Also, what happens to the time element? You know... 3,000 or THREE MONTHS?
Also, what about make up fluids from blow by?
And what about viscosity break down that has been extremely well documented to occur inverse square to oil life.... ie: 50% of the oil's ability to lubricate is gone after as little as 2000 miles of driving?
Lots of problems with this article but the biggest problem is that we take all the risks and once again the greenies cost us money in the long run.
As others have pointed out, there's several fallacies in the article which merit comment. In no particular order:
a) Filter technology ... is better today, but still isn't necessarily something that one should trust for very long intervals. Taken in conjunction with newer engine designs with smaller traces for oil circulation, the consumer is at risk of a clogged "oil artery" which can result in a catastrophic engine failure.
b) Engine technology ... engines still burn oil, especially turbocharged ones. By the time that one has driven "X" miles and are now down a quart, it is worth deciding if it is time to drain the other 3 quarts out and reset the system with "100% fresh" or to add a quart and make the system "25% fresh". The real answer depends on how faithful one really is to getting oil changes done, as well as other factors, such as what comes next:
c) Mileage isn't the only metric to use for when to change oil. Time is another factor - - a good rule of thumb is at least annually, for example. And another imporant factor is how far you drive your car...does it get fully warmed up and then driven for another half hour? Short runs result in oil that gets lots of volatile contamination in it which isn't burned off by the engine being brought up - - and held - - at full operating temperature. If you do short runs, you need more frequent oil changes.
Finally, we can all understand that there's environmental pressures to try to reduce "pollution" from used motor oil. Fortunately, these fliuds are recyclable - - and do get recycled - - and this expense is utterly insignificant in comparison to the lifecycle costs of an automobile, which currently is nearly $30K in initial purchase price, plus another $10K in gasoline (50K miles) and plus another $5K in insurance (5 years), etc, etc.
-hh
With that said, change your oil often and on time. 2x miles with syn, but still need to keep up with the routine.
Moto has to be changed every 2K because of the high RPM placed on the motor. She will tell you by the clutch slipping when you most need it.
Yes, it goes without saying, Oil and air filter! everyone should know how to change their oil.
This data is, incidentally, from a $120,000 Porsche, not exactly the car you want to have an engine failure.
Strange, the cooling system had 100,000 miles but the engine failed at 74,000 miles......sounds like the radiator was faster than the engine!
Engines don't "seize" because of excess wear caused by infrequent oil changes, they seize for a myriad list of reasons and in the absence of failure analysis anything can be the cause.
Misleading articles like the above rot only further the reliance on ignorance to prop up needless consumerism with religious passion.
Yes, of course it's not all lies, new cars are strong and wonderful, but keeping fresh clean fluids in them makes them even better!
If the Dr. Evil & mini me of the "Buy a new Car Often" Cartel knew how often I change the fluids in my 26 year old Toyota, well, I just don't know what would become of me. So mum's the word, n'est pas?
Years ago I did an experiment, I bought an old junker for $250 from a friend(it was his mothers car and had been sitting way too long), I did nothing but change the oil like a nut every month (the local auto shops were having a price war ( as low as $9.96 w/coupon from Sunday paper), after about 10 months the car was running so much better I sold it for $1800!
Other than rust, deer and telephone poles , old dirty fluids lead to the demise of many otherwise perfectly fine functional vehicles.
I have a 95 Jeep GC and the previous and original owner had it serviced faithfully at the stealership and now with 160000 and with synthetic oil and it doesn't even start to get dirty until the 7000 mile mark. But on the other hand I also have a 65 VW Beetle that runs mineral based oil that is dirty at 1500 miles. I know nothing about the previous history of its' service but I am not about to let it get much more than 2500 miles before giving it a change. For me changing oil when it gets dirty is the only way I know of to be assured that I am not "throwing away" useful oil and also that I am not leaving the oil in too long leading to problems down the road. This crap about changing oil at a certain mileage is just that, crap. These oil monitoring systems could prove to be one of the best things new cars have on them if they work the way they are intended. I can imagine there are a lot of people don't even know what oil looks like so this would be good for them. There are just way too many variables to say every engine needs an oil change at a certain mileage.
Keep a clean air filter, and it will insure that 10k mi even more. E10, Or 90%Gasoline/10% Ethenal burns cleaner, Reducing carbon build up"gunk" in the long run.
A good rule of thumb, If its a used car, and you have no clue about its previous care. 3k mi intervals are just fine, after you own the vehicle for a period time until satisfied, safe to go longer.
OR
Carbureted(dirty engines), or older "Oil Crisis" built vehicles, stick with Conventional oils, and closer intervals. Less tolerant engines tend to be more friendly with thicker Conventional lubes..
Some Synthetic oils in older engines, tend to be on the lighter side of the engines harsh nature(sometimes produce knocking). Some of which even with the proper weight/viscosity still tend to wear down, and dirty faster. Compared to a newer engine. In this case, switching from conventional to synthetic, wont see any performance/life gains of your oil or engine.
Turbo's respend well, to lighter synthetic oils Which are usually found on higher performing engines anyways... Faster circulation(heat dissipation) through the oil. and reduced resistance of spooling for better performance.
Superchargers usually have a medium viscous oil20w-30w(synthetic prefferably) with intervals ranging from 30k mi"performance" to 80k mi"daily driver" condition intervals.
