The Dec Motortrend compares the PF with others in the field. Overall it did well, I was jazed with the 0-60 time, 7.3, much better than I expected. However, it couldn't quite keep up on the very tuff Off road hill that was part of the test. They tested an SE, so I bet if they had the LE with the All Mode 4WD it would have made it up the hill.
I was hoping the Dec Car and Driver would have a comparo but no luck, maybe in Jan.
Actually, the all-mode probably wouldn't have helped. The best hill-climbing performance is realized in 4LO, which is functionally identical to the all-mode's 4LO (except for a difference in the gear ratio). My guess is that the poorer performance was due to highway-biased tires, insufficient clearance, or limited axle articulation (due to the independent suspension).
First, they tested an SE with the Off Road tires that come on the PF SE Off Road model. However I looked very closely at the Pics and there was no "Off Road" badge on the front door of the PF. Any official picture I've seen of an SE OR Model has the badge on both front doors.
Second They tested the Infiniti QX56 (Nissan Armada) which has the All Mode and Traction control and it made it up the hill. MT said the Traction control made the difference, but I'm not so sure because the PF has that 4 Wheel limited slip which is like traction control.
The fact is the new Jeep Grand Cherokee and the 4Runner with its Torsen setup and locking differentials are better off roaders, but I think the PF is a better package overall and cheaper to boot.
The ride was very nice and stable, although I didn't get to drive it on the highway. It was more stable than the 4Runner I test drove a while ago. Maybe because PF has an independent rear suspension.
The A/C worked very well (dual automatic), although the controls were digital and hard to see the air flow arrows on the LCD.
Plenty of power, on tap. I punched it and that thing took off. The transmission was very smooth and you could hardly feel it was changing gears.
The third row seat was very cramped for my size (6'). In my opinion, only small children can use it (less than 7 years of age).
One thing that caught my attention was a constant squeaking noise from the left rear door behind me. I couldn't figure out where it came from.
Over all, I really liked the truck. I think I would buy it over the 4Runner. Too bad I'm not in the market to buy a new vehicle. They also had 7 or 8 new '04 models they hadn't sold. This is in Sunnyvale, CA, Flore Nissan on El Camino.
http://www.nissannews.com/multimedia/events/800px/04_sema009.jpg
Yikes!
2FastDre.
Not true. On V6 4-Runners there is a full-time 4WD mode. It's not "permenent" full-time 4WD as per the V8, but "selectable" full-time 4WD, meaning the driver has to select that mode. There is also a part-time 4WD mode too.
Bob
I am thinking to buy a new vehicle next year, I like 4Runner, but PF really impressed me as well.
Viktor
Yeh, what I meant was the All Mode 4WD system on the PF LE is similar to the 4Wd system in the V8 4Runners. It varies torque to each axle as conditions dictate. The regular 4WD system in the PF-XE,SE and V6 4Runners can be set to full time but the torque is set (40/60 for 4Runner) for each axle and doesn't vary if wheel slippage occurs.
Or, tight, smooth, solid and really nice?
Are you sure about that? My understanding is the V6 4-Runner (and V8 Sequoia) can be set to either full-time or part-time 4WD, whereas the Pathfinder SE & SE Off Road can only be set to part-time 4WD.
The Pathfinder LE has an on-demand (All-Mode) 4WD, which is much like the Explorer's Control Trac, which is RWD until the front tires start slipping, in which they then engage. The V8 4-Runner (and Land Cruiser) have permenent 4WD, in that there is no 2WD mode whatsoever.
Bob
Basically the All mode 4WD should be better in slippery conditions like Rain, Ice and snow because it can send more grip to the wheels that are slipping. However, I'd like to see a test in a magazine or something to validate that premise. I also can find the real meat of how the All Mode works, Nissan just has a short overview of the system nothing really specific.
"Toyota’s Multi-Mode 4WD system is standard on all four-wheel drive models. The Multi-Mode 4WD feature is actually an open center differential with locking capability that provides a full-time 4WD system with the ability to select 2WD mode. The all-wheel multi-mode 4WD system may be used in normal driving conditions on all types of roads from dry, hard surface roads, such as pavement, to wet or snow-covered roads. Driving with the Multi-Mode's 4WDl drive system engaged provides the driver with a more sure-footed feel because power is applied evenly to all four wheels which improves traction."
I also found 2 very informative posts #7371 and #7373 that address the PF 4WD in more detail. Below is a quote from that discussion.
"As other members have commented, part-time systems lock the front and rear axles together, and are therefore not recommended for use except off the pavement (even when it's just wet from rain). Only full-time 4WD (or "All-Wheel-Drive") systems can be operated on any type of terrain without any problems. Shift-on-the-fly part-time systems are used on all Pathfinders except 2001+ LE models and all Infiniti QX4's"
I also found a link on Auto world that gives a good explanation of the All Mode 4WD
http://www.autoworld.com/news/Infiniti/QX4_All-Wheel.htm
That's crzy
be set in an has to be manually shifted in cannot be set in an does not have an all the time , when set can only be shi
There are advantages and disadvanges to both systems. The clutch system will wear out faster (though it appears this doesn't happen during the expected life of the vehicle). Compared to a torsen centre diff. - if a clutch plate centre diff. is used it will probably wear about the same as a centre multiplate clutch. The system in the previous models is essentially a multiplate clutch similar to what you find in a motorcycle or automatic transmission, hydraulicly actuated. A clutch centre diff. uses a clutch pack to transfer torque between the two output shafts. A torsen diff. uses mechanical pressure to transfer the torque.
