Jack
fo
Jack
Also, any ideas on leasing a CPO 2002 X5? Anything I need to realize because if it's the same deal, I think that would be much more affordable especially since it's covered by the BMW "extended warranty 6/100".
fo
Several BMW sites on the net have fairly accuarate lease factors (road___.org)
Establishing a relationship with a BMW salespersopn is another way to go. Let them know what you're looking for and that you're waiting on the lease factor to drop. Most will keep you in mind and give you a call. On slow days, they'll find a way to make things "work".
Jack
Jack
To quote from the BMWUSA.com site:
"Only the best pre-owned BMWs qualify for the Certified Pre-Owned BMW Vehicle Program. To be eligible for enrollment in the Certified Pre-Owned Vehicle Program, a late-model vehicle must be in service for at least six months or have more than 6,000 miles but less than 60,000 miles on the odometer. They must pass an extensive examination — a thorough and rigorous inspection by BMW factory-trained technicians. They inspect the vehicle for safety, performance and wear. If something is not right, it is fixed. If it cannot be fixed, the car cannot become a Certified Pre-Owned BMW.
In short, we're picky. But when you see everything covered under our Protection Plan, you'll understand why.
Every Certified Pre-Owned BMW is backed by a special BMW Protection Plan which provides coverage on the car for up to two years or 50,000 miles (whichever comes first) from the date of expiration of the 4-year/50,000 mile BMW New Vehicle Limited Warranty.
The Certified Pre-Owned BMW Protection Plan has two elements: The Certified Pre-Owned BMW Limited Warranty abd BMW Roadside Assistance."
Hope this helps,
Jack
Is it safe to assume that you can only get a car with CPO if you purchase from a dealer? They don't have an inspection process with the ability to purchase a warranty extension for individuals do they?
Certified Used Vehicle Programs
Just Curious
Hope this helps,
Jack
1. Anyone know when the 2004's generally come out. I might wait if they are coming out soon.
2. I have heard rumers of a refresh of the body style in the next year or 2. Any info here?
3. Generally what can I expect/target for negotiating off of MSRP? I live in the Chicago area with many dealers.
MJ
2. I have heard rumers of a refresh of the body style in the next year or 2. This October.
3. Generally what can I expect/target for negotiating off of MSRP? I live in the Chicago area with many dealers. 3.0, ~ 2k. 4.4, ~ 1k. Maybe a bit more closer to October on a leftover.
Of course, YMMV.
Hope this helps,
Jack
and would like some suggestions on wheel locks. I have used BMW locks but I found them not up to the job. One good hit with a hammer and they are
useless
Lars
BMW X5 Problems
So, wouldn't the smart thing to do to buy a 2002 CPO and pass on a new 2003?
With regard to a stick shift, would you expect the pricing to be proportionately lower (on a used unit) to reflect the lower MSRP, significantly lower because they are not wanted by the used buyer, OR relatively higher because they are rare? In other words, how do stick shifts "residualize" in the real world?
In back issues of Roundel and Bimmer, the columnists aren't particularly impressed by the longevity of BMW automatic transmissions (maybe 100K before major overhaul). I figure that an overhaul on a X5 automatic would equal a California mortgage payment. Anyone's mortgage payment. How much could a Sachs clutch and pressure plate cost, anyway? $300? Plus 3-5 hours of local labor to throw it in and cut the flywheel?
Speaking of Roundel, if you join the BMWCCA you get a free subsciption AND a significant rebate on a BMW purchase or lease after a year's membership. I joined a year ago in anticipation of possibly getting out of my Jeep GC. This isn't a bad investment not only for the purchase/lease discount but to read about new BMWs coming out and other developments. Incidentally, their columns have a lot of tech commentary by hard core BMW owners and techs. A lot of this commentary is negative. Not only do they recommend obsessive/compulsive
airline-like maintenance intervals to avoid problems (really how often do most Americans really want to flush out their brake fluid?) but it seems like BMW has had some serious tech problems. These include engine problems (e. g., bad block castings and liners) leading to catastrophic failures, massive electrical problems, rear suspension failures,etc. etc. Apparently, you just don't want to own a BMW not in warranty. (The old fashioned, 100% cast iron Chrysler 318 in my JGC looks better and better. Feed it Mobil 1 lube oil, Red Line Synthetic ATF and at 104,000 miles it runs like a train.)
I think buying a used BMW via CPO takes away most of the risk and worry. But, if you want to save a few bucks, You could buy it without CPO, save maybe $2k - $3k, and start a maintenance/repair fund with the savings. But, an 02 CPO probably won't save a lot over an 03. Some would take the 02 CPO over a new 03 just for the longer warranty.