5bikes, and 7cars later, all had there own schedule. 1500-4000mi for bikes, and 6500-12,000 for the cars avg.
My 1996 BMW M3, 148k,.. Oil changed at an average of 8k. No issues... My e320.. gets changed at 12-15k... with 201k miles and no issues.
No one is "NUTZ" iff they don't follow your instructions.. to each his own but I wonder how long you have felt that everyone that doesn't think like you is "NUTZ"?
I only have one comment, and that is to NOT peel that sticker off, after you have read all of this..use it for the next 2000 miles (for at least most cases) and read your owners manual for the appropriate interval, it may be even more than the 2000 miles.
Good job to those reeporting all of this and their research and providing information to all of this.
Oil changes, to an extent, determine engine life. So if you never change the oil, your engine will go kaput after so many miles. if you change the oil every day - just saying - your engine is unlikely to go kaput because of poor oil.
Somewhere in between, there is a balance between engine life and oil change frequency, other things being the same.
If I want my engine to go, say, only 50,000 miles, can I change oil once, at 25K, and leave it at that?
How about if I want it to go 250,000 miles?
Point is, if I change my oil according to the manual, how long will my engine last? If I change it half as often, how long? If I change it twice as often?
Without correlating engine life to oil change frequency, it makes little sense to say that it makes no difference whether you change oil at 7500 miles or 3000 miles.
VVT screens in Hondas,Subaru turbo cars, and gm cars plug up often.
We see people who let maintenance go a long way and they have all sorts of variable valve timing issues. Mostly related to lack of oil changes.
Some vehicles that use 0w-20 or 5w-20 oils also tend to "use" a lot more oil per 1000 miles that others that use heavier oil.
Most people are don't check their oil often so most of the time they're running low.
Also love trying to change spark plugs that have been in for 100k miles in some vehicles!!!
Sythetic will not break down, and theoretically, it could go 10k miles, however, your oil filter can't comfortably go that. Micro metal shavings will be slipping through and those will create more micrometal shavings in you engines moving parts. The increase is exponetial, not linear. And a pluging of the filter restricts the lubrication. At least change your filter every 5k.
I will continue to do every 3k for conventional. I did this with a 98 taurus I bought in new and sold it in 2008. Got the same mileage as the day I bought it when I sold it with 260k miles. Wear increases exponentially because worn high-stress parts slap harder and vibrate, creating friction.
And I wonder if the writer is aware that all oil is recycled these days.
change the "Filter" top the oil good to go!
I've experienced the ollowing results:
- 84 VW Jetta GLI went nearly 198k miles; transmission died, so I go rid of it.
- 95 Saturn SL2 went 188k before the head gasket failed.
- 2000 Xterra (4WD V-6) went 150k before being traded in for a larger SUV. It still ran like new.
- 2003 G35 has 165k on it and runs great.
- 2008 Sequoia has 90k and runs like new.
I do not, typically, operate in severe conditions, but at times. I am by no means or strectch of the imagination an environmentalist; which many of them, I believe, fall in to the enviro-wacko category.
but started changing oil and filter every 5-6k and now at 49k, no more rattles!
You truck needed a new engine because it was a POS Chevrolet.
I have been in the Quality Assurance now for 7 years.
All data shows that GM, Ford, and Chrysler brands as well as their sub brands have dramatically inferior drive trains.
Altho
Source Mitchell On Demand. Engine specifications.
Honda Accord 2007
0.020---0.040 mm (0.0008---0.0016 in.)
0.05 mm (0.002 in.)
2007 Chevrolet Cobalt
•Piston - Piston To Bore Clearance
0.010-0.041 mm
0.0004-0.0016
One top-notch filter, as evidenced by cutting it open and examining it, is the Baldwin (no, I don't own stock--I just buy their filters by the case), made in Nebraska.
Another nice touch for a motor is the oil additive SFR, made in Montana. I've seen it work firsthand and for "boundry" lubrication--that very last layer of molecules between metal-to-metal contact--it is excellent insurance if your motor "uses" a bit of oil, and it's great for start-up protection.
2000 Jeep Cherokee limited. 4 L I6. 243 ci, another good old cast iron Rambler-based block with fuel injection again, of course. Purchased at 65,000 miles in 2003 from fleet user. Oil and filter of choice--NAPA (Valvoline) and NAPA gold filter. Did have head/rebuild because of overheating. Even though it was pumping water through the engine Suspected 1st overheating from failure of oil pressure sensor, hot soak, and failure to detect less consequential causes of previous led 2nd overheating hot day, etc. Currently 185,000 miles. Regular, 3,000-4,000 mile oil changes. Most driving in past year in-city. 656,000 miles. So far 3 vehicles averaged 218,000 miles. Choose wisely, my friends, take care of your vehicle and it will take care of you.
Merry Christmas!
conventional oil- 3000-5000 miles*
full synthetic- 5000-10000 miles*
synthetic blend- 3000-6000 miles*
high mileage- 3000-5000 miles*
*The distance you go on your oil change should depend on a few factors such as how much your car may burn oil between oil changes, any leaks the motor has, and the style of driving you do between the oil changes. Just remember, the more you change the oil, the better it is for the car.