Both AWD systems drop your fuel economy. My vehicle looses about 10% when in "auto" mode (clutch system active). It's nice to be able to turn it off - something you can't do with a centre diff. unless they provide a "centre diff. lock" function or allow you to shift out of AWD. The vehicles I've seen with centre diff. lock only use it for extreme traction, whereas on my Pathfinder I turn off the centre clutch system for non-traction limited situations (driving on dry pavement for example). This is a plus for the clutch system.
My preference is for the Subaru's "proactive" (always driving all wheels, all the time) AWD, to that of the "reactive" on-demand system on my '98 Explorer and Pathfinder LE. I just wished Subaru offered the dual-range transfer case found in other markets, here.
Speaking of Subarus: They are about to launch the B9X, which will be the largest vehicle they have yet offered. It will have seating for 5-7 passengers, and designed to go against the MDX and BMW X5. Being a Subaru it will have full-time AWD with stability control on all models. As to whether it will offer a dual-range tranny—don't know yet. Here's a preliminary teaser link:
http://www.subdriven.com/news/publish/Subaru_News/article_280.sht- - - - ml
The car will be introduced at the Detroit car show, and will be on sale next summer. It will also be the first Subaru to introduce their new corporate "face" to the American public.
Bob
Does anyone else have problems with the seating controls on the drivers side. Do you find they get in the way when getting in and out of the vehicle? I am tall and my legs always hit the controls on driver side of the seat and I have to continue to adjust the seat when I get in and out. Placement of controls should have been lower.
Also, in the comfort package description it read 'Dual illuminated visor vanity mirrors'. Are your mirrors illuminated and if so could you describe? It's not a big deal but sometimes it's the little things that count.
I love the vehicle, I am a previous PF owner,and a nissan lover but it seems the older models had a little more thought to them. For instance The front passenger seat does not have a storage pocket on the back? The driver side does, but not the passenger? Why is that?
The back window doesn't release from the inside anymore like the older models did and the lift gate doesn't release automatically from the outside. Not sure if the auto release feature was ever a part of Nissan but it would have been a nice feature. Most SUV's have it now.
Also, did anyone get the dvd package? The dvd is in an awkward spot, it's between the driver and front passenger seat. When you open the console the lid flips up and the passengers in the back can't load a dvd. (unless they have extremely long arms that can reach over the lid and down into the dvd compartment) they can only control the dvd player with the remote. If no one is in the passenger seat that means the driver has to unload and reload the dvd player when ever it needs to be changed. Bad placement. If the dvd player is located between the driver and passenger seat at least place it in a position that is accessible to the back seat, or maybe if the lid flipped toward the front of the car instead of the back the passengers in the back could reach it easier. I can't tell you about the quality of the picture because mine has not worked from the time I picked it up, and I've had the car for a month. Still waiting for parts that are "on back order".
I think Nissan should have given more thought to the little things.
One the positive side, it's a Nissan. I love nissan products. Purchased several used Nissans for my kids as first cars and they are great cars.
As a previous Pathfinder owner I waited for the New 05 models to be released before purchasing a new suv. The 05 PF has excellent acceleration, is comfortable to drive and handles well.
I'm looking at my options. I found a place online that will repair it (get the stuck CD's out) for $200
http://www.johnson-electronic.com/pages/1/index.htm Do you know of anywhere cheaper??
The dealer referred me to a local radio place that does their stereo work but they said they would send it off and it costs $400. I noticed a few on ebay but am suspicious that they are fakes and may not last too long. My friends tell me just to replace it with an after-market stereo, but I'm pretty sure I would loose all the steering wheel controls (volume, change station, etc) any suggestions other than putting in a pocket and doing without.
I am returning to the dealer to have my Bose (Clarion?) 6 disc in-dash CD/cassette changer repaired - it skips and won't play CDs in the morning when cold, or after sitting at night for several hours. After about 20 to 30 minutes it works fine (unsure why this happens - any clues?). I am concerned that the dealer will want to switch out the new stereo (my PF is still under 30 k miles and under warranty) and replace it with a "refurbished" unit. I have read stories on people continuing to get replacement stereos that don't work.
Do I have any recourse in demanding a new stereo as a replacement, vs a refurbished? I don't want someone else's 3 yr old stereo (that may or may not work), if I can keep my 1 yr old cruddy stereo just as well and have it repaired by a good shop. I also am concerned about the lack of TLC of the dealer mechanic while they disassemble my dash - don't want rattles in addition to this dissatisfaction. Has anyone tried a CD cleaner disc in their car stereo (with the tiny brushes?) I imagine these might not work due to the tight confines in the magazine. I don't want to make a bad problem worse.