Yes, BMW's have problems. The V8 block problem is well documented. But, and this is a big but, BMW stepped to the plate and extended the warranty and fixed the problem. It took several attempts to identify the exact cause. But, they did make it right. It's an interesting story, too long to document here.
I am in the process of selling an 86 BMW 528e that has over 197k. Yes, we bought it new, but it was out of warranty for quite a while. It is on the original engine and transmission. It's been a great car. Several minor issues, but overall, a great car. It still out brakes and handles most of the new stuff being sold.
As far as flushing brake fluid goes, I do it. If you want to compromise the stopping ability of your BMW/JGC when the brakes are hot, then have at it. But as for me and my family, I'll change brake fluid and keep the braking performance as close to new car specs as possible.
A comment on X5s with 5 speed. My son has a X5 with a 5 speed. My wife has an X5 with auto. I have a 530i with 5 speed. The X5s 5 speed has a very low 1st gear, much lower than the 530i. It may not bother you, but just know that upfront. The X5 just fells more "right" with the Steptronic (automatic) in my opinion.
So, yes, I think BMWs appeal to people who put handling and braking at the top of their list. If you value reliability, BMWs are quite good, but there are better alternatives. (the JGC will never make a reliability list. )
I hope this helps....
Jack
There are 3 within a 500 mile radius of where I live (NYC).
2001 Prelude Type SH, 2022 Highlander XLE AWD, 2022 Wrangler Sahara 4Xe, 2023 Toyota Tacoma SR 4WD
Incidentally, did everyone catch the preventive maintencance recommendation in the June issue of Bimmer? They recommend replacing the water pump and converting to an aftermarket aluminum thermostat housing at 40,000 miles (less if the car is used competitively)on most 6 cylinder engines. It seems Bimmer Magazine isn't too impressed by the plastic OEM water pump impeller and thermostat housing.
I'm impressed with the ride quality on the non-sport X5. The Sport Pack on the X5 is a stiffer ride, and I don't see where the increased control or sportiness justify its cost/stiffness in most situations.
Just MHO,
Jack
Anyone with any good lease deals in NYC area lately?
How much should I expect to pay above invoice for 2003 X5 3.0i this month?
Thanks for any input.
It's had a couple of recalls the dealer fixed when I took it in for an oil change - I couldn't even tell you what the recalls were for - nothing I ever noticed.
I thought I wanted a manual X5 until I test drove a manual and an automatic - auto all the way. I usually get a manual transmission in any vehicle that offers one - not the X5.
I'm definately buying my X5 when it goes off lease, it's one of the best BMW's I've ever leased/ owned - fantastic.
I'm still impressed when I drive the X5. (Wife and son each have one.) The room and luxury beat the 5 series. Great for hauling the 2 year old and 6 year old.
Jack
ever heard of this on an X5
Also, the Steptronic seems to work very well.
Hope this helps,
Jack
Both seem to have more than adequate power. Neither will win many drag races, but each can take you down the road quickly.
The X5 cargo area is a little small, but the spacious seating areas seem to make up for it, at least for my family.
If the "drive" of the X5 is a high priority, then it may be for you. If not, the the XC90 will do a great job.
I don't see a loser here. Both are winners.
Good luck,
Jack
Where in the SE? Be more specific and I'll give you a recommendation.
Jack
What about the interior don't you like? I find it to be a good layout with good quality materials and comfortable seats.
Hey, but as they say, buy what you like.
Jack
I'm located in North Alabama but will travel for a good deal. Thanks, Jeff
Most dealerships will give you a good deal if you ask for one, can wait for one, and are ready to act on one when it's offered. But, on the other hand, most have professional salespeople, and they are trying to get all they can from you. You can get clubbed like a baby seal most anywhere.
Good luck,
Jack
Samir
I'm new in this board. I just bought a 2001 X5 3.0i at an auction with 66k mi,PP,CP,NAV,auto, and it came with an aftermarket Apline XM cd changer with JBL amp and a 6" woofer. It sounds good but the engine noise. I took a vehicle history from the dealer and the previous owner showed concerns but they could not fix it. They even replaced the alternator. I had a similar problems from my previous vehicles and it's very hard to get rid off. Sounds to me like audio installation problem. It is probably not grounded properly. The noise is still there even when the radio is off but it's worse when the XM radio is on. Any suggestions? I would greatly appreciate it.
Overall it drives very nice. It is clean inside and out. How can I find out if any recalls has been repaired? It doesn't show on the dealer history. By the way I got it for 27,500.
Thanks ahead for any suggestion.
G
Jack
