wants to die.what could be the problem?
2 days ago, battery light on again and same brake light and no fan blower. Replaced alternator with reman from Advanced Auto, still same problems. Alternator tested fine on the bench, but fails test while in vehicle. Advanced Auto suggested factory alternator vs. reman! Anyone had this problem?
On the right side of this type of alternator, there is a plug connection. The alternator has the "male" terminals, while the "female" terminals are from the vehicles electrical system. One of the "male" terminals, known as the "C" terminal, connects the voltage regulator to the ECM (engine control module). As stated previously, in remanufactured alternators, the voltage regulators appear to be faulty, a problem that has been in exsistence since the 1980's, whereas the voltage regulators do not emit the proper voltage.
While I did get all of the remanufactured alternators from Advance Auto Parts, they obviously do not remanufacture them, so it is not really Advance Auto Parts blame, however I wonder why they continue to sell them, as a recall has been previously issued regarding this problem.
I am confident that if the alternator for these vehicles are replaced with a completely new one, not remanufactured, this problem should cease to exsist!
Also, below is a link to the electrical diagrams for Rodeo/Passport.
1997 Honda Passport/Isuzu Rodeo System Wiring Diagrams
DC AUTO ELECTRIC
If you don't know how to "move stuff around in there" to replace the belts, have a mechanic do it because it can be overwhelming to the unfamiliar. In the event that you find out you have a bad alternator, replace it with an original...not a remanufactured one. See my previous posts on this forum regarding the alternator issue!