Has anybody had any experiences with these refurbished units? Am I right to be a little uptight about this? I just wonder what "refurbishing" actually entails and if will be in "like-new" condition or if they just clean off the CD lens and call it good.
Does anyone know the model # of the Clarion (Bose) 6 disc in-dash CD/cassette?
Thanks for any help with these questions.
Viking03; I don't think you should try those brush cd cleaners, that's a very tight opening, you might be asking for trouble if you try, which would give the dealer something to blame you for along with an even higher price to repair. Refurbished might mean the same as remanufactured, like alternators, starters and water pumps. Reliable replacement parts but lower prices for us vehicle owners to pay.
I agree - I would love to get away from CDs. Rather than tape I think MP3, Itunes AAC, etc is what format would be best. Better than CD convenience with none of the downfalls, and better sound quality than tape. I wish I could easily replace this changer with something along those lines. I wonder if the new 05's have MP3 capability.
I can't really comment on the '05 since I haven't towed with or driven one (but i will anyway). I tow my 21' boat which weighs around 4500lbs with my 01 PF LE and it tows fine. The rear suspension is a bit on the weak side considering my boat has over 350lbs of tonque weight. It's not a problem for day trips, but when we go for extended weekends with 2 small kids + gear, the rear suspension sags significantly with the weight. I've towed our current boat with the PF to florida from ohio, Ohio to Kansas City, and Kansas City to Wichita, KS where we live now (not including our normal boating trips), w/o any probems . Here in Kansas 95 to 100 degree days are about the norm and the temp gauge has never budged and the trans is holding up fine. I figure last year I towed over 10,000 miles. Towing MPG is around 12-13mpg
When I purchased my '01 we had an 18' boat that weighed about what your boat weighs and I had absolutely no problems what so ever. It's amazing what an extra 1200lbs and 150lbs of tonque weight makes.
With your boat the new Pathfinder with its extra 1000lbs of tow capacity, longer wheel base, and more hp/torque shouldn't break a sweat. Your tongue weight is probably anywhere from 160-250lbs, which shouldn't be a problem.
I will be replacing my 01 this spring, but I haven't decided on what. I am 95% sure I'll go full size. I've test drove the Armada, but I'm not impressed with the build quality, my current PF felt much tighter, loved the powertrain, but I don't think I'll buy one. I'll probably just go with a used Suburban, since they are a dime a dozen around here. I can't believe I'm considering a Chevy, but we'll see.
I'm now having problem with squeaking while turning on low speed with 4wd engaged.
I took it to two mechanics:
First one wanted to replace just the strut mount and second wanted to replace the cv axle, lower ball joint, and front wheel bearing.
I don't quite understand the mechanical portion of this problem. The nissan dealer stated (if I understood it correctly) that the pathfinder does not have a ball joint--has a strut instead.
Any suggestions/comments/solutions? any input greatly appreciated.
My questions are, do these sound like good prices? What are known problems to look for when trying one out? What major services have to be done to them? I have a '99 Explorer that I can't wait to get rid of, and it needed a transmission fluid change at 30k, ect. I have heard about the timing belt having to be changed, a water pump having to be put on, stuff like that.
I have a friend who has an '88 Pathfinder with, as he calls it, "over a quarter million miles," or in laymens terms about 260k. He also has a '96 Pathfinder with about 105k on it. He swears by Nissan and will not own anything other than a Nissan or Toyota, and possibly a Honda.
I'm also looking at 4Runners as well. They're a little more expensive, and most of the ones I've seen have higher mileage than the Pathfinders. I'd love to hear your thoughts and opinions. Thanks!
idntnvu
Make sure the major services were done at 30k and 60k. It shouldn't need a timing belt and water pump until 105k.
I'd like to have the 240HP 3.5L V-6 in mine, but there is no way that I'd want the manual tranny. If I was buying today, I'd be looking for a 2001 or newer LE. When I was shopping, I also looked for 4-Runner's, but they were significantly more money for similar years and miles.
You should copy that post over in the Real World Trade-In Values board, with as much information as possible. When Terry wakes up from his New Year's Eve festivities, he will give you a good indication of what you should be paying.
However, the price on both seem a little high. Have you checked the blue book value ?
What is the "Kelley Blue Book" Price?
This discussion focuses mostly on new prices but it may be worth browsing:
Nissan Pathfinder: Prices Paid & Buying Experience
As for service items, there aren't any major things to do. Eventually the valve lash will have to be done, but I suspect the engine will be worn out by then. Make sure you change the diff. and trans. fluid when you choose one. The older engine has a cast iron block (aluminum heads), the newer engine (3.5 L)is all aluminum. It's why I bought the vehicle. A wonderful engine that has won many design awards.
Couple of other complaints if I could nit pick for a second... The high beams leave a lot to be desired.... And the navigation system should be operable by the passenger while you are moving..having to pull off the road and put it in park is a terrible PIA. Also needs more cupholders and a seat pocket on the driver's side seatback.
Times change. Is it progress?
